Old 07-04-2013, 08:33 PM   #1
feo_gang
Drives: black 93 camaro z28 coupe
First Camaro , Need Help
I Just Got My First Car a 93 Camaro z28 , it can crank and drive it but when it gets hot it shuts off , can anyone help me with this problem ??
feo_gang is offline   Reply With Quote
Old 07-04-2013, 09:24 PM   #2
PHXLT1
PHXLT1's Avatar
Drives: black Z28
Ya but I think you should be in the 4th gen section. Ok, how hot are you talking about? Red line? If your car gets to that point then you should not be driving it at all. Next, we need to determin why it gets hot. First, have you checked or put in a new thermostat? Second, are the fans working? Third, have you opened the radiator cap to see if the radiator is full of sludge? Fourth, and lastly, do you have fluid coming out of the tail pipes? Oil in the water? And check the oil dipstick. If its milky white the you could have a blown head gasket. Any one of these things will cause your car to over heat. Good luck!
My family
1994 Z28 (mine)
2015 Camaro (wife's)
2015 Silverado (mine!)
54 Belair (wife's)
2004 silverado (daughters)
PHXLT1 is offline   Reply With Quote
Old 07-04-2013, 09:26 PM   #3
feo_gang
Nahh Fernando Nothing Is Milky White , no water in my pipes . new oil chage , my fans go into overdrive when the car shuts off
Old 07-05-2013, 11:12 PM   #4
PHXLT1
PHXLT1's Avatar
Drives: black Z28
Ok then we need to look at your radiator. Try a flush and change out your thermostat.
My family
1994 Z28 (mine)
54 Belair (wife's)
Old 07-05-2013, 11:24 PM   #5
11BEE
11 BEE
Drives: 2011 LS2 RS & 2012 2SS RS 45th Vert
When you say shuts off, do you mean the engine stalls?
11Bee and I♥My45th
11BEE is offline   Reply With Quote
Old 07-06-2013, 01:33 AM   #6
PHXLT1
PHXLT1's Avatar
Drives: black Z28
That's the impression I got too. I hope not or the damage has been done....maybe.
My family
1994 Z28 (mine)
54 Belair (wife's)
Old 07-06-2013, 06:28 AM   #7
11BEE
11 BEE
I am curious if he is getting a vapor lock.
11Bee and I♥My45th
Old 07-08-2013, 09:34 PM   #8
feo_gang
What Do You Guys Mean By Stall ?
Old 07-08-2013, 09:43 PM   #9
Overflow
Space Shuttle Aficionado
Drives: 2016 Camaro 2SS
You'll be driving and the engine will stop.
Old 07-08-2013, 09:45 PM   #10
11BEE
11 BEE
A stall is when you are driving and the engine dies. We are trying to determine what is actually happening. Answer these:
What do you mean by it turns off? Please describe
Can you restart it?
When you are driving it, does it run smooth when cold and then get very rough as it warms up?
Is your radiator full of fluid? (ONLY OPEN WHEN THE ENGINE IS COLD)
Check your oil dipstick and see if you have oil?
11Bee and I♥My45th
Old 07-08-2013, 09:48 PM   #11
feo_gang
yeahh the car stalls , i can restart it after 5-10 minutes of waiting , needs a tune up , and yes i have radiator fluid
Old 07-08-2013, 09:49 PM   #12
feo_gang
But When The Car Stops You'll Hear The Fan
Old 07-08-2013, 10:23 PM   #13
11BEE
11 BEE
Sounds to me like a few possibilities:
-Fan is not turning on. This will trip the ECU to turn off when it gets above 225 I think.
-O2 sensor is bad causing it to run very lean when hot
-Split vacuum line. You need to check all of them.
-Someone reran the fuel lines and they are causing a vapor lock
I had this happening in an old Chevy 3100 I did a Chevy 350 swap on. I ran the fuel line too close to the headers and it was causing the gas to turn to vapor in the line before it got to the carb. It would run horribly. Moved the line and wrapped it and it runs perfectly now.
My son had this same issue in an 1985 Nissan 300 zx he rebuilt. He ended up having a split vacuum line which was to provide vacuum when the engine got hot to lean the fuel mix down. The lack of vacuum caused the engine to run way to rich when hot and caused it to stall.
11Bee and I♥My45th
Old 07-08-2013, 10:25 PM   #14
feo_gang
I'll Check These Out .... Thanks
