Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > LT1 (6.2L V8) Powertrain and Drivetrain Discussions
Old 11-19-2013, 09:14 AM   #1
Richardlord
Drives: Dodge Magnum RT Hemi AWD
Computer Aided Gear Selection (CAGS)
Has anyone defeated the the C7 7-speed Computer Aided Gear Selection (CAGS) either by adding a Skip Shift Eliminator or removing a fuse as some have reported they did on Corvettes past?
Richardlord is offline
Old 11-19-2013, 03:31 PM   #2
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
Skip shift is one way, another way is to simply add gas . This is never an issue in my Camaro.
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline
Old 11-19-2013, 03:33 PM   #3
S3XPanther
by Odeon
S3XPanther's Avatar
Just to be clear, it only forces you into 4th if you're going really slow. Just rev out first a little more and it's a non-issue really.
Old 11-20-2013, 08:06 PM   #4
purpleRac3r
purpleRac3r's Avatar
True, but it can be aggravating in stop & go traffic, where a little more gas isn't always an option, or wise. Pulling a fuse or disconnecting the harness at the transmission will nor work, as it sets trouble codes. However, I have seen that a couple of companies are working on the eliminator gadget. They are currently testing prototypes to make sure they don't cause unwanted side issues. Should be available soon! I for one will absolutely be getting one!
purpleRac3r is offline
Old 12-27-2013, 10:27 AM   #5
Piccione Performance
Piccione Performance's Avatar
Drives: 2010 2ss/rs & 2014 Stingray
We are able to turn it off using HP Tuners software when we tune a car. If your looking to tune your car to get more out of it ask your tuner to turn it off.
Piccione Performance is offline
Old 01-14-2014, 11:20 AM   #6
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
We have a Skip Shift Eliminator available for the C7. Check the vendor sales section or our website for more info.
Originally Posted by Pete43 View Post
I installed Apex's skip shift eliminator. It works great!
Apex Motorsports is offline
Old 01-14-2014, 04:24 PM   #7
binko
Drives: Honda Accord
I just installed the Apex skip shift eliminator on my C7. it works fine. It's a real easy install. I have a post under general discussions on how to do it.
binko is offline
Old 02-07-2014, 10:37 AM   #8
Apex Motorsports
Thank you for your order.
Old 01-24-2015, 08:17 AM   #9
Dave Powell
Drives: 2014 Stingray
My C7 is an A6, but I disabled the skip shift in my C4, C5, and C6 easily. You can buy the $20 kit, which makes it neat, but all it consists of is a resistor across the two-wire connector on the cable. I used a 1500 ohm 2 watt on one. It can be 1/4 watt but the larger leads on the two watt can plug into the connector, which you then tape up along with the open tranny connector.
The computer checks for continuity of the solenoid to ensure that it is not disconnected. The resistor tells it all is well so it won't set a code and check engine light.
Dave Powell is offline
