Old 02-11-2013, 12:38 PM   #1
pocketcthulhu
pocketcthulhu's Avatar
Drives: 2014 2ss/RS 5th gen Camaro #2
Black Boxes in Cars: Open Call for Comments
Pulled from Eff.org
You might be surprised to learn that the vast majority of new cars sold in the United States contain a device that continuously monitors the driver’s behavior and vehicle performance. This so-called “black box” or Event Data Recorder (EDR) records at least the last several seconds of vehicle and driver data before a crash, ostensibly for use by crash investigators. Last month, the National Highway Traffic Safety Administration (NHTSA) proposed rules that would mandate EDRs in all new cars and light trucks.
While we agree that EDRs can serve a valuable forensic function, we are concerned that the NHTSA’s proposed rules fail to address driver and car-owner privacy in a meaningful way.
The proposed rules are open for public comment due by next Monday, February 11. EFF plans to submit our own formal comments to the NHTSA, but we also wanted to give our supporters a preview of our concerns so that any of you who are so inspired can share your own views with the NHTSA. You don’t have to be a lawyer or an engineer, and in fact comments are best submitted online. You can even submit comments anonymously.
What do black boxes record?
Under the proposed rules, EDRs will be mandatory in all light vehicles (cars and trucks that are required to have front airbags) sold in the United States that are manufactured on or of after September 1, 2014. EDRs will collect technical data (including vehicle speed, engine throttle position, brake use, driver safety belt status, air bag warning lamp status, and changes in velocity) continuously while the vehicle is in operation. Then, once a “crash” is detected (airbag inflation or an extreme change in velocity), at least five seconds of data will be recorded and “locked.” While EDRs are not required to record audio or video, location information, or data such as hours of service for commercial operators, nothing in the regulation prohibits the collection of those data either.
EFF’s Concerns
  • The NHTSA states that it is agency policy “to treat EDR data as the property of the vehicle owner.” That’s not enough. There needs to be a clear statement, both in the regulation itself, and in the owners manual, that any data recorded by the EDR are the sole property of the vehicle owner, and that the owner may expect that the EDR data remain private except if he or she consents to its disclosure.
  • The NHTSA needs to put a cap on the amount of data recorded. The proposed rules set a minimum duration of 5 seconds prior to a crash for the recording of 15 required and 28 optional “data elements.” However, because no maximum duration is specified, and modern automotive electronics packages include large amounts of digital storage, there is nothing to prevent the long-term collection of data. There needs to be a ceiling to the EDR collection requirements, not just a floor.
  • The rules must prohibit the disclosure of EDR data for purposes other than crash recovery. Modern automotive electronics are capable of surprising feats, for instance emailing you when your car thinks its time for an oil change. While the technology is impressive, the data that an automaker’s value-added services relies upon should be kept separate from the data legally mandated data to be collected by the EDR. EDR data is simply too sensitive to be broadcast to any third party by the vehicle itself.
  • The proposed rules must contain a requirement that the data recorded by the EDR be accessible via a published, free, and public standard, or at minimum, free for personal use, i.e. by the car modder community. Under the current draft, the NHTSA proposes that a commercial imaging tool be made available. A requirement that manufactures sell a closed, proprietary tool to access data owned by the consumer isn’t enough.
  • The NHTSA needs to explicitly prohibit the collection of audio, video, and location data by EDRs. The agency states that such data isn’t collected. That’s not enough.
  • Finally, consumer must be clearly informed of what data are being collected. The proposed regulation mandates that each new car’s owner’s manual include a boilerplate notice stating that an EDR is present and that “various systems” are being monitored. That’s not enough. Any EDR data collection beyond the minimum requirements of the regulation needs to be fully and clearly disclosed to the consumer. For instance, while the NHTSA is careful to state that EDRs are not required to collect location data, nothing prohibits automakers from including a location data element in the EDR. If they do, that’s something the consumer needs to know. Likewise, if the EDR records 5 minutes of data prior to a crash (or 5 days, or 5 months), instead of the mandated 5 second minimum, the consumer needs to know that as well.
The agency will hold open its comment period through Monday, February 11. Join EFF and tell the NHTSA that you think it needs to take privacy seriously in the EDR rules."
pocketcthulhu is offline   Reply With Quote
Old 02-11-2013, 02:01 PM   #2
upflying
upflying's Avatar
Drives: '86 Monte Carlo SS
More here..
http://www.camaro5.com/forums/showth...light=blackbox
upflying is offline   Reply With Quote
Old 02-11-2013, 03:40 PM   #3
Brian 1LE SS
Drives: 98 Camaro SS
I wish they wouldnt bother putting these things in new cars and pass the savings on to us.
