Old 10-03-2013, 10:08 PM   #1
Louis White Law
Drives: Torch Red C7 Z51 stingray
Will passenger airbag turn off automatically for 6 year old?
I want to be able to drive my 6yo daughter around. Does passenger airbag automatically or manually turn off?
How does it disengage?
Louis White Law is offline
Old 10-03-2013, 10:13 PM   #2
ec1990
Drives: 2012 AGM SS
I believe it requires a 70 lb. weight sensor to be tripped. under that, it is not engaged
ec1990 is offline
Old 10-04-2013, 01:05 PM   #3
jackka
jackka's Avatar
Drives: 2011 Black/Black 2LT/RS M6 w/Sroof
Location: FT. Rucker, Alabama, the home of Army Aviation!
there should be an airbag status light somewhere on the rearview mirror or above the windshield that shows whether the passenger airbag is on or off.
the car automatically determines whether to turn the airbag on or off by sensing the amount of weight on the passenger seat.
jackka is offline
Old 10-08-2013, 03:01 PM   #4
showstopper
Drives: 2010 RS/SS
I was thinking about this as well so could drive my 5 year old. My brother in law had a c6 that you could manually turn off.
showstopper is offline
Old 10-08-2013, 03:50 PM   #5
solo40oz
solo40oz's Avatar
Drives: My wife crazy
There is a birth certificate scanner in the center console
solo40oz is offline
Old 10-11-2013, 08:47 AM   #6
Chevrolet Customer Svc
Chevrolet Customer Svc's Avatar
Drives: GM Vehicles
Hi Louis,
If you have a chance to look in the owners manual starting on page 3-22, there is a lot of information regarding passenger seat air bags. I found the following that may answer your questions: The passenger sensing system is designed to turn off the front outboard passenger frontal airbag if:
. The front outboard passenger seat is unoccupied.
. The system determines an infant is present in a child restraint.
. A front outboard passenger takes his/her weight off of the seat for a period of time.
. There is a critical problem with the airbag system or the passenger sensing system.
When the passenger sensing system has turned off the front outboard passenger frontal airbag, the off indicator will light and stay lit as a reminder that the airbag is off.
See Passenger Airbag Status Indicator on page 5-14. The passenger sensing system is designed to turn on the front outboard passenger frontal airbag anytime the system senses that a person of adult size is sitting properly in the front outboard passenger seat.
If you have any further questions please let me know,
Kelly J.
Chevrolet Customer Care
Chevrolet Customer Svc is offline
