Old 07-17-2013, 09:44 PM   #1
SSdude
SSdude's Avatar
Drives: Super Sport
Battery in a pool of tire sealant for almost a year
My van decided to die out on me today so I figured I'd use my camaro and jumpstart it. Since my camaro was in my garage and the van was parked behind it I thought to myself "Glad the battery is behind. No need for any long jumper cables" . So I go and pop the trunk and remove the thermocol cover that sits on the battery and lo and behold the battery is sitting in a pool of white liquid. Nearly freaked me out. I was wondering how nothing had shorted out yet. The only time I had ever removed the compressor out was when I was helping a friend out with a flat about a year back. I'm pretty sure I had put the cap back on the tire sealant line in the air compressor but I guess it somehow popped out and all the tire sealant liquid basically dumped into the battery compartment.
I took some pictures but by then I had already removed most of the gunk out. The pictures below are after I had removed almost 75% of the sealant liquid.
The tire sealant is a really sticky liquid and it was a real pain to clean especially because you can't reach under the battery stand and the floor of the trunk. I had to pop open a seal cap on the bottom of the trunk that basically acted like a drain hole and gently keep pouring water until all the sealant drained away. Has this happened to anyone else or am I the only one?
Also how come the tire sealant just flowed out of the compressor unit. Isn't it supposed to flow out only when the compressor is ON?
SSdude is offline   Reply With Quote
Old 07-17-2013, 09:46 PM   #2
meshamey
Meshamey
meshamey's Avatar
Drives: 2011 Camaro 2SS / 2014 Camaro ZL1
dam, now I have to go check mine... /brb
meshamey is offline   Reply With Quote
Old 07-17-2013, 10:07 PM   #3
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
Rut row raggy
hunter1660 is offline   Reply With Quote
Old 07-17-2013, 10:10 PM   #4
midnighter
Drives: nothing
Those are a piece of shit. I used mine, made a huge mess, and couldn't get it to stop releasing fix-a-flat afterwards. I threw away the fix-a-flat canister and just kept the air compressor.
Old 07-17-2013, 10:10 PM   #5
Dznts
Anabolic Connoisseur
Dznts's Avatar
Old 07-17-2013, 10:31 PM   #6
CamaroTard
CamaroTard's Avatar
Drives: 2011 Camaro1LT/RS SGM
Same problem...
Hi, I had the same thing happen to me and dealer has a new one on order under warranty...fyi. PS that stuff is gross as hell...
CamaroTard is offline   Reply With Quote
Old 07-17-2013, 11:59 PM   #7
KJS
KJS's Avatar
Drives: '10 RJT,'95&'14 Vette
Looks like a....
....bit from "Honey Boo Boo scratch and sniff"....
"As ye sow, so shall ye reap" - Me
Mine at sunset
KJS is offline   Reply With Quote
Old 07-18-2013, 07:07 AM   #8
Cheveey57
Cheveey57's Avatar
Drives: 2010 Camaro 2LT RS
That's why I ordered mine with the spare.
If you're not living on the edge, you're taking up too much space.
Cheveey57 is offline   Reply With Quote
Old 07-18-2013, 07:48 AM   #9
Cody6.2
Drives: 2012 Camaro 2SS
Not an option on the SS though.
Cody6.2 is offline   Reply With Quote
Old 07-18-2013, 08:05 AM   #10
ToolFan66
ToolFan66's Avatar
Drives: 2011 2SS 6.2L W/RS package
Looks like you had sex with your car..
KooKs LT Headers, Borla S-Type cat back, RotoFab CAI, Bo White PTB, RMCR tune...
ToolFan66 is offline   Reply With Quote
Old 07-18-2013, 08:14 AM   #11
AKA-22
AKA-22's Avatar
Drives: ELLE-1
has anyone used this stuff before to see if it even works?
AKA-22 is offline   Reply With Quote
Old 07-18-2013, 08:39 AM   #12
JR 1
JR 1's Avatar
Drives: 2014 2SS/RS Convertible
Well, at least your trunk floor should be very well sealed.
JR 1 is offline   Reply With Quote
Old 07-18-2013, 08:50 AM   #13
strych9
I'll be back...
strych9's Avatar
Drives: Subaru, HD Road Glide Special
I carry a tire plugger kit and the compressor. No way in hell am I going to fill my tires with that shit.
Bye bye, Bumblebee!
strych9 is offline   Reply With Quote
Old 07-18-2013, 12:48 PM   #14
GEEKFREEKSCOTTY
Autoboticus Roboticus
GEEKFREEKSCOTTY's Avatar
Drives: 2011 Camaro 2SS/RS
This is probably the better advice to follow. And less likely to foul your TPMS sensors.
GEEKFREEKSCOTTY is offline   Reply With Quote
