#1 | |
2015 Mustang to Shed 400lbs (Edmunds)
http://www.edmunds.com/car-news/2015...on-a-diet.html
15" shorter, 6.5" narrower...makes me think BRZ size? Quote:
#2 |
![]() ![]() ![]() ![]() Drives: 2013 ZL1 Join Date: Mar 2010
It will be close to BRZ size. BRZ is 166 inches long compared with 173 for the new Mustang.
I can't wait for the specs to come out. At 3123lbs for the V6 Mustang vs 2800 for the BRZ, but with a huge power advantage for the Mustang, it should slaughter the BRZ and make it obsolete.
If someone from the 1950s magically appeared, what would be the most difficult thing to explain?
"I have a device in my pocket that can access the entirety of knowledge known to man. I use it to look at pictures of cars and have arguments with strangers." |
#3 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
So assuming the 400lb weight loss is true, that means we will see a base Mustang around 3,100 lbs and I'm guessing the GT will be in the 3,200 to 3,3xxlb max range.
Now imagine how that car with 450HP (which is what the next 5.0 is rumored to produce) under the hood will perform at the strip. Amazing comes to mind. I'm guessing easily mid 12s, if not slightly better than that. At this point there is almost zero doubt in my mind that the next gen of pony cars will be the fastest ever. With less weight they should also be more fun to drive in the turns. The only question yet to answer is how good they will look compared to the current gen which could be a tall order. I will say I'm not sure that I like the fact that the Mustang has to shrink so much. I just hope it doesn't end up looking like the size of a 370Z and still feels like the size of the current car even if it isn't. GM may be able to pull some tricks, but based on what we've seen so far with the cars build on the Alpha platform, I don't see how they could touch weights like that. I estimate the base Camaro to be in the high 3,2xx range at best and more likely low to mid 3,3xx range with the V8 model in the low to mid 3,500 lb range. I can't wait to see more.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
#4 |
![]() ![]() Drives: 2018 Mustang GT Join Date: Jul 2011
This all sounds ok but I want to see some pics of the 2015.
#5 | |
Oldbie that nobody knows
![]() Couldn't have said it more clearly. This mostly comes down to looks, because there is no dispute that the next generation is going to perform a lot better thanks to improved power and most importantly, lighter weight. Sadly, looks is a big role to fill since many people favor the retro futurism that defines the current generation. Any car can go fast but not every car looks amazing. |
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: too many Join Date: Jul 2013
If that becomes fact, WOW they will smoke us like a cheap one. I hope GM takes notice
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
That's Vette territory as far as weight. Should be interesting to see what kind of power the 5.0 will make.
#8 |
![]() Drives: 12 MP4-12C, 16 Quattroporte Join Date: Mar 2012
I that weight is correct, GM may have to make some changes to the c7. 450hp and 3200 lbs is pretty spot on the new corvette specs.
#9 |
Remember the Charleston 9
Drives: 2004 KME PREDATOR, 2014 2SS/RS/1LE Join Date: Nov 2008
I just hope the new Camaro isn't that small. We survived in the fifth gen just fine with the extra weight.
2002 V-6 5 speed rally red (current camaro) Also driven:1992 Z-28 305 auto Red w/ black stripes (anniversary), 2001 V-6 auto light pewter metallic,1991 RS V-6 auto Black |
#10 | |
![]() Drives: 2012 45th Anniversary SS Coupe Join Date: May 2012
#11 |
Recalled user
Drives: '12 Camaro SS, '18 Colorado Z71 Join Date: Mar 2009
My thoughts exactly. It'll put Chevy in an odd position to compete.
2012 2SS 45th AE LS3 M6 Borla ATAK Catback Kooks Stepped LT Headers CAI Intake Hexvents VMAX CNC Ported Throttle Body RX Catch Can Hurst Short Throw Shifter Pfadt ZL-Spec Stage 3 Suspension Forgestar F14 Tuned by Frost |
#12 |
A 2015 Mustang GT Premium package should list for around 37K depending on options.
#13 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 92 Luminadead/01 Dakota/97 F150 4x4 Join Date: Jul 2009
#14 |