98 Camaro SS M6, a few mods
13 Ram R/T, tow vehicle
6th gen??
<a href=http://www.norcal-lsx.com/multimedia/data/500/562752_4054654816027_115782456_n.jpg target=_blank>http://www.norcal-lsx.com/multimedia...15782456_n.jpg</a>
Brian 1LE SS is offline   Reply With Quote
Old 02-11-2013, 06:39 PM   #4
Captain Awesome
Drives: 2010 Camaro 2SS/RS
These things don't add much to the cost of a new car, so that argument will get shot down. The car already has systems that access all this information because it is needed for a reliable ABS and Stability Control system. All they will do is add some software to continuously save 5 seconds before a crash.
On the other hand, they did force all cars to have stability control and ABS as standard, and also standard air bags and seat belt warnings. They also made back-up sensors mandatory and now want backup cameras mandatory in addtion to the sensors. The sensors were added because a handful of people were run over a year by people who weren't looking while backing up. I'm not sure what forcing everyone to buy a backup camera accomplishes that the sensors don't already do. All these devices are driving up the cost and weight of cars. Why don't we get to choose what options we want anymore?
Captain Awesome is offline   Reply With Quote
Old 02-11-2013, 07:16 PM   #5
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
Actually a good number of cars have a basic 5sec data logger onboard right now. My '00 TA has one behind the shifter under the center console. I had pics somewhere but its tied into the PCM and does just what the proposed bill suggests.
It is NOT however protected in the ways they propose for the new bill. Funny thing is that unless they make it super smart, it'll log every slip on a slick road as an accident.
Old 02-11-2013, 09:07 PM   #6
Captain Awesome
Will the car still function if the logging box were to get stolen, or if some rodents were to accidentally chew through the wiring?
Old 02-11-2013, 09:29 PM   #7
pocketcthulhu
I have heard a Lot of 50/50 on that, so go unplug the one in your camaro and let us know what happens.
Old 02-11-2013, 10:03 PM   #8
Zabo
Gunning for Sixth
Zabo's Avatar
No idea.. It's why I didn't unplug it and pull the box.
If you aren't sure what it does, and its your daily: don't touch.
Old 02-11-2013, 10:23 PM   #9
Brian 1LE SS
Actually a good number of cars have a basic 5sec data logger onboard right now. My '00 TA has one behind the shifter under the center console. .
Are you sure thats it? I thought that box behind the shifter was for the airbags.
6th gen??
Old 02-12-2013, 01:07 AM   #10
Zabo
Gunning for Sixth
Zabo's Avatar
Nah, it's actually both. Called an EDR (Event Data Recorder). It's also what triggers the bags to blow but the data can be pulled as they suggest in the bill.
What it collects:
Vehicle speed (in five one-second intervals preceding impact)
Engine speed (in five one-second intervals preceding impact)
Brake status (in five one-second intervals preceding impact)
Throttle position (in five one-second intervals preceding impact)
Driver's seat belt state (On/Off)
Passenger's airbag enabled or disabled state (On/Off)
Airbag Warning Lamp status (On/Off)
Time from vehicle impact to airbag deployment
Maximum Delta-V ( DV ) for near-deployment event
Delta-V ( DV ) vs. time for frontal airbag deployment event
Time from vehicle impact to time of maximum Delta-V ( DV )
Time between near-deploy and deploy event (if within 5 seconds)
http://www.airbagcrash.com/
Makes sense for it to be there too, almost dead center of the car from the sides and front so should the car get torn to shreds it's in the least likely spot to get obliterated, just like how real FDR/CVR boxes are in the tails of aircraft.
Old 02-12-2013, 07:41 PM   #11
Number 3
Hail to the King baby!
Number 3's Avatar
No issues..................unless your version of the truth differs from what really happend. In that case it's you against the data.
Old 02-13-2013, 02:30 AM   #12
Captain Awesome
So you're basically putting your future in the hands of a bunch of electronic sensors and a computer running software some contractor wrote.
What could go wrong?
Old 02-13-2013, 05:59 PM   #13
upflying
upflying's Avatar
EDR data is sure a heck of a lot more reliable than a driver statement.
Old 02-13-2013, 06:06 PM   #14
christianmotox
christianmotox's Avatar
Drives: ( . )( . )
100% agree,
why do we use computers?, might as well write everything down right?
I dont mind having the black box, if an accident was my fault and the device confirms that, so be it. Its the right thing to do.
christianmotox is offline   Reply With Quote
