Old 01-18-2013, 07:35 PM   #1
GaBoy25
GaBoy25's Avatar
Drives: 2010 SS/RS M6/2500HD Lmm LTZ
Active Hatch Vent - One of coolest things about the 2014 Chevrolet Corvette Stingray
This is the coolest thing about the 2014 Chevrolet Corvette Stingray(not my words).
Via http://www.foxnews.com/leisure/2013/...#ixzz2INgnU6vz
The 2014 Corvette Stingray has a lot of holes in it, and that’s a good thing.
Vents, to be precise, and extractors. Also vertical slots behind the front wheels called coves.
It’s all very high-tech, and each one has a purpose. Some, several.
The ones in the hood and fenders, for instance, allow air to travel through the body to reduce aerodynamic lift while directing engine heat up and over the car rather than under it, where it just causes trouble.
Meanwhile, the vents on top of the rear fenders direct air into the vehicle to feed cooling systems for the transmission fluid and electronic limited slip differential, which then exits through openings built into the brake light housings.
But the most unique hole on the ‘Vette is hidden, which is a shame, because it is possibly the coolest feature on the car.
The Active Hatch Vent is hidden behind the Corvette’s rear fascia and features electronically-controlled louvers that open when you lift the hatch. It turns out that the hatch is so large that it acts like a spinnaker sail, catching a huge amount of air and creating a lot of resistance when you try to shut it. Instead, the vent relieves that air pressure to reduce effort, closing again only after the hatch is latched.
Although it seems like a complex solution to a problem that a little muscle could solve, the extra engineering effort involved is an indication the attention to detail put into the rest of the car.
We’ll find out if it all works as well as advertised when the seventh-generation Corvette hits the road later this year.
Attachment 441
Attachment 442
GaBoy25 is offline
Old 01-23-2013, 11:55 AM   #2
Tran
Administrator
Tran's Avatar
Drives: 2010 Camaro of course....
Very
Tran is offline
Old 01-23-2013, 12:19 PM   #3
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
The Camaro has the same thing, except they're not electronically controlled. Instead, it's just a flap of rubber over a vent hole that's hidden by the rear fascia. (And there's one on each side)
Edit: Here's a picture from inside the trunk of one:
My VIN = 2G1FK1EJ9A9105017
CamaroSkooter is offline
Old 01-23-2013, 01:11 PM   #4
Gohan
Guest
Posts: n/a
Didn't know about this til now thanks. Lots of fancy tech in the C7!
Old 01-24-2013, 12:50 PM   #5
monstertodd
monstertodd's Avatar
Drives: 2010 Cyber Grey Metallic 2SS/RS M6
That is really cool!
monstertodd is offline
Old 01-24-2013, 02:41 PM   #6
imported_Indy Bumble Bee
haha that is brilliant if it works correctly
imported_Indy Bumble Bee is offline
