06-12-2013, 07:15 PM | #1 |
Drives: 2012 Camaro ZL1 Victory Red Join Date: Mar 2013
Hauling a ZL1 in a enclosed trailer?
I live in Northern Ontario in a the years to come would like to take my car with me to the Southern States for our winter break. I would really prefer to carry the car in an enclosed trailer to eliminate milage and any chance of road salt. All the 8'.5"w x 20' L trailers I have looked at seem to be a real tight fit as this car is so wide.
Has anyone hauled their car in an enclosed trailer? If so please give me the trailer details and how you felt your car fitted width wise. Thanks
Terry
06-12-2013, 07:21 PM | #2 | |
Drives: 2010 Camaro Join Date: Feb 2010
Width wise they are all tight. On my 48' I can park on either side of the wheels wells and get out of the door. A smaller trailer will not allow that. It's dukes of hazard style. Unless you get a high end trailer with an escape door. That would be the way to go. |
06-12-2013, 08:21 PM | #3 | |
[QUOTE=AMMUSCLE;6663437]Y
In the back I use 24" axle strap wrapped around the lca then attached to a ratchet strap. Yes, the front is low and its a pain. I had Jannetty fab a hoop in the front center on the chassis that I can reach from the front if the car. I hook 2 staps to the hoop and then to the trailer D rings. You can also use race ramps and drive up onto them in the trailer. That will give you plenty of clearance to finagle the straps around the chassis. |
06-12-2013, 08:29 PM | #4 |
Drives: 2013 ZL1 VERT M6 Join Date: May 2013
Great info.
Thanks |
06-12-2013, 08:31 PM | #5 |
06-12-2013, 08:40 PM | #6 |
pics:
06-12-2013, 11:03 PM | #7 |
Drives: 2013 ZL1 Camaro Join Date: Oct 2012
I picked my ZL1 up in February and hauled it in a 20' enclosed trailer. It was made by Royal Trailers. It was super tight width wise, like an inch from the wheel wells. The bottom of the doors unexpectedly cleared the wheel wells , but barely. The rear was easy to tie down because the rear of the trailer was ramped slightly. The front was a super pain in the butt because the D-rings on the trailer were located right under my front splitter. I was able to criss cross the straps still but had to put the straps on the wheels, through the spokes. I wrapped the straps in microfiber and also placed a blanket between the spokes so it wouldn't scratch. 4.5 hours later the car safely got home and didn't move a bit. But moral of the story is i would not use a 20' again lol
06-13-2013, 12:03 AM | #8 |
Drives: 2012 Nickey ZL1 #001, 2014 Corvette Join Date: Feb 2011
I have towed several of my camaros across the country and back in a 20' enclosed trailer. They are tight width wise but I had no problem length wise. I installed an e-track the entire length of the trailer with the below wheel straps. The great thing about these wheel straps is that they let the car suspension work and by design, the ratchet is far enough away, there are no issues or concerns about hitting the car. By having the e-track the entire length, I have endless possibilities of strapping cycles, 4 wheelers, etc.
http://www.autohaulersupply.com/cata...plies-83-1.php |
06-13-2013, 12:45 AM | #9 |
Teenage Dream Camaro
Drives: A Visually Stunning Camaro Join Date: Feb 2013
06-13-2013, 01:00 AM | #10 |
HT5 COTW 1/21/13
Drives: 2010 Camaro Inferno 2SS RS 6M Join Date: Apr 2011
I am looking at buying a 20' trailer to haul my car and I will also get the e track
06-13-2013, 07:21 AM | #11 |
Drives: 2010 camaro pace car, 2008 cts bl, Join Date: Jun 2011
I ordered a 24x8.5 v-nose and got the escape door on it ($350 option). Be careful first time you open it, mine didn't clear and the door hit the opening right at the bottom. You can put some 2x12's down to clear the opening. I raised the floor since I haul my drag car and its low to the ground.
Mods, 2r max cam, ls3 conv,kooks lt w/hf cats,kooks street sleeper cat back with magnaflow res x-pipe, roto fab cai, v-max TB, vigilante 3700 stall, 3.70 LPE, 442hp/392tq, Mike Norris Tune 11.71@116.24 1.63 60' m&h DR's
06-13-2013, 07:43 AM | #12 | |
Drives: 2013 Camaro ZL1 Join Date: Jan 2010
ZL1 Hauling In Enclosed Trailer
06-13-2013, 08:56 AM | #13 |
Perma Grinning
Drives: 2012 Tom Henry Racing ZL1 Join Date: Feb 2012
I have a wide body Wells Cargo. . . plenty of room to go in.
Went with a 10,000 lb capacity, since the 7,700 lb, have zero weight safety factor with the ZL1 coming in at 4,200 lbs. I use the factory tie down points with "T" hooks. On the front had to route out a hole in the belly pan, but looks like it is supposed to be there. I also have a custom raised deck rails and over sized drivers awning door so that I can get in and out of the car.
Our Garage:
2018 Traverse High Country, 2017 Tom Henry Racing ZL1 Convertible, 2016 Silverado High Country HD, 2014 Camaro SS Convertible, 2012 Tom Henry Racing ZL1, 2002 Berger SS Phase II, 2001 Camaro SS Convertible, 1997 Hendrick Motorsports 30th Anniversary LT4 SS, 1992 Camaro RS Z03 25th . . . |
06-13-2013, 09:40 AM | #14 |
Perma Grinning
24' long 8.5' wide, 10,000 lb. Here are pics:
