Old 03-29-2014, 12:30 AM   #1
Shiftgreen
Shiftgreen's Avatar
Drives: 2014 2SS 1LE AGM
GM recall worry some?
Apologies if this has been mentioned alrdy.
Im going to do the financing tomorrow for my car but I've been reading about the recalls from gm this past week. Could this cause a negative effect on our cars or the company in general ? I would hate anything to happen especially now that I'm about to get a new car from them.
Shiftgreen is offline   Reply With Quote
Old 03-29-2014, 12:33 AM   #2
yzrider58
Aviation guru
yzrider58's Avatar
Drives: 10 1SS, 09 Acadia, 90 K1500 Z-71
Companies have recalls all the time. The Camaro has been rated very well in reliability. You have nothing to be concerned about.
yzrider58 is offline   Reply With Quote
Old 03-29-2014, 12:35 AM   #3
lawman007
Panama-Gulf War Vet
lawman007's Avatar
Drives: '11 SW 1LT/RS 6M
What recall did you refer to? I know there was a update or SB for the personal data package. But other than that...
Troy
lawman007 is offline   Reply With Quote
Old 03-29-2014, 12:40 AM   #4
Todd in Vancouver
Todd in Vancouver's Avatar
Drives: 2014 ZL1
Breath deep and it'll all be OK.
BTW, Toyota was fined over $1 Billion, but it doesn't seem to be in a lot of headlines.
http://www.nytimes.com/2014/03/20/bu...uiry.html?_r=0
Todd in Vancouver
'14 ZL1 Camaro
'67 Camaro SS Pro-tour in process
How hard can it be...
Check out my other build http://www.pro-touring.com/threads/9...ject-Obsession
Todd in Vancouver is offline   Reply With Quote
Old 03-29-2014, 12:42 AM   #5
alaskacamaro
alaskacamaro's Avatar
Drives: 2012 2SS 45TH Anniversary
I spoke to a shop owner the other day about the recall on the ignition shut off. Camaro's should not have any issues. He told me the ignition issue will only happen if someone has a ton of stuff hanging from their keychain. The weight causes the key to push down against the switch which kills the engine.
Not an excuse but makes some sense
alaskacamaro is offline   Reply With Quote
Old 03-29-2014, 12:42 AM   #6
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
I wouldn't worry about your car because the 5th gen has proved to be pretty reliable and the TSB's have been minimal.
If there's something to worry about, it would be the overall health of GM. All car companies have recalls every year but this GM recall has taken center stage lately. It's mostly due to the amount of vehicles affected and the bad history behind it. The good news is GM's stock has remained pretty level lately, even with all the recalls.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 03-29-2014, 01:23 AM   #7
Wuiquen
Wuiquen's Avatar
Drives: 2018 Hot Red ZL1
What was this last recall about? I got an email about it from the dealership. Haven't called yet. No worry. Car has been reliable for the last three years and half
Sent from my DROID RAZR using Tapatalk
Wuiquen is offline   Reply With Quote
Old 03-29-2014, 07:44 AM   #8
RollaMo
RollaMo's Avatar
Drives: 2017 2SS
I don't think he is asking about any Camaro recalls.
He is wondering about how recent GM recalls in general will affect the overall health of the company.
And what or how that might affect the value/perception of any other GM products.
This ignition switch issue on their compact cars is a serious issue, as there have been multiple fatalities involved and the lawsuits will start piling up.
However, other manufacturers have "weathered the storm" on similar issues (Toyota, Ford, Firestone, etc).
For sure this is going to cost GM a lot of money and potential customers.
But this is what any manufacturing company deals with on a daily basis these days.
Nobody is immune to issues or problems.
1996 Corvette - LT4
2017 Camaro 2SS
2019 GMC Sierra 2500 HD
2015 Harley Davidson Ultra Limited
RollaMo is offline   Reply With Quote
Old 03-29-2014, 07:46 AM   #9
jd10013
Drives: 2012 camaro
actually, I believe it was 1.2 billion. the fine was so high because they determined that Toyota was trying to cover up the acceleration problem and avoid liability. that's essentially whats going on with GM. The fact that they may have knew about it and not disclosed it at the time of their bankruptcy proceedings will most likely result in criminal charges against GM. in all likelihood, GM will receive a fine possibly as large, likely larger, than Toyota did.
the reason the issue of disclosure is so big is because according to bankruptcy law, a company can not be held liable for anything that happened prior to the filing.
this case isn't really about a recall, that's fairly minor. what it's really about is how GM handled and disclosed the problem. if it can be proven that GM knew about the problem prior to 2009 but kept quite because they knew the bankruptcy would shield them from liability..................then GM will be in big doo-doo
jd10013 is offline   Reply With Quote
Old 03-29-2014, 09:30 AM   #10
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2021 zl1 a-10 WildCherry
The case is as many people knew that not just the GM cars but all cars could have their ignition affected by having lots of things hanging off the key rings pulling the weight of the key down......... this has been common knowledge to me and well a lot of people since crap I DUNNO.... LIKE TWENTY YEARS AGO. The fact they went after g.m. who just kind of half assed replaced the ignition switches for a lot of cars back when they found out about this problem in some of their models and did not retro fit them to every car affected is what they are going after them about now that they have a recall..... Yes people died, but will they look at competitors having the same problem? NO.... And g.m. is just being more cautious and doing more recalls if they think there is any problem as big government loves to fine and slap hands and act all BIG.. Like they always know what is best for everyone like say... a current program with 26% approval ratings. SO g.m.'s new CEO is making sure the company is more safe which is actually good for us, at the same time in a historical perspective life is not always fair.... I remember a ways back when G.M. had the largest fine ever for the build of the 73 model year up chevelle as it had a tank with a fairly straight fill tube that exited the rear bumper and a single flapper to keep the gas in the tank.
