#1 |
Administrator
Lucky Camaro5 member gets some early seat time in a C7.
Shares his photos with us @ http://www.corvette7.com/forums/showthread.php?t=282807 |
#2 |
Sweet.
Cars and women are both going to give you problems...but you can pay somebody else to fix your car!
#3 |
![]() Drives: 2012 Toyota FJ Cruiser Join Date: Oct 2012
What is the negative 12 on the boost gauge? 12inHG? No one says -12psi hahaha. Its called vacuum. Even so 12inHG is low for a healthy car idling. They must have just thrown some numbers on the dash for the heck of it and figured they will deal with it later.
#4 |
N7 Spectre
Drives: 14 ATS Performance 3.6L AWD Join Date: Jul 2008
The car isn't turned on. 0 RPM.
#5 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 11 F150 EB/13 Sonic RS/15 Z06 Join Date: Sep 2010
He's saying the scale doesn't go low enough. I don't think he was sayiing it was idling and showing too low vacuum.
Old Ride -- 2012 Camaro 2LT/RS (647 RWHP & 726 RWTQ) -- Build Thread |
#6 | |
If it was reading inHg it wouldnt be negative and if it was really negative psi they were showing, it does not equal enough vacuum. Like I said before, its probably just there for testing purposes but im just curious about it is all. Last edited by sonic656; 03-14-2013 at 07:34 PM. |
#7 |
The magic smoke genie....
Drives: Jewels (2010 RJT 1SS) Join Date: Dec 2009
It's a vacume gauge, that's why it reads negative. This gives it a use on non boosted cars as well.
#8 |
We know it can read vacuum and thats why it goes below zero. The numbers below zero should not be negative is the point. Vacuum gauges are not negative and they do not read PSI like that gauge. They read vacuum(inHg). More info on the topic if you click the link in the OP.
#9 |
Recalled user
Drives: '12 Camaro SS, '18 Colorado Z71 Join Date: Mar 2009
Awesome. You guys are nuts that don't like the new rear end.
2012 2SS 45th AE LS3 M6 Borla ATAK Catback Kooks Stepped LT Headers CAI Intake Hexvents VMAX CNC Ported Throttle Body RX Catch Can Hurst Short Throw Shifter Pfadt ZL-Spec Stage 3 Suspension Forgestar F14 Tuned by Frost |
#10 |
It's still PSI. Pounds of Suck Per Inch.......... lol
J/K |
