Old 09-17-2013, 03:21 PM   #1
FaytalsCamaro
Distributor of Liquor
FaytalsCamaro's Avatar
Drives: My Wife Crazy
Something you should know before getting GTA5
If you have a Xbox with a 4gb hard drive you will not be able to play the game without getting a USB 2.0 Flash drive b/c the install is 8gb. The install disk GREATLY helps with texture and pop ins. Also it has been stated from RockStar NOT to install the actual gameplay disc on your hard drive. That will cause alot of pop ups and such because it will cause the data from two seperate sources to be streamed from the same place.
FaytalsCamaro is offline   Reply With Quote
Old 09-17-2013, 03:22 PM   #2
SSGUNNER
Chu no guat a hasa is?
SSGUNNER's Avatar
Drives: 14 Jeep G Cherokee Overland HEMI
I got 250. Is that good???
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
SSGUNNER is offline   Reply With Quote
Old 09-17-2013, 03:42 PM   #3
FaytalsCamaro
Your fine SSgunner! Rockstar just said to make sure NOT to install the actual disk that you play off of onto the harddrive. You can install it onto a USB according to some people. Ill find the source here in a moment
Old 09-17-2013, 03:43 PM   #4
FaytalsCamaro
http://www.ign.com/articles/2013/09/...-360-play-disc
