Old 06-20-2013, 03:23 PM   #1
Retro69
Retro69's Avatar
Drives: 2018 Camaro ZL1
Text in Signature Doesn't Show On Replies
I just created a signature with a picture and some text below. When I click on "Preview Signature" I see both the picture and the text. However, when I reply to someone's thread only my signature picture shows. What am I doing wrong?
Retro69 is offline   Reply With Quote
Old 06-20-2013, 03:30 PM   #2
If your sig pic is too big, the text below will be cut off. Try reducing the picture size and you should see it appear.
Old 06-20-2013, 03:58 PM   #3
Retro69
Retro69's Avatar
Okay I just made it smaller. Let's see what happens.
Old 06-20-2013, 03:58 PM   #4
Retro69
Retro69's Avatar
Hrm... I'll try something else later :(
Old 06-20-2013, 04:00 PM   #5
Retro69
Retro69's Avatar
Okay I made it within the recommended size. (fingers crossed)
Old 06-20-2013, 04:01 PM   #6
Retro69
Retro69's Avatar
:( boo!
Old 06-20-2013, 04:01 PM   #7
Retro69
Retro69's Avatar
Okay this is with a smaller font...
Old 06-20-2013, 04:02 PM   #8
Retro69
Retro69's Avatar
Hrm I don't get it. It shows in the reply preview but not in the final post.
Old 06-20-2013, 04:28 PM   #9
Retro69
Retro69's Avatar
One more try...
Old 06-20-2013, 04:29 PM   #10
Retro69
Retro69's Avatar
(sigh)
Old 06-20-2013, 04:42 PM   #11
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
Your signature is based on a certain pixel size. Your picture is 200 pixels tall.
Try making your picture shorter and the test should appear beneath it. For example, with my signature I have very small text above it and the bottom of the picture gets cut off slightly. I can make the picture even smaller if I want the whole thing to show up. Good luck!
Old 06-20-2013, 04:47 PM   #12
My picture's actually a lot bigger but I had to reduce the size to get the text in.
Old 06-20-2013, 06:39 PM   #13
Overflow
Space Shuttle Aficionado
Drives: 2016 Camaro 2SS
I think mine cuts off early too.
EDIT: Yepp.
Old 06-20-2013, 06:43 PM   #14
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
The size limit is for both images and text combined. If you want a line of text to show up you'll probably want to set the height to something like 190 pixels instead of 200. Or do like Mindz has done & just put the text above the pic and let the bottom get cut off.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
