Old 05-05-2013, 09:30 AM   #1
mlmvl
mlmvl's Avatar
Drives: 2010 Camaro SS ZL575
What Do I Have Here
I am picking up this project today.
1967 Firebird convertible 400. He had the original 400 but traded it for a 454 motor that needs to be re-built. I am pulling the numbers from the block, heads, and intake manifold. I want to figure out what year motor it is. It has 7.4L G stamped on it which I thin means it is something out of the 80's.
mlmvl is offline   Reply With Quote
Old 05-05-2013, 02:38 PM   #2
Silverlsinva
Silverlsinva's Avatar
Drives: 2013 Fiat 500 Abarth Grigio
I would guess something out of a truck? And congrats on the new project gonna do a build up show and tell?
Silverlsinva is offline   Reply With Quote
Old 05-05-2013, 02:40 PM   #3
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
In the 80's that was the only place they used the BBC.
Sent from my friggin Droid by two thumbs using Tapatalk 2 or whatever the ish it's called....
Firefighter is offline   Reply With Quote
Old 05-05-2013, 03:37 PM   #4
ChrisBlair
Buick 455 Fan
The 454 won't mate up to a BOP trans. To be honest, you're better off with a 400 RA IV build up. There have got to be a billion Poncho clubs to help you out
...and I hope the 454 is in the shed, because there ain't no mill in that car
Old 05-05-2013, 03:42 PM   #5
Firefighter
Was there three trans patterns? I know there was a Chevy then a Pontiac. Wasn't there a Corporate dual pattern? Or something like that.
Old 05-05-2013, 03:50 PM   #6
ChrisBlair
Buick 455 Fan
I don't know how many there were but BOP had commonality. I don't know the reason
Buick Olds and Pontiac used a common pattern and Chevies were different...Not sure about GMC and Caddy. I don't know when that stopped but I'm confident it was in place in '67. I know it was for '74; I still have a TH400 long tail that was hooked up to my '74 Buick 455 bloc,k and it has the BOP pattern without doubt- bolted right up to my Buick transmission built in 1969.
There are adapters though. There might be a corprosate dual pattern in the mid to late 70s and 80s, but in the '60s the divisions hadn't been corralled into the corporate lagoon yet. I feel very confident there is going to be a tranny pattern issue with that Poncho using a Chevy engine. No deal breaker, just a mild PITA- might already have the Chevy trans for all we know.
Old 05-05-2013, 04:04 PM   #7
Firefighter
All of your post is ringing accurate now that I'm thinking about it.
If it were me I would be updating the drivetrain. I would be looking at something LS based and getting some sort of 6 speed trans at minimum. Especially with all the motors out there now and the ease of swaps through the aftermarket.
Old 05-05-2013, 04:19 PM   #8
LStick
Drives: 2021 Shadow Gray 1LS
What a treasure !
If it were me, I'd be nut and bolting it back to a full restoration. A first year convert has to be super rare, and worth the effort.
Your car ....Your decision.....Great find !!!!!!!!!!
LStick is offline   Reply With Quote
Old 05-05-2013, 05:12 PM   #9
05stram
Drives: 2013 RS - 2013 2SS/RS - 1971 RS
Like he said the BOP pattern will have the top of the trans bell housing with a swag if you will and the Chevy pattern will come up into a peak sort of. Yes there was a combined pattern in the late 70s but I believe it did not start until the metrics came about. Somebody may correct me if I am wrong but it has been a while since I had to worry about bell housings.
Chris wasn't there a difference in the BB and SB bell housings as well in the BOP pattern? seems to me there was I cannot remember.
05stram is offline   Reply With Quote
Old 05-05-2013, 05:49 PM   #10
ChrisBlair
Buick 455 Fan
The 1974 Buick 455 that I yanked out of a Riviera bolted right up to the original TH350 in my '70 Buick; that car originally had a Buick 350 that needed the top end redone. It was cheaper to buy an entire car just for the engine and transplant it! Buick didn't really have a 'big block' and a 'small block' per se, they didn't really worry about that, although the parts don't interchange. Incidentally, nothing is a swap on the Buick Olds or Pontiac 455s either. GM practically burned money in those days
My 455 engine inflicted bloody murder on my TH350 of course, but it bolted up with no problems
Old 05-05-2013, 08:15 PM   #11
trademaster
Drives: 12 MP4-12C, 16 Quattroporte
Looks like a nice project. Beautiful dogs too.
trademaster is offline   Reply With Quote
Old 05-05-2013, 08:19 PM   #12
shank0668
shank0668's Avatar
Not to highjack, but I have a TH350 BOP in my garage if someone wants it...
Now if it's an 80's motor, it is definitely a truck 454. I would seriously go back to a Poncho 400 in it.
Looks like a good project!
Old 05-05-2013, 09:10 PM   #13
mlmvl
mlmvl's Avatar
Block numbers,heads
Here are a few of the numbers.
