Old 09-12-2013, 03:55 PM   #1
GreenC7Z-51
GreenC7Z-51's Avatar
Drives: '04 C5 Z06 Le Mans, '14 C7 Z51
Exclamation Winter tires for your new Vette!
Many of us will be getting our cars in the beginning of COLD weather!
We will have to replace the stock tires with winter rubber. Does anyone have some good information on what is a good cold weather tire for the Corvette?
Most of us won't be driving in the snow but the stock rubber will not perform in the cold... Read Chevrolet warnings... Ive heard they mean it!
Thank you for all responses!
GreenC7Z-51 is offline
Old 09-12-2013, 04:34 PM   #2
SilverRay
SilverRay's Avatar
Drives: 2014 Silver C7 Z51 Stingray
I really don't you have anything to worry about, you live in Arizona. I live in Indiana and ran my C6 in very cold condition (never in the snow) but the tires preformed just fine and the new tires have even better grip just worm up tire with a little peddle.
SilverRay is offline
Old 09-12-2013, 05:08 PM   #3
GreenC7Z-51
I spoke to the manufacturer at the Monterey Motorsports Reunion recently, they told me that the rubber in this tire, (a different tire than on your C6), lacks good performance at below 50 Deg. F. ... *It gets plenty cold here... Like 7 Deg. through 20 Deg. Many mornings.
Yes you can drive on them, just don't depend on them to perform as they should if called to perform an evasive maneuver, or stop as they would when warm.
Old 09-13-2013, 09:19 PM   #4
bnall40
Drives: Z51 3LT, 2009 Pilot, 2012 Ody Tours
Try Tire Rack I have found good advice and prices there
bnall40 is offline
Old 09-14-2013, 09:39 AM   #5
TheCaptain
N7 Spectre
TheCaptain's Avatar
That's quite an ignorant response. All summer tires do not perform up to normal spec once ambient temperatures fall below 5*C (41*F).
I give you kudos GreenC7, you are not only looking out for your own safety, but that of others as well in your concern for tires in cooler weather!
TheCaptain is offline
Old 09-14-2013, 11:12 AM   #6
mdk9950
Drives: 06 Victory Red Corvette SOLD for C7
Was told at Corvettes at Carlisle that Michelin is making all season tire too. Not available from Factory with all seasons. Here is a description of all season version I found online:
Michelin Pilot Sport All Season Tire - 285/35-19 (2014 Corvette Stingray-Rear)
The Pilot Sport A/S 3 includes a W- and Y-speed rated Ultra High Performance All-Season option that's part of MichelinŐs Pilot family of low profile, high-speed tires developed for the drivers of high-end sports cars, sporty coupes and sedans looking for total performance regardless of the season. The Pilot Sport A/S 3 tire is designed to provide Michelin's highest level of all-season performance by combining dry road handling, wet road grip and year-round traction, even in light snow.
Pilot Sport A/S 3 tires feature MichelinŐs Helio compound made with sunflower oil combined with their Extreme Silica Technology to increase traction at low temperatures and on wet roads. Molded into an aggressive asymmetric tread pattern inspired by the Michelin Pilot Super Sport, its 4-, 5- or 6-rib designs* are tuned to complement tire width and feature more rubber and rigid blocks on their outboard shoulders to provide high levels of lateral grip that offer as much dry cornering capability as some competitive summer performance tires. Wide circumferential grooves help resist hydroplaning, enhance wet traction and help generate some of the shortest wet braking distances in the Ultra High Performance All-Season category. 3-D Variable Thickness Sipe Technology and unique biting edges in the tread grooves enhance cold weather snow mobility for all-season performance.
Variable Contact Patch 2.0 technology derived from MichelinŐs experience in endurance racing, focuses on evenly spreading contact patch pressures and temperatures. The tireŐs internal structure includes two high-tensile, lightweight steel cord belts reinforced with spirally wrapped polyamide cord to combine predictable handling and high-speed durability with treadwear and ride comfort.
- See more at: http://www.corvette7tuning.com/miche....uKx4cEea.dpuf
Found this too for more winter tire:
2014 Corvette Winter Tires
September 5, 2013
The 2014 Corvette Stingray is equipped with Michelin® Pilot Super Sport® ZP run-flat summer-only tires. (Fig. 9) The Michelin Pilot Super Sport ZP tires are unique and aggressively tuned to provide outstanding handling, grip and road-holding capability in dry conditions.
If frequent driving on ice or snow covered roads is expected, customers may want to consider installing winter tires.
With winter tires, there may be decreased dry road traction, increased road noise, and shorter tread life. After changing to winter tires, drivers should be alert for changes in vehicle handling and braking.
Due to the limited production of the Corvette Stingray, the only winter tire currently available is the Michelin Pilot Alpin PA4. Other tires may become available at a later date.
mdk9950 is offline
Old 12-12-2013, 07:20 AM   #7
Richardlord
Drives: Dodge Magnum RT Hemi AWD
What are the run-flats?
Richardlord is offline
Old 12-13-2013, 01:10 PM   #8
WARP TEN
WARP TEN's Avatar
Drives: 95 ZR-1
Run flats allow you to drive even with a loss of pressure. Usually OK to go up to 80 miles at up to 50 mph. although it you do go that far the tires are usually shot by then. --Bob
Thinking more seriously about a C7
1995 ZR-1 Polo Green #409 "WARP TEN" (FOR SALE)
--Haibeck 350/510hp package, 4.10s, Hurst, Stock Exhaust with QTP Cutouts
1993 ZR-1 Quasar Blue #161 "HIL KING"
--Sold but still running strong
ZR-1 Net Registry Founding Member #95
NCM Member
Favorite Quote--Attributed to Mickey Thompson:
"Too Much Horsepower is Almost Enough"
WARP TEN is offline
Old 12-13-2013, 01:32 PM   #9
bkindall
NCM Raffle Winner
Drives: '14 Cpe 3LT Z51 Crystal Red
Oh, he knows what Run Flats are, he wants to know where are the WINTER or ALL SEASON run flats are for the C7, like we all do.
bkindall is offline
Old 12-16-2013, 12:41 PM   #10
Richardlord
