Old 11-15-2013, 05:29 PM   #1
S3XPanther
by Odeon
S3XPanther's Avatar
Drives: '12 SS/RS A6 IOM SOLD, '13 1LE IOM
Question about Z51 on all trims
Does the aluminum frame designated for the Z51 package available for every trim or just 1LT? There's some confusion on the chevy site regarding this.
EDIT: read somewhere that even non-Z51 cars have an aluminum frame. Please clarify.
"It works 60% of the time, every time."
"Some say it's a waste of time, others say it's an incredible waste of time."
"The ultimate measure of a man is not where he stands in moments of comfort and convenience, but where he stands at times of challenge and controversy."
2013 IOM SS/RS - 1LE. Born 5/6/2013 (1 of 32 1SS IOM 1LE's)
S3XPanther is offline
Old 11-15-2013, 05:34 PM   #2
Stingray
just can't get enough
Stingray's Avatar
Aluminum frame? If you mean by the chassis (frame) then 100% of C7's are constructed of aluminum frame, Z51 or not. The Z51 package is more suspension & handling oriented unrelated to inclusion or exclusion of an aluminum frame.
Where did you see this on the Chevy site? Maybe I'm misinterpreting your reference of 'aluminum frame'?
Stingray is offline
Old 11-15-2013, 05:36 PM   #3
S3XPanther
by Odeon
S3XPanther's Avatar
Right here in the models and specs section:
http://www.chevrolet.com/corvette-st...ecs/trims.html
It made reference to an aluminum "frame structure" only under the Z51 1LT section.
But, you did answer my question. That is, all C7's have an aluminum chassis. Thanks
Old 11-15-2013, 05:43 PM   #4
S3XPanther
by Odeon
S3XPanther's Avatar
In addition, the chevy site called the 1LT the "lightest" trim, thus it prompted me to believe that the 1LT w/Z51 had a different construction. My mistake.
Old 11-15-2013, 05:49 PM   #5
Stingray
Stingray's Avatar
Oh I see...where it can be a bit misleading. But in any case, the two higher trim levels includes 1LT... so technically it's applicable to all models. In terms of lightness (weight), obviously the 1LT is lighter since it has lesser weight-adding components.
Stingray is offline
