Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > In Car Electronics (NAV, Audio, Entertainment, Gauges, etc.)
Old 11-14-2013, 11:52 PM   #1
REVVIC
Drives: 2014 Z51 Velocity Yellow
Center Screen Failure
Two days ago as I shifted out of reverse (manual) my screen became a sea of gray pixels. I still had bluetooth connection. I restarted the car. Left screen fine, center stack one, gray pixels. Got home, left two hours later. Upon ignition, left screen was as usual with the booting dance of graphics. Center one nothing then suddenly back to normal!! It's been fine for a few days. Chevy service rep said not to bring in till it fails. Has this happened to any of you?
REVVIC is offline
Old 11-15-2013, 03:54 PM   #2
urr2slo
urr2slo's Avatar
Drives: 2010 2ss ss/rs abm, 2016 2ss/rs hbm
Im starting to have the same problem. I'm waiting for it to fail more consistently. So far no TSB's on it.
Some days its fine, others it acts up.
URR2SLO - If you're not going fast enough, get out the way......
urr2slo is offline
Old 11-15-2013, 04:36 PM   #3
Stingray
just can't get enough
Stingray's Avatar
Sahowley also had center screen probs... reworked bezel supposedly cured it. Perhaps similar issues?
http://www.corvette7.com/forums/showthread.php?t=323454
Stingray is offline
Old 11-15-2013, 04:48 PM   #4
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
I was at my dealer today and was talking about the new C7 with the service advisor and he said they have had a couple right off the truck with a similar problem you describe. He said GM is looking into the problem. He also said there have been other bugs in them...
The Bird is the word!
Angrybird 12 is offline
Old 11-15-2013, 11:44 PM   #5
REVVIC
Thanks for the response. These bugs are inevitable. That's what the warranty is about. Otherwise, it's an awsome car.
REVVIC is offline
Old 01-02-2014, 10:29 AM   #6
tghamm
Drives: 2014 Corvette
I am having a problem with my video screen flickering on and off. It does this intermittently. It happens for a couple of days then will be fine for a couple of days. Nothing in area behind screen so that doesn't appear to be the problem. I plan on taking in to dealer next week but just wanted to see if anyone else was having the same issue. Other than the dash dimming issue (apprently fixed with a software update) and a rattle under the console the car has been flawless for the first 3k miles. My VIN is 643 so one of the earlier ones.
tghamm is offline
Old 01-02-2014, 10:58 AM   #7
GunnyG
Da WHALE
GunnyG's Avatar
Drives: 2014 Stingray, 2015 Panamera 4
Same thing happened to me this morning...
Project MantaRay...Underway
GunnyG is offline
Old 01-02-2014, 11:04 AM   #8
zimm888
zimm888's Avatar
Drives: 2014 Stingray Z51
Is there any confirmed info on a screen replacement? I heard chatter about possibly jan-feb, any of that true?
Tghamm, what is the cause of your rattle under the console? Fixable yet?
zimm888 is offline
Old 01-02-2014, 01:21 PM   #9
tghamm
Don't know yet. Due to take in to dealer next week. You have same problem?
tghamm is offline
Old 01-02-2014, 01:23 PM   #10
tghamm
Are you talkinmg about the screen flickering?
tghamm is offline
Old 01-02-2014, 03:57 PM   #11
GunnyG
Da WHALE
GunnyG's Avatar
Yes! Went completely black, then flickered, then came and stayed on. Maybe software issue ...VIN 3563
GunnyG is offline
Old 01-02-2014, 07:49 PM   #12
zimm888
zimm888's Avatar
Sry can't say I do. My TPW is this week, just trying to be proactive if I run into these issues. I'll have a better idea what they are and their possible fixes.
zimm888 is offline
Old 01-03-2014, 12:23 AM   #13
bnall40
Drives: Z51 3LT, 2009 Pilot, 2012 Ody Tours
I did not have the problem described ... But what I did have was a radio/Nav screen that was not responsive to the touch ... It was replaced.
bnall40 is offline
Old 01-03-2014, 08:10 AM   #14
purpleRac3r
purpleRac3r's Avatar
Well, I experienced the clicking and screen switching randomly for the first time this morning. I noted a couple of things. First, the clicking is the same sound you hear when switching between screens by touching the screen icons. It is not a mechanical click such as a relay or metal on metal contact would make. Second, the screen does not break up and pixelate, like it would if the issue were electronic interference. Third, this was by far the coldest morning yet since I got the car, at -1 degree F. This leads me to believe the problem is not necessarily the screen failing. I suspect its an issue of either a connection that becomes loose with temperature change or perhaps a cold bezel or mount that changes shape just enough to put stress on the touch screen. This stress is then "tricking" the screen into thinking an icon has been pressed when in reality it has not. And if the stress continues, it can act like the screen has been touched continuously, and cause repeated screen switching and clicking. Lowering the screen appears to be removing this stress, allowing the touch screen to catch its breath so to speak, and that's why the clicking stops.
This seems to be the most likely issue, as the person above stated the dealer shimmed the bezel and fixed it on that car. I will see what happens when I leave the office for lunch. Its supposed to warm into the low 20s by then. I suspect I will have no screen issues.
purpleRac3r is offline
