Old 11-05-2013, 07:13 AM   #1
GQ4Life
Drives: 2010 Camaro SS LS3
Tire temp monitor a waste lol
It never showed cold even when tires temp was 36 degrees. Now that the outside temp is 27 degrees & tires r the same.. In the morning it showed cold tires & showed cold for the whole 7 mile drive. I get out check tire temp with my IR temp sensor & it shows tire is 77 degrees.
Seems like it goes by outside temp. Or only resets when u shut off the car
Sent From The Q on the Galaxy S4
2015 Corvette Z06.. Lime Rock Park 1:01; Watkins Glen 2:14; Thompson Speedway 1:21
GQ4Life is offline
Old 11-05-2013, 07:43 AM   #2
Stingray
just can't get enough
Stingray's Avatar
IIRC, doesn't it calculate via algorothim?
Hard for me to monitor changes down here where I am since it's always warm or hot outside!
Stingray is offline
Old 11-05-2013, 11:33 AM   #3
GQ4Life
Algorithm is off lol. Found it weird... When I got car back from service & started it. It showed tires warm & stayed warm even though tires were now colder then when I arrived..
GM said calculates from TPM sensor microchip temp, IAT, Coolant temp, & outside air temp..
GQ4Life is offline
Old 11-05-2013, 12:20 PM   #4
Stingray
Stingray's Avatar
Sounds like the engineers, metrologists, or whatever team who worked on the algorithms must have been too busy watching Nurburgring lap vids... always warm/hot!
Stingray is offline
Old 11-05-2013, 01:12 PM   #5
GQ4Life
LMAO
GQ4Life is offline
Old 11-07-2013, 12:21 AM   #6
SCM_Crash
SCM_Crash's Avatar
Drives: 2014 Z51 3LT
Mine never changes at all.
1997 Formula Firebird
2002 Trans Am WS.6
1990 Z32 300zx
2002 Corvette Z06
2003 Corvette Z06
2014 Corvette Z51
SCM_Crash is offline
Old 11-07-2013, 06:15 AM   #7
GQ4Life
Only shows cold under 32°.. doesnt seem to change temp till car is shut off & turned back on.
Im sure Hot wont display till tire over 160° & car is shut off & turned back on. GM was no help I gave up.
GQ4Life is offline
Old 11-08-2013, 02:35 AM   #8
SCM_Crash
SCM_Crash's Avatar
Yep. Haven't noticed the temp change in nearly 1300 miles. No idea what to make of it other than the sensors aren't getting refreshed until startup.
2002 Trans Am WS.6
1990 Z32 300zx
2002 Corvette Z06
2003 Corvette Z06
2014 Corvette Z51
