Old 01-24-2014, 11:50 PM   #1
Kim
Drives: 2014 Torch Red Z51
Noises when cold
I'm wondering if anyone is hearing the same things I am. When I first start the engine and am just in the first 5 miles from home, I'm hearing sounds I can describe as something between a click and a chirp. I've turned the stereo off and fan down so I know it's not coming from those areas. I'm also getting the clock on the main screen for five seconds at a time then it switches to whatever Screen I happen to be using. I've got a service appt. but would like to hear from anyone having the same issues.
Kim is offline
Old 01-25-2014, 07:44 AM   #2
pancho
Drives: hope a new c7 stingray
perhaps a Bomb?
pancho is offline
Old 01-25-2014, 08:14 AM   #3
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
check your batt voltage when your engine is off...anything less than 12.0 will yield false phantom alerts and odd behavior from the electronics......
Glen e is offline
Old 01-26-2014, 01:43 AM   #4
C7Driver
C7Driver's Avatar
Drives: 2014 Z51 Lime Rock Green
Direct injection engine tends to produce a little more noise then non direct injection. You can expect a little more valve train noise in cold weather which should fade as the engine warms up.
C7Driver is offline
Old 01-26-2014, 11:05 AM   #5
weaponX
I'm your pusher!
weaponX's Avatar
Drives: 2014 Stingray, 1000HP CTS V, 06 H2
do you have a z51 model? dry sump takes longer for the oil to warm up.
weaponX is offline
Old 01-27-2014, 11:08 PM   #6
Jay_Levine
Drives: 2014 Corvette
I have noticed a lot of engine noise when it is a cold start. This is Florida so outside temp does not really come into play.. As soon as it is warm, it stops
Jay
Jay_Levine is offline