Well bleeding heart juries being all liberal with other peoples money that they are ruining our health care system, ( some constant rise in health care cost due to no tort reform...gee is our president a lawyer?), and every thing they touch said oh lets give a 9 billion dollar judgment or something to that effect because a family in California got ran into in big pile up on a California freeway and burnt to death from being slammed in the rear. My last car I built before my Camaro was a 73 chevelle ss clone, the rear bumper is massive with a rolled tube inner that weighs like at least more than me.
The government though said they should have had a second flapper in the fill tube to prevent gas ever being able to get out the tank which by the way was under the trunk and surrounded by frame rails also. Funny how they can go after g.m. when say the drop in gas tank of the 65 mustang is 1000% worse and the Ford Pinto.... oh but back in the day a liberal democrat president named Kennedy drove a 65 Mustang.....coincidence?
You be the judge, now in this environment the EPA and such have way too much power and need to be slapped big time into compliance with what is the reality for people who have to survive..... take for instance say Ethanol in our gas forced on us, a real rotten mess that is, or how they pay now to ruin roads up here in the N.W. in timber lands they wont let be harvested we the tax payers paid for so people will not use the roads so they do not have to maintain them..... Then come a say giant forest fire from their not managing things right in the forests there is no road to fight fires, and do you want to talk about protecting Salmon?
They require at least a 30 ft buffer of trees around the water in both sides of the rivers and streams to protect the salmon even if its not on the sunny side and even if the water is too cold for the fish as it is to promote their growth in numbers and size, I remember when they made fell trees into rivers be removed by timber companies as it hurt the fish and then they went everywhere removing the trees from the water. Now much later they actually add trees they said were bad to the water to help the fish spawn and keep the water not so rough......
The big government we have is a one size fits all approach that's a real crock compared to what our founding fathers knew with states having so much more power. Career politicians are the thing that is ruining our country because they cannot relate to us the common people and do nothing for us but only inflate their opinion of themselves as its a popularity competition with people thinking of themselves and what they can get from big sugar daddy government....the other guys money, and that's just what they want, dependence on them for everything.
And that's where revolution comes in back in grade school in our history books with the British taxing us because they could....no voting for us to say do something like approve Obamacare, no its just shoved down our throats as they say its a mandate and the "will of the people" because someone got reelected. And the will of the people comes down to a very few making the decisions and most have ZERO common sense.
SO if g.m. gets its hand slapped compare it to others? Is that what the liberal loving press will do? or are they under the thumb of those that allow them a lot of latitude like the media want so that some day we have to what? Watch Viagra commercials followed by Trojan twister commercials before we can get to the Cialis commercials as they funnel so much money to campaigns from medical drug companies profits soaring they can advertise like crazy with our money they spend to sell us more in a vicious cycle that raises prices to us. And that's the state of the world, at least a small part of it, and if you put too much stock into it look out AS THE STOCK MARKET IS RIPE TO FALL HARD SOMEDAY. And the lies you are fed can be comparable to who has the power at the moment in history, and only time will tell the truth hopefully if the historians are not to threatened. Good day this has been Walter Cronkite reporting for CBS evening news...... Sound of gunshot in distance as camera rolls out... LOL and the economy is strong!
2021 Wild Cherry ZL1 A10, Sunroof, Data,Red Carbon Interior, Nav, RotoFab Big Gulp , Elite x2ultra, Borla ATAK, Driveshaft shop, BMR susp, Speed covers, intercoolers, ATI , 2650 MAG, DSX lid, 103 NW, TSP Longtubes & cats, LPE, 1le mods, ,LME cover, Katech pump and chain, Trunnions, BTR stage 2, LPE boostapump, Gforce, Speed eng , Granetteli, etc etc
Old 03-29-2014, 09:48 AM   #11
Frank in MD
Raining Blood
Frank in MD's Avatar
Drives: 2014 SS Performance Sedan
All you have to do if you're concerned that you're vehicle might have an open recall is to check the NHTSA.gov website AND have your dealer's svc. dept. run your VIN to see if your vehicle is included.
Ordered 1/9/12 - Born 2/3/12 - Delivered 2/21/12 - '12 1SS/RS Summit White - TRADED.
2014 SS Performance Sedan #2974 - Red Hot 2 - S/R. & Spare. Built 01/09/14 #238 of 291 as configured
Frank in MD is offline   Reply With Quote
Old 03-29-2014, 09:59 AM   #12
cadyshac
It's in the hole!
cadyshac's Avatar
Drives: '11 2SS L99 SGM, '18 2SS, M6, HWSE
Yeah, and that pisses me off too! All my suburban neighbors run like lemmings to the sea to their closest toyota dealer because they are so reliable and run forever........BS!!!!!
cadyshac is offline   Reply With Quote
Old 03-29-2014, 10:57 AM   #13
tmcclint
tmcclint's Avatar
Drives: 2014 AGM 2SS/RS 1LE
Yet another reason for GM to put push-button start in all their cars. To OP, I don't think this will hurt our cars. The Cobalts will probably get a bit more scrutiny at resale to make sure the ignition was fixed but other than that it will be fine.
2014 2SS RS 1LE
tmcclint is offline   Reply With Quote
Old 03-29-2014, 10:59 AM   #14
The issue definitely should've prompted a recall right when GM knew about it.
With that being said, if people did what they were supposed to and didn't hang everything but the kitchen sink off their keys, none of this would've even come up.
So it's kind of a chicken vs the egg matter.
