Old 07-16-2009, 12:16 AM   #1
CamaroGT
CamaroGT's Avatar
Drives: Chevy
Shaker Rig Testing
VIPER's custom-designed 8-post test rig represents the next generation of suspension testing equipment. It has several advantages over today's 7-post rigs.
Body actuators are pneumatic instead of hydraulic. This reduces the force feedback (in the actuators) caused by body motions, so inertial and aerodynamic forces are applied to the vehicle body more accurately.
The addition of an eighth actuator to the traditional seven that are typically employed allows moments to be applied at both ends of the vehicle simultaneously. Applying moments at just one end (as performed by a 7-post) introduces artificial frame twist into the chassis, which in turn affects the accuracy of the loads at the tire.
8-post setup also allows kinematic and compliance measurements such as axle roll stiffness, chassis torsional rigidity, and vertical spring rate.
http://www.viperservice.com/content/view/13/21/
CamaroGT is offline   Reply With Quote
Old 07-16-2009, 12:17 AM   #2
CamaroGT
CamaroGT's Avatar
Drives: Chevy
7-Post Shaker Rig Testing
http://www.arcindy.com/index.php?main=home
Pedders Suspension Benchmark Track Testing and New Jersey Track Day Info@PeddersUSA.com USA - NY / NJ / PA 35 10-26-2009 06:20 PM
2011 Camaro Convertible continues testing down under! (spyshots) Tran Camaro Photos | Spyshots | Video | Media Gallery 112 08-27-2009 09:24 PM
2010 Camaro videos (6:00+ minutes) - testing on Nurburgring and driving near premises Tran Camaro Photos | Spyshots | Video | Media Gallery 235 01-08-2009 06:20 PM
When is the V8 going to be out for testing? Pushing_Tin 5th Gen Camaro SS LS LT General Discussions 2 10-14-2008 11:36 PM
possible 2.0t camaro mule... lakers 5th Gen Camaro SS LS LT General Discussions 30 07-26-2008 04:25 AM
