#1 |
![]() Drives: 2014 Corvette Stingray Join Date: Nov 2013
Racing Tires
The stock Michelin tires grip good. However, does anyone know if the cup tires or better are available for the stock z51 rims?
#2 |
![]() Drives: 2014 Z51 Lime Rock Green Join Date: Jan 2014
I doubt if you will find a better tire, for the track, that fit the stock Z51 rims than the Michelin Super Sport Summer tires that come with the car. Just have to remember they are Summer tires and don't like cold temps. There are several on-line tire reviews that give this tire very good marks.
Some folks have swapped them out for the Michelin All Season 3 tires but they have no plans to track their cars and wanted a tire with a better wear factor. The A/S 3 tires are NOT run flats so keep that in mind. Hope this helps. |
#3 |
![]() Drives: Crystal Red C7 2LT Z51 Join Date: Feb 2014
I've been looking around quite a bit - maybe the Proxes R888. 285/35ZR20 in rear, 245/35ZR19 in front. They're R-Comps and I would be fairly sure they would outperform the PSS. Doesn't look like the wider tires will fit on stock rims per Toyo's specs. No testing or concrete data on my part, just going off R-Comps normally outperforming anything else (despite how good the stock tires are). Not run-flats, of course.
C7 Status:
1100 - 2/10/14 3000 - 2/12/14 TPW - 3/17/14 Born - 3/20/14 R8C - Pickup on 4/3/14! |
#4 |
![]() ![]() ![]() ![]() Drives: '14 Z51 3LT Stingray and '13 Cruze Join Date: Feb 2010
At what temperatures do the stock tires perform the best? I was driving the other day with temps in the mid-to-high 60's, and they still break loose a bit under WOT at around 5k RPM. Is that normal?
"We have a mental health problem disguised as a gun problem, and a tyranny problem disguised as a security problem."
"What is a moderate interpretation of the text? Halfway between what it really means and what you'd like it to mean?" -Antonin Scalia |
#5 |
The real question is what the tire temp was. When autocrossing I normally want as much heat as possible in my tires (note: this is for the M Roadster I run while I break in the C7) and don't spray them down to cool until they're close to 120°F+. Some tires are best at even higher temps. Since the C7 just displays "warm", I would take a temp gun to them and see how it acts at different temps. Even at ideal temp, this car has enough torque to break any tire loose if you really push it!
C7 Status:
#6 | |
I'd call michelin for exact range but I'd guess one you get over 120° they start to get real sticky but keep under 200 I would think.. I'll Google
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
#7 | ||
![]() Drives: 2014 Z51 coupe Join Date: Feb 2013
On a warm day, take the car for a 15 minute spirited drive to get the tires up to temp and they'll grip a ton then.Keep in mind, however, that even the grippiest tires will break loose with 465 ft/lbs of torque. The tire can't overcome physics
Current: 2014 Z51 | Torch red | Black interior
![]() Previous: 2012 C63 AMG coupe | Obsidian black | Red/black interior | Performance Package Previous: 1996 BMW M3 | Estoril blue | Track car | Heavily modded for the track but still street legal... barely Previous: 2011 M3 coupe | Jerez black | Fox Red interior | Competition Package | M-DCT |
#8 |
Well, I suppose you could fill the back of the car with bags of concrete. F=µmg and all that...too bad it's also a=F/m. Darn physics keeps trying to slow us down!
C7 Status:
#9 | |
