Old 05-14-2013, 10:43 AM   #1
HSV Reveals 2014 HSV Gen-F Range
If you want to make a stand, then it’s time to take a seat
Holden Special Vehicles
15 May 2013
Exterior
With a whole new distinctive identity, the HSV GEN-F range of vehicles feature a more sophisticated, modern and integrated design.
The GTS is fitted standard with:
• AP cross-drilled discs with forged 6-piston front calipers and 2 piece front and rear rotors
• 20" x 8.5" (front) and 20" x 9.5" (rear) “Blade” forged alloy wheels in Satin Graphite
• HSV LED Tail Lamps
• Dual function Daytime Running Lamps (DRLs)
• Projector headlamps
• HSV Quad exhaust outlets with Shadow Chrome tips
• HSV Performance Body Design
• Fender vents and side mirrors with Pitch Black accenting
• HSV side-skirts
• HSV Super-flow Performance Spoiler
Wheels
The GTS features 20" x 8.5" front and 20" x 9.5" rear “Blade” forged alloy wheels in Satin Graphite
The dual function lamp runs as a Daytime Running Lamp (DRL) and a Position Lamp meaning they can be seen at night, at a slightly lower intensity, in conjunction with the headlights.
Super-Flow Performance Spoiler
The GEN-F GTS features the all new HSV Super-flow Performance Spoiler finished in body colour with Pitch Black accenting. This spoiler complements the integrated and aggressive design of the rear fascia.
Interior
The GEN-F GTS receives an all-new premium interior incorporating new seats and fabrics, instrument panel, cluster, gauges, centre console, trims and finishes.
The GTS features:
• Driver Preference Dial
• HSV Performance Seats in Onyx Leather Trim
• 8-way electric adjustment of driver and front passenger seat
• Front seat heaters
• Multifunction, leather wrap sports profile steering wheel with height and reach adjust
• HSV Sports Twin gauges displaying oil pressure and boost pressure
• Centre console GTS I.D. plate
• Leather wrap gear selector
• Alloy faced pedals
• Premium BOSE audio with 9 speakers
• Enhanced Driver Interface (EDI)
• Dual Zone Climate Control
Entertainment
The GTS features an 8" high-resolution, colour touch-screen display along with USB input, Single CD player with hard drive storage and the capability to play MP3 tracks, Full iPod® integration and a 9- Speaker Bose® premium audio system.
Enhanced Bluetooth©
The Bluetooth fitted standard to the GTS is fully integrated so keeping in touch, while on the move, has never been easier.
Driver Environment
Side Blind Zone Alert with Reverse Traffic Alert
The Side Blind Zone Alert system extends driver vision, using ultrasonic waves to detect objects adjacent to the vehicle in the traditional “blind spot” zones. Reverse Traffic Alert intuitively scans rear cross traffic and warns you of any approaching vehicle hazards.
Head Up Display
The Head-Up Display provides the driver with important vehicle information including speedometer, tachometer and lateral G forces, in a safe and convenient way on the windscreen directly in front of them.
EDI connects with the vehicle’s on-board computer to constantly stream real-time vehicle dynamics and performance data to the touch screen display.
Passive Entry and Remote Start (Automatic Transmission only)
Passive entry is a keyless access system which lets you lock and unlock the vehicle’s doors without removing the remote from your pocket, briefcase etc.
Vehicles with automatic transmission have remote start which allows the vehicle’s engine to be started from outside the vehicle by using the remote start button found on the remote key.
Automatic Park Assist
The Automatic Park Assist system helps take the guess work out of reversing into tight parking spaces through the use of parking sensors located in the front and rear fascias. The sensors detect the suitability of a parking space, calculate the correct drive path and steer the vehicle into position. All that is left for the driver to do is control the brakes, transmission and clutch (in manual vehicles).
Forward Collision Alert
A camera, located above the rear view mirror, scans the road ahead up to 14 times per second. When a collision is predicted, the driver is alerted with an audible tone and a visible alert in the Head Up Display. Anticipating hard braking, the system applies sufficient brake pressure to close the space between the brake pads and rotors, thus delivering a quicker brake response time.
Lane Departure Warning
Lane Departure Warning alerts the driver to any unintentional lane departures with an audible sound and warning indicator.
