Old 10-07-2013, 07:38 PM   #1
Chive Driver
Keep Calm and Chive On
Chive Driver's Avatar
Drives: 2013 Camaro 2SS/RS
Top Gear turn off A/C
What does turning off the A/C do in a car?
What is the benefit? and is it really noticeable?
I hear it on Top Gear when they do the Star in Reasonably Priced car sometimes.
Chive Driver is offline   Reply With Quote
Old 10-07-2013, 07:54 PM   #2
Aequitas & Veritas
Aequitas & Veritas's Avatar
Drives: 2010 Camaro 2LT RS, 2009 GTR
Less movement under the hood, supposedly frees up more ponies. Does it add power you can tell the difference? Not to me, though I hardly use my ac since I hate hearing it running
Aequitas & Veritas is offline   Reply With Quote
Old 10-07-2013, 08:52 PM   #3
Au201
Drives: Black V6 auto 2LT RS
It makes a small difference with these more powerful engines but a huge difference in a small 4 cyl. In my cruze turbo there's an amazing difference with a/c on and off. In the Camaro I can't tell at all.
Sent from my bragging iPhone using an app that encourages it.
Au201 is offline   Reply With Quote
Old 10-07-2013, 10:16 PM   #4
Number 3
Hail to the King baby!
Number 3's Avatar
In many newer performance cars, the A/C compressor will disengage the clutch. When engaged, it is HP the engine must use to turn. Alternator is the same way.
Old 10-07-2013, 10:23 PM   #5
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Normally speaking the AC compressor is like a leach and is stealing some power from the motor. With that being said in a car with a larger motor the reduction is far less than a little 4 cylinder. I have heard people say if takes 20 Hp but to that I say
Old 10-07-2013, 11:30 PM   #6
derklug
derklug's Avatar
Drives: 12 Boss 302
Old a/c compressors used about 7hp, new models use around 5. On a 400 horse engine, this draw is like leaving your golf clubs in the trunk. On a 150 horse car, it is like having a passenger. At wide open throttle, most cars shut down the a/c compressor to get better performance, so turning it off on the Reasonably Priced Car probably doesn't make a difference.
The biggest mistakes in life come when you know exactly what you are doing.
derklug is offline   Reply With Quote
Old 10-08-2013, 12:32 AM   #7
sspolo
sspolo's Avatar
Drives: 2014 Camaro SS 1LE
I haven't noticed (or cared to feel) a difference when I have the A/C on or off on my 100hp Saturn
sspolo is offline   Reply With Quote
Old 10-08-2013, 07:26 AM   #8
dcoates18481
dcoates18481's Avatar
Drives: 2010 CAMARO RALLY YELLOW SS/RS/M6
i believe at WOT the A/C clutch is disengaged until WOT is let off.
I LIKE TO GO FAST!
Lethal Racing Night Fury Cam Kit, Melling oil pump, C5R Timing Chain, Dyno Tuned by Shawn@Lethal Racing, Vararam Tuned intake, Vararam Power Wedge, LSR Tri Ax Short throw Shifter, VMAX Ported T/B, TSP 2" L/T Headers, TSP Cat delete, Borla axle back exhaust, Innovate A/F monitor, 471.7 HP/438.8 TQ
dcoates18481 is offline   Reply With Quote
Old 10-08-2013, 06:46 PM   #9
ClawSS
High-tech Redneck
ClawSS's Avatar
Drives: '10 CGM SS, '02 2500HD, '09 300SRT8
FYI ... Never run your A/C when at the track...especially the drag strip. The water that will drip can cause severe traction issues for those running behind you and may cause a terrible accident.
"My friends call me Chris. Are you my friend?"
2010 CGM L99 2SS/RS - GPI SS3 VVT, BTR DoD Delete, Circle D 4c, BTR springs, Katech C5R Timing Chain, MRR-228 315/275, CAI, Elite catch-can, TSP 1 7/8" Headers + offroad pipes, Magnaflow 3", Pfadt springs, BMR LCAs, toelinks, trailing arms, cradle bushings, & sway bars w/ endlinks, Vitesse paddles, heritage grille, and an eBay splitter. Power upgrades by Race Proven Perf.; Tuning by ShorTuning.
ClawSS is offline   Reply With Quote
Old 10-08-2013, 09:17 PM   #10
ChrisBlair
Buick 455 Fan
Simply put- accessories driven off the engine all produce parasitic loses in power of some kind, at some time.
As an aside, but related, before 1971, engines were rated in gross horsepower- the engine itself, not even installed in the vehicle, no alternator, a/c compressor, nothing. That's why you'll see old ads for the "450 hp" Chevelle SS LS6. That was 450 gross hp. The LS3 spanks it in terms of hp. The V6 Camaro makes more brake hp than a lot of V8s of the golden era of muscle.
Old 10-13-2013, 10:37 AM   #11
Scalded Dog
Scalded Dog's Avatar
Drives: 2011 1LT
My vote for best answer.
Having driven many vehicles over the years, very frequently on the long grades ascending the 5000 ft. mountain I live on, I will testify, brothers and sisters: On a four banger, there are times that it makes the difference between being able to drive in fourth gear, or being forced to leave it in second gear. In vehicles with greater power, the accel/ torque difference is far less noticeable.
In my 1LT, it is nearly imperceptible... however, just to be sure, I still cut the AC off if I happen to be engaged in a contest to see who has larger manparts vs. a Ford, a German car, or even the occasional Italian ride.
Scalded Dog is offline   Reply With Quote
Old 10-15-2013, 01:43 PM   #12
MikeSVX
The magic smoke genie....
MikeSVX's Avatar
Drives: Jewels (2010 RJT 1SS)
When your making a couple hundred horses it isn't really noticable, but in low horsepower cars you can feel it. Long ago I rented a Geo Metro with a/c in it. I was in California and I would have to turn off the a/c to get the thing to go up some of the mountains. Also, It is a common warning in desert areas to turn off your a/c when going uphill to prevent your car from overheating. This reduces the load on the engine and, the a/c heat exchanger is usually mounted in front of the radiator and will raise the temperature of the air before it passes to the radiator if the a/c is on.
Support Search & Rescue.
Get Lost.
MikeSVX is offline   Reply With Quote
Old 10-15-2013, 09:57 PM   #13
Au201
Interestingly enough, I recently had my obd 2 port hooked up and I looked at load at idle with A/C on and off and on max. With A/C off, it was 23-25% load and with A/C on, it was 40-45% load (quite a difference!) and on max A/C, it went up to 50-55%. So I guess that means Max A/C actually does more than just put it on recycle. Lol. Also, just for S and Gs, when I dry steered the car (I know! Shame on me!) the load went up to 85% and there was a 200rpm drop for a split second. Lol. So even though it doesn't seem like much, it obviously makes a substantial load difference. As for power at full throttle, I do not know if the A/C makes as substantial a difference. Although, as mentioned, the Camaro shuts off A/C at full throttle.
Old 10-18-2013, 10:13 AM   #14
km9v
Drives: 2011 Camaro SS/RS M6
Living on the gulf coast, I use the AC ~8-9 months out of the year. When it gets cool enough, I really enjoy not having the load of the compressor on the engine. I don't drive @ WOT very much. Does anybody have an accurate HP loss number for LS3/L99?
km9v is offline   Reply With Quote
