Old 03-18-2014, 03:44 AM   #1
ahesq
Drives: 2014 C7, 3LT, manual
A/C Compressor Noise
My A/C Compressor works fine, but it is noisy. More noticeable at idle and slow start accelerations.
It sounds like the old Ford power steering pumps of the 1980's. Turn off the A/C and noise is gone.
Luxury cars have small mufflers installed on the high pressure line out of the compressor to eliminate this. Wonder why Chevy didn't install one for this car.
My 2013 Camaro SS I traded in for my C7 had zero compressor noise.
Anyone else out there notice this?
ahesq is offline
Old 03-18-2014, 01:00 PM   #2
Ka Razy
Ka Razy's Avatar
Is your C7 a Z51? I hear the "water runing sound" on cold startup also.
Heres what I read. Hope this helps...
Checking Engine Oil/Dry Sump Oil Tank Noise on Startup
For an accurate reading of the dry sump lubrication system, check the oil level only after the engine has been thoroughly warmed up, after at least five minutes but no more than 15 minutes after engine shutoff.
Some customers may comment on a noise similar to running water from the dry sump oil tank when the engine is cold and started. This is a normal sound of oil returning to the tank.
I'd rather be AutoCrossing
06-28-13 Status 1100
11-22-13 Status 2000
11-29-13 Status 3000
12-12-13 Status 3300
12-16-13 Status 3400
01-06-14 Status 3800!!
01-10-14 Status 4B00
01-13-14 Status 4200!!!
02-17-14 Delivered!!!!!!!!!!
Ka Razy is offline
