Go Back   Chevrolet Corvette Stingray C7 Forum > Technical Forums > LT1 (6.2L V8) Powertrain and Drivetrain Discussions
Old 02-27-2013, 01:04 PM   #1
Gohan
Guest
Posts: n/a
Z51 different gearing? faster acceleration?
Will the Z51 feature different gearing than a non Z51 base C7?
Assuming it does, that means it should have better acceleration numbers?
Old 02-27-2013, 04:07 PM   #2
ec1990
Drives: 2012 AGM SS
Unknown yet, the GS on the current C6 has different gearing i believe and goes 0-60 in 3.95 compared to 4.2 for the base.
It all depends on price, the Z51 has more coolers, brake upgrades, i wouldn't be surprised if they changed the gearing though.
ec1990 is offline
Old 02-27-2013, 05:08 PM   #3
imported_Q8y
I think so, In the brochure If you look under packages you will see performance gear ratios as one of the features of the z51 package.
http://www.corvette7.com/forums/showthread.php?t=6
imported_Q8y is offline
Old 03-29-2013, 09:45 PM   #4
volsfan0911
Drives: '10 GTI for now
The manual will have the same ratios as the C6, just with a much taller 3rd overdrive for 7th gear. GS/Z51 ratios are shorter for 1-4 compared to the base 'Vette. Should get off the line a little quicker from a dig?
volsfan0911 is offline
