Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 02-26-2014, 10:40 PM   #1
dustyr
dustyr's Avatar
Drives: 2013 Camaro 2LT convert
modification vs warranty
I have a 2013 2LT convert that is all most a year old. When I wake it up this spring,I like to do some mods.
1 Cold Air Inductions Intake
2 Solo v6 Mach X exhaust
3 Elite 1 catch can
Will any of these mods void the warranty.
I just want it to sound a little deeper,and is there any think else I should consider.
I am in my 60's and not looking to go nuts.
http://www.camaro5.com/forums/images/smilies/thanks.gif
dustyr is offline   Reply With Quote
Old 02-26-2014, 11:00 PM   #2
BigBlock69RS
Ed
BigBlock69RS's Avatar
Drives: 2013 AGM Camaro 2SS/RS/1LE
Good read:
Will this modification void my warranty?
http://www.camaro5.com/forums/showthread.php?t=267574
BigBlock69RS is offline   Reply With Quote
Old 02-26-2014, 11:23 PM   #3
bionick
bionick's Avatar
Drives: 2010 2SS/RS M6
Mods don't necessarily void your warranty.. Basically from what I have read/been told is that the certain aftermarket part will not be covered and any other parts that failed due to that aftermarket part.
If all you are doing is an intake, catch can, and cat back exhaust, I would not worry about your warranty at all.
I've never heard of any person who has had any mechanical problems due to aftermarket exhaust and intake. But like I said, the warranted service would only be voided if they can prove your aftermarket part caused the problem.
Refer to the "magnuson moss act"
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
bionick is offline   Reply With Quote
Old 02-26-2014, 11:25 PM   #4
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
None of those should void your warranty
Old 02-26-2014, 11:34 PM   #5
ka`mayor-oh
ka`mayor-oh's Avatar
Drives: 2013 LS M6
yeah, you should be perfectly fine with the mods you listed.
ka`mayor-oh is offline   Reply With Quote
Old 02-26-2014, 11:50 PM   #6
PlainEnvelopes
PlainEnvelopes's Avatar
Drives: 2014 1LS BRM
Just depends on what you take your car into the dealership for. For example, if your MAF sensor is causing a problem and you have an intake some dealerships would want to try and blame it on the intake so that it does not have to be covered under warranty. They could try and say the extra air flow made your MAF go out.
Mods: MRT V2 Exhaust, CAI Intake, BMR Strut Tower Brace, Vmaxx PTB, Elite Catch can
Next Mod:SOLO HFC, Lowering springs
PlainEnvelopes is offline   Reply With Quote
