Old 03-15-2014, 02:17 PM   #1
john suntato
Drives: 2014 stingray
C7 GLASS ROOF PANEL
IS THE C7 GLASS ROOF PANEL PAINTABLE ?????
john suntato is offline
Old 03-15-2014, 04:12 PM   #2
hawkfe
Drives: 2014 Stingray 3LT
I guess anything can be painted but why?
hawkfe is offline
Old 03-15-2014, 04:26 PM   #3
purpleRac3r
purpleRac3r's Avatar
I could see painting the edges in the same way the exposed carbon roof has it. It would be one way to differentiate your car from the others.
purpleRac3r is offline
Old 03-16-2014, 10:30 AM   #4
john suntato
MY 2014 IS ON ORDER AND I OPTED FOR THE GLASS ROOF,NOT THE BLACK CARBON FIBER. I AM NOT TOO EXCITED ABOUT THE EXTERIOR LOOK OR HOW MUCH LIGHT WILL ACTUALLY COME THROUGH. THAT BEING SAID, I CAN'T CHANGE MY ORDER TO A COLOR MATCHING PANEL AND THER IS NO PRESENT WAY OF ORDERING A COLORED ROOF PANEL ASSY. I BELIEVE THE ONLY WAY IT CAN BE ORDERED IS AN UNPAINTED PANEL WITH ALL THE NECESSARY GASKETS, CLAMPS ETC. TO BE ASSEMBLED AND PAINTED BY THE DEALER. ONE ESTIMATE WAS $6.800. SO, I THOUGHT MAYBE I COULD HAVE MY GLASS ROOF (LEXAN) PAINTED. NOT AN EASY TASK. THE BLACK CARBON FIBER ROOF HAS COLORED SIDES JUST OVER THE SIDE WINDOWS WHEREAS MY SMOKED GLASS ROOF PANEL RUNS FROM SIDE TO SIDE.
Old 03-16-2014, 03:28 PM   #5
purpleRac3r
It would be easiest to give it a little time and see if someone on the forum or locally with the same color car would be up for a trade: their oainted top for your transparent one. Or hold out a bit for the aftermarket to come out with a sun shade for the C7. They have shades that just pop in for all the earlier Corvettes, so it shouldn't be much of a wait for the c7 version.
Old 03-16-2014, 07:07 PM   #6
john suntato
THANKS. I AM AWARE OF THE SUN SHADES WHICH WILL BE MY LAST RESORT. I STILL REALLY FEEL I WILL NOT LIKE THE OUTSIDE APPEARANCE OF THE GLASS ROOF. I THINK IT INTERRUPTS THE LINES. THIS IS A GREAT FORRUM.
Old 03-16-2014, 08:24 PM   #7
jashobbsie
Davenport Stage 5+
jashobbsie's Avatar
Drives: Camaro ZL1 & C7 Corvette 3LT Z51
I got two roofs with mine…clear/black tint and exposed carbon fiber… but mine has the torch red sides to match the exterior paint…
Davenport Motorsports stage 5+ 2013 ZL1 Camaro
Victory Red Auto
jashobbsie is offline
Old 03-16-2014, 08:42 PM   #8
Stingray
just can't get enough
Stingray's Avatar
I can relate... I have the body-colored cf roof which blends/flows with the painted body lines well, but I also have the transparent roof since I also like the full see-through view from inside especially in the evenings. Hopefully you can find a body-colored roof to purchase or swap. GL!
Stingray is offline
Old 03-17-2014, 02:01 AM   #9
REVVIC
Drives: 2014 Z51 Velocity Yellow
The clear roof is paintable. I got an estimate of $300.00 to paint yellow stripes as are on the exposed carbon fiber option. This would be the best of both worlds if you like transparency and the esthetic of the body color on the roof edges. I'm thinking about this down the line.
REVVIC is offline
Old 03-17-2014, 09:33 AM   #10
john suntato
PLEASE CORRECT ME IF I'M WRONG, BUT I THOUGHT THERE ARE 3 DIFFERENT ROOFS AVAILABLE. THE BODY COLOR MATCH, WHICH I BELIEVE IS CARBON FIBER. THE BLACK CARBON FIBER WHICH IS NOT SEE THROUGH AND HAS BODY COLORED SIDE RAILS. THE BLUE/BLACK SMOKE CLEAR GLASS WHICH IS SEE THROUGH AND IS WHAT I HAVE ORDERED. I WOULD BE INTERESTED IN PAINTING THE ENTIRE GLASS ROOF THAT I AM GETTING. IS IT POSSIBEL THAT LATER DOWN THE ROAD, AN AFTER MARKET MFG. WOULD BE SUPPLYING THESE ROOFS ?
Old 03-17-2014, 10:28 AM   #11
purpleRac3r
You are correct, those are the 3 roofs available. While possible, it's unlikely anyone in the aftermarket will make a plain, painted top for the C7. No one does for any of the earlier generations so I would be surprised if they start now. If I were in your situation, I would take the car as ordered, and patiently keep an eye on the various forums, eBay, etc. for a gently used painted top. There are already a number of wrecks out there, so it should be relatively easy to locate a painted top, even if it needs to be painted to match your color. The transparent top will be worth far more as-is, unpainted, especially in a few years when people start wanting to replace their scratched or cracked tops.
Old 03-17-2014, 11:40 AM   #12
john suntato
HEY PURPLERAC3R, THANKS FOR YOUR INPUT. I SADLY MUST AGREE WITH YOU 100%. I GUESS IT'S TIME TO JUST GET EXCITED ABOUT THE ONE ON ORDER.
Old 03-17-2014, 12:01 PM   #13
Buzzardz_vette
Remove Before Flight
Buzzardz_vette's Avatar
Drives: 2014 Cpe Z51 2LT Torch Red
As a temporary fix, get some carbon fiber vinyl wrap like DiNoc and cover the glass. That way you can peel it off when you want to.
Z51, 2LT, 7-speed, Torch Red, Adrenaline Red, Red Calipers, Carbon Fiber Dash, Magnetic Selective, MyLink Nav, Black Wheels, Performance Exhaust, and Corvette Museum Delivery
Buzzardz_vette is offline
Old 03-17-2014, 02:28 PM   #14
john suntato
very interesting !!!!!!!!!
