Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > Wheels | Tires | Suspension | Brakes
Old 01-18-2014, 09:49 PM   #1
weaponX
I'm your pusher!
weaponX's Avatar
Drives: 2014 Stingray, 1000HP CTS V, 06 H2
Light weight Racing Brakes coming soon!
I have these 2pc light weight rotors on my CTS V and I'm pleased to announce that Racing Brake will be making these for the Stingray and Stingray Z51 models as well! Weapon X Motorsports will be the exclusive vendor for these rotors for the next few months as we work through this with them! They're also working on forged calipers 6f/4r for a complete system! We're looking for a C7 in the Orange County/LA area to complete the development on those as well, so if you're out that way, send me a PM and I'll get you connected!
They're a very quality 2 piece brake rotor, have true replacement rings, and saved about 10lbs of rotating mass over the standard C7 Z51 brakes.
The stock rotor weights are in!
Front two piece:
Dimension: OE=345x30mm
Weight: OE=20 lbs
Rear two piece:
Dimension: OE=340x26mm
Weight: OE=18 lbs
__________________________________________________ _______________________________________
Racing Brake rotors are in design now, but expected results for you track guys already look good!
Front two piece:
Dimension: RB=340x31mm (1mm thicker)
Weight: RB=16.5 lbs (projected)
Rear two piece:
Dimension: RB=340x26mm
Total rotational weight savings are nearly 10lbs projected! That is a lot of weight for already light weight rotors when you take into account inertia and rotational mass!
weaponX is offline
Old 11-25-2014, 09:59 AM   #2
duckman714
Drives: Laguna Blue C7
Any updates on release dates for non-Z51?
duckman714 is offline
Old 06-02-2015, 12:07 AM   #3
A_DILLA
Optimus Prime
A_DILLA's Avatar
Drives: Camaro ZLS [COTW 09/22/14]
How about for the camaro
A_DILLA is offline
c7 racing brakes, c7 rotors, weaponx
