Old 07-14-2009, 05:59 PM   #1
FutureBumbleBee
Drives: 83 Z28, white, slow and dying
What exactly is a turbo?
I see a lot of cars with a turbo engine, or a twin turbo etc... and they have a ton of extra horsepower. Is a turbo like a magic box or something that adds a bunch of power? And how do they work?
FutureBumbleBee is offline
Old 07-14-2009, 06:25 PM   #2
MuscleCarz
Drives: 5.4 3v
In a nut shell, A turbo draws air from the exhaust and forces it (forced induction) in to the engine at a level higher than the normal vacuum draw of the intake(boost).
There's a lot more to turbocharging than that, but if you thought it was a "magic box", that'll be enough to get you started.
MuscleCarz is offline
Old 07-14-2009, 06:57 PM   #3
Rtoups
Rtoups's Avatar
Drives: RJT 2LT
Magic box, huh?
SoCal Camaro5 Family Member
Rtoups is offline
Old 07-14-2009, 07:00 PM   #4
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
http://auto.howstuffworks.com/turbo.htm
I piss excellence
and fart awesomeness
CamaroSpike23 is offline
Old 07-14-2009, 10:19 PM   #5
coolman
Guest
You going to have the boy all screwed up. A turbo doesn't draw air form the exhaust. It uses the exhaust gases to spin a rotor that is attached to another rotor in the inlet air side of the motor to increase airflow into the motor which allows for more fuel. This make a bigger air/ fuel charge in the cylinder thus making more power. Exhaust gases wouldn't make for very good combustion air.
coolman is offline
Old 07-14-2009, 10:39 PM   #6
fazm
Drives: ex-500hp v6 mustang
Originally Posted by coolman View Post
You going to have to boy all screwed up. A turbo doesn't draw air form the exhaust. It uses the exhaust gases to spin a rotor that is attached to another rotor in the inlet air side of the motor to increase airflow into the motor which allows for more fuel. This make a bigger air/ fuel charge in the cylinder thus making more power. Exhaust gases wouldn't make for very good combustion air.
tell that to the egr valve
fazm is offline
Old 07-14-2009, 10:46 PM   #7
coolman
Guest
That wasn't the point and besides ,the egr valve provides very little air compaired to the rest. I made the point to show him the motor is not using the exhaust gas for combution air.
coolman is offline
Old 07-14-2009, 10:50 PM   #8
MuscleCarz
Drives: 5.4 3v
That's what I meant.
Old 07-14-2009, 10:52 PM   #9
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
Spike's link is the best answer so far.
Turbo is basically a fan that spins using your exhaust. The fan blows air into your intake/engine so now your engine is compressing more air than normal. The bigger volume of air is condensed, making a bigger explosion and more power.
A super charge is basically the same thing. It's run off a belt connected to your engine to run a "fan" that blows air into your intake.
TLR
More air flow into your engine = more compression = more boom = more power.
Mindz is offline
Old 07-14-2009, 10:54 PM   #10
coolman
Guest
Hey that's cool. I just didn't want him trying to pipe exhaust gases into his new baby.
coolman is offline
Old 07-14-2009, 11:13 PM   #11
MuscleCarz
Drives: 5.4 3v
Old 07-14-2009, 11:20 PM   #12
coolman
Guest
Hey new tecnology! Sell it to toyota or honda.
coolman is offline
Old 07-15-2009, 10:27 AM   #13
MrIcky
MrIcky's Avatar
Drives: Dodge Ram Megacab & Cobalt SS
How stuff works is a great site. Good stuff to be had there.
MrIcky is offline
Old 07-16-2009, 01:52 PM   #14
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Engines mix air and fuel and burn it. The more fuel and air you burn, the more power you make. This is why large displacement engines tend to have more power but lower fuel economy (though thats not always the case). But if you have a limited displacement you are going to need to force more air into the cylinders than they would normally hold if you want any significant power gains. This is where superchargers come in. They are air pumps that feed pressurized air into the engine. A turbo charger is a type of supercharger, though when people mention a supercharger its typically in reference to a belt driven one. As others have mentioned, a turbo is driven by the exhaust gasses.
A twin turbo uses 2 turbo chargers rather than just one. On top of that, there are 2 different twin turbo configurations, but we'll save that for another day.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
DGthe3 is offline
STS Remote Mount Turbo Kit for V6 ZNOLMT Forced Induction - V6 102 06-09-2010 01:18 PM
Group Buy - Turbo Kit ZZcamaro Forced Induction 32 11-30-2009 01:52 PM
V6 Superchargers / Turbo / Twin Turbo Mohrg Beast Forced Induction - V6 25 07-10-2009 10:02 PM
Turbo on 1999 Hyundai Accent 1.5L SOHC 1986Z28 General Automotive + Other Cars Discussion 0 03-19-2009 03:37 PM
Turbocharge your way to efficiency.....and power! Mr. Wyndham Forced Induction - V8 20 07-06-2008 01:46 PM
