#1 |
Drives: 2023 GMC Canyon, 2023 Expedition Join Date: Aug 2008
GM Details 3.6L LF3 Twin-Turbocharged V6
Cadillac’s Twin-Turbo Kicks Turbo Lag to the Curb
Efficient air flow delivers better torque response for CTS Vsport, XTS Vsport General Motors 2013-07-26 ![]() DETROIT – Turbocharging increases power and performance with efficiency, but the delay in the delivery of power – known as “turbo lag” – has historically been its key limitation. That’s about to change. Cadillac’s first-ever Twin-Turbo, available on the 2014 CTS Vsport midsize luxury sedan and XTS Vsport full-size luxury sedan in the U.S. this fall, kicks turbo lag to the curb with a unique combination of smaller turbochargers, top-mounted throttle body and shorter air pathways. The Cadillac Twin-Turbo V-6’s patented air flow design, which eliminates circuitous heat-exchanger tubing, makes the most of engine packaging efficiency to improve torque response time over other air flow designs. Rated at 420 horsepower in the all-new 2014 CTS Vsport and paired with Cadillac’s first eight-speed transmission, the Twin Turbo is one of the most power-dense engines in the midsize luxury sedan segment, rated at an SAE-certified 420 horsepower (313kw) and 430 lb-ft of torque (583 Nm). Air flow routing volume is reduced by more than 60 percent when compared with a conventional design that features a chassis-mounted heat exchanger. The water-to-air cooler system achieves more than 80 percent cooling efficiency with only about 1 psi (7 kPa) flow restriction at peak power for fast torque production. “By creating a very short path from the turbos to the throttle body, the compressors are able to draw air directly from the inlet box and send pressurized air through the intercooler immediately,” said Richard Bartlett, Cadillac assistant chief engineer for the 3.6L engine. “This gives the driver a more immediate feeling of power on demand.” Using two smaller turbochargers rather than a single, larger turbo also helps ensure immediate performance because smaller turbochargers spool up quicker to generate horsepower-building air pressure that is fed into the engine. An integrated charge air cooling system also contributes because the compressors blow through very short pipes up to the intercooler. The single, centrally located throttle body atop the engine controls the air charge from a pair of turbochargers after the temperature is reduced in the intercooler. This design fosters more immediate torque response and reduces complexity by eliminating the need for a pair of throttle bodies. Together, smaller turbochargers, top-mounted throttle body and shorter air pathways help sustain peak torque over a broad range – 1,900 to 5,600 rpm – for a confident feeling of power in almost all driving conditions, such as accelerating or overtaking traffic on the highway. “The Cadillac Twin-Turbo intercooler design builds on our experience with the 6.2L supercharged engine used on the current CTS-V Series,” Bartlett said. “That means more performance for drivers without sacrificing efficiency.”
2023 GMC Canyon Elevation 2023 Ford Expedition SSV (State-Issued) |
#2 |
Casual Camaro Owner
Drives: 2010 Black LS V6 Join Date: Jan 2010
Man this engine gets better and better everyday
#3 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 IBM 1SS (Former) Join Date: Feb 2009
Is this engine going in the ATS-V too? I feel like I read that somewhere. Maybe I'm making it up. I really hope this motor finds its way into a Chevy product too.
#4 |
It'll probably be the ATS-V engine.
#5 |
![]() ![]() ![]() Drives: 2002 ws6 Join Date: Jul 2009
poor ecoboost.
Bolt on 2002 ls1 Trans am--- 11.5 @ 121 (1.72) 2000 da
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
#7 |
![]() ![]() Drives: 2018 Mustang GT Join Date: Jul 2011
That's impressive for an American made V6.
#8 |
Casual Camaro Owner
#9 |
www.macsautodetail.com
What are the chances one of these would drop right into a Camaro v6?
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 GT350 Join Date: Jan 2011
Buick Grand National please!
2019 GT350 RR
2013 Boss Mustang 2012 SRT Challenger 392 auto 12:40s 112 stock 2012 Ford Mustang 5.0. Brembo, 3:73s 2010 SS, LS3, Cammed, LTs, 12:20s 2004 Redfire Cobra, Pullied & Tuned 1986 GT, Ed Curtis 347ci, 11:20s motor. 10:30s 100-hp shot |
#11 | |
Hail to the King baby!
Drives: '19 XT4 2.0T & '22 VW Atlas 2.0T Join Date: Dec 2008
The Epsilon architecture has always had an issue with exhaust routing under the front of dash that chokes off power. My guess is the ATS in a North/South configuration will just make more power from breathing a little bit better.
#12 | |
Moderator.ca
The Assistant Chief Engineer for that engine was on Autoline After Hours last night. Haven't watched it yet, but skip ahead to around the 20 minute mark to see what he has to say about it (the first part of the show covers recent automotive news)
www.youtube.com/watch?v=X_kYGY7ZMNA there should be a podcast version of the show available at the following link sometime soon: Autoline After Hours Quote:
Ask the people that have done LS9 swaps into their SS, I don't think it would be too different in terms of overall work involved. But that said, there are much better ways to get 420 hp out of your V6 -just as there are better ways to get 640 hp out of an SS than dropping in an LS9.
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
#13 |
Drives: 2010 Camaro 2LT VR/RS CGM Rally's Join Date: May 2009
I Plan on putting this engine in my car in a couple of years.
#14 |
Drives: 2000 Camaro SS Join Date: Feb 2010
That is going to be a lot of fun to play with.