Rain Sensing Wipers
Rain Sensing Wipers are a convenience feature in that the windscreen wipers will operate when water is detected on the windscreen without the driver having to manually operate them.
Hill Start Assist/Hill Hold Control
The Hill Start Assist system assists in preventing rollback when taking off, when the vehicle is on an incline or decline (when reversing).
Performance Technologies
Supercharged LSA Engine
The GTS features a 6.2litre Supercharged LSA engine which provides a staggering 430kW of power and 740Nm of torque.
With all this power comes the need for massive amounts of air cooling, which is why the GTS’ design is not only stylish and sophisticated, but also functional with 130,000 square millimetres of air intake frontal surface area. To also assist with this need for cooling, the GEN-F GTS is fitted with a stacked plate engine oil cooler and Water to Air charge intercooler system.
Unique tail shafts cater for the higher torque loads and a new rear differential helps transfer all of that power to the ground.
Torque Vectoring
Torque Vectoring uses the ESC system to detect when the vehicle is starting to understeer, and helps correct it. The system works by transferring torque across the rear axle from the inside wheel to the outside wheel. This is accomplished by braking the inside wheel and adding torque, through increased engine power, to the outside wheel. The result is a “rotational moment”, acting on the body, helping to steer the vehicle through the corner.
The Driver Preference Dial allows the driver to manipulate the vehicle’s various electronic performance systems according to a range of distinct pre-set modes.
AP Brakes
The GEN-F GTS features a new and improved brake package developed from the latest NASCAR and V8 Supercar technologies, which has not only provided a weight saving, but also improved our brake feel and performance.
The GTS is fitted with forged 6-piston front calipers with 2 piece front and rear rotors with increased diameters.
Continental Tyres
After an extensive evaluation and testing process, in both dry and wet conditions, the HSV Engineering team with the assistance of HSV Test Driver and V8 Supercar Driver, Garth Tander chose Continental as the tyre supplier for the new GEN-F range.
Generation 3 Magnetic Ride Control (MRC)
HSV, in conjunction with Bosch, has been working on the latest iteration of this suspension technology for over two years. Dubbed “Generation 3 MRC”, this feature is standard on the GEN-F GTS.
Generation 3 MRC has 3 independent settings on GTS and now runs dual coil pistons which results in faster response times and greater body control.
Electric Power Steering
Electric Power Steering, with 2 modes, matches steering calibration with ESC settings, providing a new level of “feel” through the steering wheel that can be changed to suit driving preferences.
Launch Control (Manual Transmission only)
Launch Control provides the vehicle with the ability to accelerate, from standstill, at its maximum potential by managing engine torque and wheel-slip ratios.
Competition Mode - Electronic Stability Control (ESC)
Competition Mode ESC is specifically designed to give the driver more freedom under ‘spirited’ driving conditions.
Options
SV Performance forged alloy wheel
20" x 8.5" SV Performance front wheel in Satin Graphite (255/35 R20 tyre). 20" x 9.5" SV Performance rear wheel in Satin Graphite (275/35 R20 tyre).
(Note: ClubSport R8 SV with 4-piston brakes pictured)
6-speed automatic transmission with Active Select specifically calibrated to the LS3 engine power and torque output.
Sunroof
The factory fitted electric sunroof features tilt and slide functions and a block out sunshade.
Temporary Spare Wheel
Full size, 20” temporary spare wheel in gloss black. (Note: Tyre Pressure Monitor is not available on the Temporary Spare Wheel.)
HSV Performance Seats in “Red Hot” Leather Trim
HSV Performance leather seats in “Red Hot” trim, with 8-way electric adjustment on driver and front passenger seats.
HSV Lo-Line Spoiler
An all-new HSV Lo-line spoiler in Satin Graphite is available as an option on GTS.
Safety
Anti-Lock Braking System (ABS)
ABS reduces wheel lock under heavy braking situations by momentarily releasing brake pressure at the wheels required. This improves stopping distances on most surfaces, improves braking efficiency and enables better steering in demanding braking conditions.
Exclusively calibrated by HSV, the GTS’s ESC system monitors steering wheel angle and speed to make turning corners safer. If loss of traction occurs, ESC activates to apply brake pressure to individual wheels and, if necessary, reduces engine power.
