Old 01-28-2014, 05:47 PM   #1
mikeyg36
Drives: 2015 Z/28 #533
Controlling AFM on the C7
I was looking at some of the information on the C7 and some places were saying that AFM doesn't kick in in the Sport or Track modes, but on the Chevy site is says that AFM is "normal" when in track mode. Can anyone confirm which is correct?
The list can be seen here about halfway down: http://www.chevrolet.com/corvette-stingray.html
mikeyg36 is offline
Old 01-28-2014, 05:58 PM   #2
GB EB
GB EB's Avatar
Drives: 2014 Stingray 2LT/Z51
Page 9-40 of your owner's manual will answer your question.
EDIT: not really.... I guess we need to know what "normal" and "eco" differences are...
this may help:
http://www.digitaltrends.com/cars/46...he-impossible/
and here is more info:
"AFM is easily deactivated. It only works when you select Eco mode. When the auto is in manual mode it doesn't work either. AFM only activates at very low throttle and is hardly noticeable."
*CAMARO5 CAMARO OF THE WEEK 3/21/11*
*1ST PLACE - NAVAL STATION SAN DIEGO CAR SHOW 4/17/11*
*PEOPLE'S CHOICE AWARD - SAN DIEGO FREEDOM FESTIVAL CAR SHOW 7/4/11*
*TROPHY RECIPIENT - GREATEST SHOW ON TURF 9/11/11*
*1ST PLACE MODERN MUSCLE - CORONADO SPEED FESTIVAL 9/23/11*
*AWARD OF EXCELLENCE - GOOD GUYS DEL MAR FALL NATIONALS 11/27/11*
*1ST PLACE / '82&UP CAMARO/FIREBIRD- FORT WALTON BEACH FF SHOW 2/16/13*
BUILD THREAD: http://www.camaro5.com/forums/showthread.php?t=120353
GB EB is offline
Old 01-28-2014, 06:23 PM   #3
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
yup - much of what is written in manuls about AFM, exhaust settinfgs and other things are incomplete
AFM is as simple as this:
1. it will never work at all on a 7 speed unless you are in ECO mode
2. It works in ALL modes on the auto trans UNLESS YOU USE THE PADDLES OR GO TO MANUAL IN ANY MODE..
To watch it work - find your fuel range display and watch the v4/v8 boxes:
Glen e is offline
Old 01-28-2014, 06:40 PM   #4
mikeyg36
Okay sounds good, thanks guys. I don't have one yet, but I wanted to make sure there was a way to shut it off without tuning it.
mikeyg36 is offline
Old 01-28-2014, 07:08 PM   #5
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
adam @ Range also working on a OBD module like he does with the camaros...
Glen e is offline
Old 01-28-2014, 07:11 PM   #6
GB EB
GB EB's Avatar
It was much MUCH more noticeable and a PIA on my 2011 Camaro SS so I in fact did tune it out.
I can't even tell the C7 has it.
GB EB is offline
Old 01-28-2014, 07:15 PM   #7
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
this is probably the most important post so far...I was TERRIFIED when I heard the Vette had AFM - because the AFM on the 2013 Camaro was terrible. But on the C7, unless you are watching the little v8/v4 boxes and very anal, it really is close to invisible on an automatic....
Glen e is offline
Old 01-28-2014, 09:26 PM   #8
mikeyg36
Originally Posted by Glen e View Post
this is probably the most important post so far...I was TERRIFIED when I heard the Vette had AFM - because the AFM on the 2013 Camaro was terrible. But on the C7, unless you are watching the little v8/v4 boxes and very anal, it really is invisible....
I was terrified when I heard that as well. I was happy though when I heard that track mode shuts it off, so when I saw this on the site I got worried.
mikeyg36 is offline
Old 01-28-2014, 09:33 PM   #9
Stingray
just can't get enough
Stingray's Avatar
AFM is nearly invisble on the manual (ECO mode) and what a relief! If you grip the shifter while it transitions from V8 to V4 and vice-versa, you can feel the AFM at work via mild vibrations pulsing to the shifter. Not a biggie, since the torque tube masks it quite well. Btw, you can test this out while in cruise control on a flat road by switching your Driving Mode Selector to/from Eco to Weather or Touring. You can verify this by also watching the V8/V4 icon change back & forth.
Stingray is offline
Old 01-29-2014, 06:25 AM   #10
Pete r welch
There is noticable vibration in AFM in the shifter on my 7 speed manual. Not terroble but easily recognizable. Every one else too?
Pete r welch is offline
Old 01-29-2014, 08:29 AM   #11
Stingray
Stingray's Avatar
Yup the inherent side-effect of AFM... it's not that bad on mine. I can clearly feel/notice when I hold the shifter firmly as it transitions to/fro V4. I hardly drive in Eco mode anyway so again no biggie. Be glad it's not even close to the Camaro SS with the L99. Now that's effin annoying... Range solved it for me since March of last year. So glad I was one of the first/early adopters and no issues since; V8 all the time when plugged.
Stingray is offline
Old 01-29-2014, 08:57 AM   #12
Hulkamaniac
Livin' the Dream
Hulkamaniac's Avatar
I've had AFM in my '06, '07 Monte Carlo SS's and in my '11 Camaro SS.
I loved it! Great mileage and power when I needed it.
Unless I was watching the tach, I never knew when it was cruising on 4 or 8 cylinders.
Hulkamaniac is offline
Old 01-29-2014, 03:43 PM   #13
Schlok
Schlok's Avatar
Drives: 2015 Z/28 #397 2022 ZL1 #1799
Yep, I can totally tell when it goes from V4 to V8 and vice versa, oh well...
Schlok is offline
Old 01-31-2014, 04:28 PM   #14
binko
Drives: Honda Accord
Having driven my 7 speed for a little over 1000 miles now, I agree that you will certainly notice when it engages with the engine under 1300 RPMs. At 65 MPH in 7th gear, the engine is turning approx 1300 RPMs. This is the minimum speed you want to be at with AFM, otherwise the droning is too invasive and I question what effect the constant vibration that you feel thru the car and especially on the shift lever will have on long term wear. Don't get me wrong, it does work and it is a good fuel saving feature, however you need to select your gear to keep the RPMs above 1300 for the desired speed. Perhaps on automatics, the torque converter can absorb the vibrations that the manual can't.
binko is offline
