Old 06-19-2013, 03:48 PM   #1
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
LS3 into an 80's Monte Carlo SS
I'm curious and thought I'd post this. My girlfriends dad has an early 80's Monte Carlo SS with a 305 in it. He wants to drop an LS3 in its place, however I'm under the impression that there is A LOT more to it than just dropping in a LS3, he seems to disagree. Isn't this going to be a much larger project than just an engine swap, or am I missing something?
BaylorCamaro is offline   Reply With Quote
Old 06-19-2013, 04:07 PM   #2
05stram
Drives: 2013 RS - 2013 2SS/RS - 1971 RS
http://forum.lsxtv.com/showthread.php?p=4852
Already been done here you go then you can give him an educated response on his project.
05stram is offline   Reply With Quote
Old 06-19-2013, 05:11 PM   #3
upflying
upflying's Avatar
Drives: '86 Monte Carlo SS
I would suggest joining
http://www.montecarloss.com/
upflying is offline   Reply With Quote
Old 06-19-2013, 06:35 PM   #4
LLT'MARO
Drives: 2010 Camaro V6/6Spd
I've swapped an LSX in my Monte. Getting the motor in was relatively easy. Need to use the right combo of mounts, oil pan...and a little work on the engine crossmember. Then you have wiring, fuel system, induction type.
Had the car running using a MSD ignition controller and a carb, but now going EFI.
LLT'MARO is offline   Reply With Quote
Old 06-19-2013, 11:48 PM   #5
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
I'd look into the E-Rod engine line. It has everything you need to swap a LSX engine into an older RWD car. They are a bit pricey but everything is new and complete. The LS3 is stout for a 3200 lbs car with a basic SLA coil spring suspension. The car wasn't designed to handle 430 hp from the factory. You should consider upgrading the suspension if you really want to complete the swap correctly.
http://www.chevroletperformance.com/...ction=overview
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
