Old 03-18-2014, 04:46 AM   #1
ahesq
Drives: 2014 C7, 3LT, manual
7 sp manual - gear crunch into 2nd and sometimes 3rd
When the car is cold, I experience a small crunch when shifting into 2nd, and sometimes 3rd. If I wait a second before shifting into 2nd, no crunch.
No problem with any other gears.
When hot, no problem at all with 2nd and 3rd.
Any one else have this problem?
ahesq is offline
Old 03-18-2014, 05:53 AM   #2
Ciscokid
Drives: 2013 ZL1 Vert - BRM&2014 NRB Vette
I have the same problem, took it to the dealer, was told it was normal. - go figure
Ciscokid is offline
Old 03-18-2014, 05:00 PM   #3
Buzzardz_vette
Remove Before Flight
Buzzardz_vette's Avatar
Drives: 2014 Cpe Z51 2LT Torch Red
Have the same problem. Assumed it was because it was cold. As you said, as soon as the car warms up, it stops. I've also installed the skip-shift mod. Do you have that installed?
Z51, 2LT, 7-speed, Torch Red, Adrenaline Red, Red Calipers, Carbon Fiber Dash, Magnetic Selective, MyLink Nav, Black Wheels, Performance Exhaust, and Corvette Museum Delivery
Buzzardz_vette is offline
Old 03-18-2014, 11:54 PM   #4
raymbarr
raymbarr's Avatar
Drives: 2014 Laguna Blue Convertible
I hear that with mine as well. Had it a month. Wouldn't mind some confirmation from others that it's "normal." Glad the dealer said so. This is the first I've discussed it - I haven't asked my dealer yet.
raymbarr is offline
Old 03-19-2014, 08:46 PM   #5
New C7
New C7's Avatar
Drives: 2014 Corvette Coupe
Same with my car. Better when warm.
New C7 is offline
Old 03-20-2014, 08:54 AM   #6
binko
Drives: Honda Accord
It may be a result of cold and thick oil in the transmission that is working against the syncros. It should disappear when the trans warms up or on less frigid mornings.
binko is offline
Old 04-03-2014, 09:50 PM   #7
MiamiDadeVette
Drives: 2014 Corvette Z51
Send a message via AIM to MiamiDadeVette
Same Problem. Wonder if there is a fix or recall?
MiamiDadeVette is offline
Old 04-05-2014, 09:55 AM   #8
gthal
gthal's Avatar
Drives: 2014 Z51 coupe
All of the cars have this to some extent... it will improve with mileage and with temperature. My M3 was like this too and after about 4,000 miles it was WAY smoother.
Current: 2014 Z51 | Torch red | Black interior
Previous: 2012 C63 AMG coupe | Obsidian black | Red/black interior | Performance Package
Previous:
1996 BMW M3 | Estoril blue | Track car | Heavily modded for the track but still street legal... barely
Previous: 2011 M3 coupe | Jerez black | Fox Red interior | Competition Package | M-DCT
gthal is offline
Old 04-05-2014, 12:50 PM   #9
regguy1
regguy1's Avatar
Is this problem reported with base or Z51's
regguy1 is offline
Old 04-06-2014, 01:57 PM   #10
gthal
gthal's Avatar
I believe the transmissions are essentially the same (save the gear ratios). I really wouldn't describe it as a problem... the tranny just needs to get worked in a bit. Mine is already improving and is noticeably better in warmer weather.
Previous:
gthal is offline
Old 04-06-2014, 02:55 PM   #11
MiamiDadeVette
This is my fifth sports car. I never had this type of problem on any of my other high end cars.
Old 04-06-2014, 07:13 PM   #12
gthal
gthal's Avatar
My BMW 328 and my BMW M3 did this for the first few thousand miles. That is, being a little stiff and sometimes a "crunch" going into a gear when very cold. Both of those cars stopped doing it... my C7 is also improving with both the warmer weather and use.
I will put $20 on the OP's car no longer exhibiting this in any meaningful way by June... assuming he is driving the car regularly
Previous:
gthal is offline
Old 04-07-2014, 09:10 AM   #13
Buzzardz_vette
I've been driving mine fairly regularly since Dec (~3000mi) and I still have the crunch shifting to second gear. I thought it might have something to do with the skip-shift mod, but seems like everyone is having the problem. It does get better as the car warms up. Hopefully, it will go away as I get more miles on it.
Old 04-07-2014, 04:17 PM   #14
purpleRac3r
purpleRac3r's Avatar
I have over 9100 miles on mine, and no "crunch" whatsoever. When cold, all I get is a little click as it goes into gear, more felt than heard. Having driven mine all winter in extremely cold temps, I never really experienced a "crunch". It was a little harder (stiff) to shift until it warmed up. I had way more noise/notchy feeling in my 2002's 6 speed manual.
purpleRac3r is offline
