Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > Wheels | Tires | Suspension | Brakes
Old 11-22-2013, 09:05 PM   #1
GunnyG
Da WHALE
GunnyG's Avatar
Drives: 2014 Stingray, 2015 Panamera 4
Went Ahead and Plasti-dipped
For $34 for 4 cans + 1 can glossifier, I went ahead and did the plasti-dip thing. Turned out pretty good, but it has some "do over" spots. I'll touch them up later.
Before:
After:
Project MantaRay...Underway
GunnyG is offline
Old 11-22-2013, 09:23 PM   #2
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
That looks outstanding! In my personal opinion, these C7's *require* black wheels to look truly gorgeous. Well done, Gunny!
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline
Old 11-22-2013, 09:32 PM   #3
GunnyG
Da WHALE
GunnyG's Avatar
Thank you! Yeah, my original order would have had black wheels, but I got this one as a dealer stock when the Z51 constraint was on. So, I sacrificed black wheels and Nav. Got the black wheels taken care of…now if someone in the aftermarket would just figure out to add Nav I'd be set.
GunnyG is offline
Old 11-30-2013, 01:19 PM   #4
DocHolliday
DocHolliday's Avatar
Drives: '14 Blade Silver Z51
Did you remove the wheels to spray them G?
Say When
DocHolliday is offline
Old 12-02-2013, 11:56 PM   #5
GunnyG
Da WHALE
GunnyG's Avatar
Doc, no I bagged off the rotors and calipers. That really inhibits you from being able to spray them well. But, I didn't have a lift or time. The inside is still the painted silver too. I figure the brake dust will take care of that. LoL! This is just a temporary solution until I can settle on the wheels I want. Most likely will be a set of HRE's…but this'll do for now.
GunnyG is offline
Old 12-12-2013, 01:15 AM   #6
thestingray
Drives: Stingray
Plastidipping can be a long term option too, correct?
thestingray is offline
Old 12-12-2013, 01:36 AM   #7
H2OStingray
H2OStingray's Avatar
Drives: 2014 Red/Red Z51 3LT
Looks good Gunny, next time if you take the wheels off and put playing cards in between the gap of the tire and rim and lay them flat you may get even better results.
H2OStingray is offline
Old 12-12-2013, 10:31 AM   #8
GunnyG
Da WHALE
GunnyG's Avatar
I'm sure it will last for a long time. I plan on changing my wheels whenever more aftermarket styles are released. The only issue I see long term is having to reapply coats as the wheel scuffs. No real problem there though.
Thanks! I could have done a lot better job with a better facility. Just did this in my garage, no lift in a couple hours. So far I've gotten nothing but compliments. Even with some spots that need touch up.
GunnyG is offline
Old 12-13-2013, 01:39 PM   #9
1KUIKC7
1KUIKC7's Avatar
Drives: 2015 Zo6 3zl
Looks great on a black car!!
1KUIKC7 is offline
Old 12-13-2013, 02:43 PM   #10
Overflow
Space Shuttle Aficionado
Drives: 2016 Camaro 2SS
You'll get easy damages with the dip. If you have to change your wheels, (balancing, rotating, etc) they'll get scuffed. Also if a little part of it starts coming off, if you don't catch it soon enough, the motion from the wheels will start to peel the dip off itself.
Always have a can or two handy for repairs.
Overflow is offline
Old 12-13-2013, 08:33 PM   #11
GunnyG
Da WHALE
GunnyG's Avatar
Thank you! I'm happy with the way it turned out.
Great advice. I have an extra can for just that reason... I know I'll need to touch up at some point. I don't see having to scuff the lugnuts anytime soon with taking the wheels off, but I know that'll happen.
GunnyG is offline
Old 12-13-2013, 09:20 PM   #12
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
plastidip should be fixed with their PD solvent they sell...see the vids at dipyourcar.com to use it....
Glen e is offline
Old 12-16-2013, 06:54 PM   #13
ActNup NY
ActNup NY's Avatar
Drives: 2011 1LT Black Camaro
Looks good G !!! Beautiful car man Is the window tinted?
The DREAM is free... It's the HUSTLE that is sold seperately
ActNup NY is offline
Old 12-16-2013, 08:42 PM   #14
GunnyG
Da WHALE
GunnyG's Avatar
Thanks! No I haven't tinted my windows yet. I will though.
GunnyG is offline
