Old 02-23-2013, 07:56 PM   #1
simt3k
Drives: 2011 Camaro RS 2LT
HELP!!!! Oil EXPLOSION in MOTOR WTF!? (Pics WARNING: Graphic)
The destruction...
Catch Can
Also I found this and put a cap over it yesterday...
They took this out???..
HELP!!!!!
Ok, so the crew at my dealership I work at installed my Catch Can, Stage 3 Ported IM and removed the ghetto felt material from the valve covers.
And this happened today on the ride home...... Did they botch the install of the Catch Can?? I am NOT a mechanic but what has happened?! What do I do sorry I am panicking!! :(
simt3k is offline   Reply With Quote
Old 02-23-2013, 08:08 PM   #2
Can't_C_Me
Don't Sleep on My V6
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
Yeah man they hooked up the hoses wrong. Also why you was getting smoke from the breather like you posted in the other thread! I know it's your place of work, but have them clean up the bay. Also seafoam or remove the IM and have it cleaned also. because it's all a oily mess now.
Can't_C_Me is offline   Reply With Quote
Old 02-23-2013, 08:09 PM   #3
OOLIE
OOLIE's Avatar
Drives: 2011 LS
Normal to take that out with a breather but should be capped on both ends. Check intake tube and make sure it is capped.
OOLIE is offline   Reply With Quote
Old 02-23-2013, 08:12 PM   #4
simt3k
So If I reverse the hoses it should be fixed?! Pardon my ignorance just stressed... I am not sure how much oil I lost....
Whats the intake tube end?!
Old 02-23-2013, 08:19 PM   #5
Can't_C_Me
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
Yes reverse the hoses and it's good to go. Also if you look at the 3rd picture you posted thats the end of the tube that needs to be capped off.
Old 02-23-2013, 08:22 PM   #6
simt3k
I capped it yesterday, thanks buddy.. smoke was pouring out of their yesterday as well..
Old 02-23-2013, 08:30 PM   #7
Can't_C_Me
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
Anytime man, Once the hoses are switched and you smoke out the breather. Do what was said in the other thread and make that PCV orifice hole bigger.
Old 02-23-2013, 08:38 PM   #8
simt3k
How do I smoke the breather? and Also how should I clean this oil slick? Spray with high pressure hose and use engine cleaner?
Old 02-23-2013, 08:54 PM   #9
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
May I also add you might want to do an oil change? Just cause you are not sure how much oil you lost and you don't want to add a wrong amount and make matters worse.
Old 02-23-2013, 08:56 PM   #10
simt3k
Do I need to do an upper induction cleaning as well? How do I clean this disgrace?
Old 02-23-2013, 09:12 PM   #11
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Sorry I am late to the help. But the others have told you the right stuff. Hoses were backwards, see my install photo. Your dealer should be doing the entire clean-up for botching the install job. If they don't know what they are doing maybe they should ask. For sure I would not go to that dealer again for installs. If you need to clean it your self, engine cleaning foam and high PSI spray will work. I would cover the elctronic boxes first thou. Also be sure to cap those ends at both the intake side and back of driver side valve cover. See my attached photos. good luck.
rtcat600man is offline   Reply With Quote
Old 02-23-2013, 10:14 PM   #12
OOLIE
OOLIE's Avatar
Drives: 2011 LS
Thanks for the pic on the intake much better than I could do with words.
Old 02-23-2013, 11:03 PM   #13
Can't_C_Me
Can't_C_Me's Avatar
Drives: 2016 C7 1LT
Our team work has always been great un the V6 community.
Sent from my Samsung Galaxy S III
Old 02-23-2013, 11:49 PM   #14
jameslk55
jameslk55's Avatar
Drives: 2012 2LT/RS, 2005 SLK55 AMG
Sorry to hear that man... Did you give them the installation instructions? I would definitely make your dealership crew make everything right.
jameslk55 is offline   Reply With Quote
