Old 12-08-2013, 05:07 PM   #1
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
Magnetic Jack pads for the Corvette
We have the jack pads for the new corvette also the C5 and C6
www.zl1addons.com
Skylane765 is offline
Old 12-08-2013, 05:41 PM   #2
purpleRac3r
purpleRac3r's Avatar
These should work on the C5 & C6 as they have steel frames. Since the C7 Stingray frame is all aluminym, I will be rather surprised if the magnetic pads will work on them.
purpleRac3r is offline
Old 12-09-2013, 12:04 AM   #3
REVVIC
Drives: 2014 Z51 Velocity Yellow
Good point! Is some steel at the jack locations? Otherwise, aluminum will require the plug in pucks I've seen promoted.
REVVIC is offline
Old 12-09-2013, 07:03 AM   #4
Bolt-onC6
Drives: 2017 Corvette
My Z06 has a steel plate bolted inside the aluminum frame. I would assume the C7 somewhat the same.
Bolt-onC6 is offline