Electronic Brake Assist (EBA)
In emergency braking situations, few people apply the required pressure to the brake pedal. EBA activates to optimise brake pressure performance.
DataDots
DataDot DNA Platinum is the ultimate deterrent to both “professional” car thieves and component counterfeiters or supplier overruns. Approximately 10,000 DataDot DNA are applied to each GEN-F vehicle, all of them laser-etched with the unique Vehicle Identification Number (VIN).
More pics on the HSV Facebook page.
Old 05-14-2013, 10:45 AM   #2
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
looks like a Pontiac.
2010SLVRBULIT is offline   Reply With Quote
Old 05-14-2013, 10:48 AM   #3
Lawdog1911
ZL1 Dreamin
Lawdog1911's Avatar
Drives: 1967 Camaro, 2010 2SS (RIP)
Sweet! I want the whole collection of them.
Lawdog1911 is offline   Reply With Quote
Old 05-14-2013, 11:49 AM   #4
Camaro Lives On
Force RECON
Drives: 2005 Saab 9-5 2.3T
Send a message via AIM to Camaro Lives On
That grill is begging for a Pontiac badge!!!
Camaro Lives On is offline   Reply With Quote
Old 05-14-2013, 11:57 AM   #5
ShnOmac
That is what the SS should look like. IMO
Old 05-14-2013, 11:58 AM   #6
Camaro Lives On
Force RECON
^Agreed!
Old 05-14-2013, 01:58 PM   #7
camarowa
camarowa's Avatar
Drives: 2013 SVT Raptor, sold 2010 Camaro
I will take the station wagon please!
- Pfadt Suspension Package; Springs & Sways
- Brembo Brake Upgrade (Yellow); Courtesy Fesler Built
- Custom Magnaflow Exhaust
- Blacked-Out Bowties & RS Emblems, Front bowtie delete
- Full Dynamat Extreme Trunk Coverage
- Tinted side markers
- Interior DSV Customs Leather Upgrades
- Airaid CAI V2
- Forgestar F14 Gunmetal 20x9, 20x11
- Doug Thorley Shorties
camarowa is offline   Reply With Quote
Old 05-14-2013, 03:39 PM   #8
matt55
matt55's Avatar
Drives: CTS-V
Yes!
10.8@130.8 610 whp, CAI, 2.5, E85, id850 on street tires.
matt55 is offline   Reply With Quote
Old 05-14-2013, 03:44 PM   #9
Overflow
Space Shuttle Aficionado
Drives: 2016 Camaro 2SS
GOOD LORD BRING IT TO AMERICA
Old 05-14-2013, 04:08 PM   #10
Silverlsinva
Silverlsinva's Avatar
Drives: 2013 Fiat 500 Abarth Grigio
IM with this guy do you think those led taillights will beable to swap with the SS's Bring the Pick up Car too while your at it with a Lsa and 6speed manual.
Silverlsinva is offline   Reply With Quote
Old 05-14-2013, 04:18 PM   #11
rez333
Drives: 2013 ZL1
What the F? Why are the grilles different? The first pic has an awesome looking grille, and the other pics have a sh!tty looking grille identical to a Hyundai.
nice:
vs BURN IT WITH FIRE!!
If someone from the 1950s magically appeared, what would be the most difficult thing to explain?
"I have a device in my pocket that can access the entirety of knowledge known to man.
I use it to look at pictures of cars and have arguments with strangers."
rez333 is offline   Reply With Quote
Old 05-14-2013, 04:21 PM   #12
LSA vs LS3 cooling needs.
Old 05-14-2013, 04:24 PM   #13
rez333
Drives: 2013 ZL1
so you're saying that GM ripped off the ugliest grille known to man from Hyundai, because of different cooling needs?
Or... they could just use the same awesome looking grille and plug up some of the grille holes or open up more holes as needed or make the grille larger or smaller (but keep the same basic shape) like most other car companies do.
Having two completely different looking grilles, one AWESOME looking and one looking like the love-child of Mick Jagger and a dugong, makes no sense at all.
Old 05-14-2013, 04:29 PM   #14
SIM Curly
Drives: Silver 1LT 2011 camaro
The only thing that changes between the two is the bottom one has fog lights
SIM Curly is offline   Reply With Quote
