Old 01-15-2014, 05:55 AM   #1
tc Bosnian
tc Bosnian's Avatar
Drives: 09 a4 1500 silverado 2010 2ss rs
Car doesn't want to start when cold
Hello, I have a 00 Ford Focus. I bought the vehicle last summer/fall and had no issues with it starting until it got cold outside. When the car is in the garage it starts right up. I work 12 hour shifts and thats when I noticed that it doesn't want to start up. What could it be? There is no lights on the dashboard.
tc Bosnian is offline   Reply With Quote
Old 01-15-2014, 12:14 PM   #2
tc Bosnian
tc Bosnian's Avatar
Anyone?
Old 01-15-2014, 12:42 PM   #3
HeavyIOM
HeavyIOM's Avatar
Drives: 2010 SS, 2000 Pontiac Formula
Is the battery any good? Check your terminals as well.
HeavyIOM is offline   Reply With Quote
Old 01-15-2014, 12:51 PM   #4
tc Bosnian
tc Bosnian's Avatar
Battery was bought right before the winter.
Old 01-15-2014, 12:57 PM   #5
ShnOmac
Does it seem to crank slower when its cold than when its warm?
Old 01-15-2014, 01:06 PM   #6
tc Bosnian
tc Bosnian's Avatar
When its warm it will start right up with no issues. When I'm at home the car is in the garage so going to work I dont have issues. Now when I'm at work and leaving it takes forever to start. It cranks pretty strong but won't turn over.
I've also noticed that the heat isn't the greatest. So maybe it's a thermostat that's causing lack of heat? The car takes forever to warm up..
Old 01-15-2014, 01:08 PM   #7
Scalded Dog
Scalded Dog's Avatar
Drives: 2011 1LT
Define "doesn't want to start up:" Does it turn over, but not fire... or does it not turn over? Does it make any funny noises, or do anything else that's odd?
Has it only happened in the wake of the ridiculous cold Indiana--- and much of the midwest--- experienced over the past couple of weeks, or does it misbehave in "normal" cold weather, too?
Scalded Dog is offline   Reply With Quote
Old 01-15-2014, 01:11 PM   #8
Scalded Dog
Drives: 2011 1LT
Yikes! Check your radiator... when you run out of coolant, the heater stops working... often by working less and less efficiently, as the coolant slowly disappears. This COULD be a cause of your hard starts, too, if coolant is low, and might be causing other problems... also, is your coolant a good blend of anti-freeze... or is is diluted, or even straight water (yes, I'be done it in a pinch)?
Old 01-15-2014, 01:12 PM   #9
tc Bosnian
tc Bosnian's Avatar
Its happening in the normal cold weather. As of this morning it was in mid 20s. Which isn't that bad actually < you know you're from a cold state when mid 20s isn't bad.
No funny noises are made it will crank but won't turn over. This morning I trying for 15 minutes before it finally fired up.
Old 01-15-2014, 01:12 PM   #10
Scalded Dog
Drives: 2011 1LT
(The heater works by taking the hot water circulating through the engine and radiator, and using it to heat the air that blows into the cabin... when the water in the radiator runs low--- or out--- there's no more hot water to heat the air for the cabin...)
Old 01-15-2014, 01:15 PM   #11
Scalded Dog
Drives: 2011 1LT
Long shot, maybe somebody more of an expert on viscousity will weigh in: I wonder if the oil you have in it might be too thick, and in cold weather it gets so "thick" that it inhibits starting? Do you know what viscousity you've got in it now?
Old 01-15-2014, 01:15 PM   #12
tc Bosnian
tc Bosnian's Avatar
Here recently I did add 50/50 mix of antifreeze. Even after adding it I'm still having issues.
Old 01-15-2014, 01:21 PM   #13
Scalded Dog
Drives: 2011 1LT
Not to nitpick, but... did you add the antifreeze because it had been leaking, or was low? Have you checked it even more recently, to ensure that the radiator is STILL full? Just trying to cover bases here...
Old 01-15-2014, 01:23 PM   #14
tc Bosnian
tc Bosnian's Avatar
You're not nitpicking.
I have noticed a leak just haven't had a chance to look what exactly it is. Its a small leak. This morning when I was trying to start I did look and it was just under the "Max" level.
