Old 02-07-2013, 01:27 PM   #1
mikeyg36
Drives: 2015 Z/28 #533
Cars that need a small block
Saw this discussed on Motortrend's WOT.
I believe that the XTS and the ATS need a small block. I also agree that the Fisker Karma needs one
Opinions?
Old 02-07-2013, 03:01 PM   #2
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
All cars need a small block. No other engine should exist other than the small block. Duramaxes are small blocks too, so diesel and LPG are covered. /perfect world
Infact, all things should run on small blocks! Alarm clocks, toasters, laptops, small dogs, your neighbor's annoying children..
Old 02-07-2013, 03:41 PM   #3
XTS: Yeah, let's not do another FWD V8.
ATS: LT1 will fit but GM's probably going for the LF3 instead.
Old 02-07-2013, 05:05 PM   #4
mikeyg36
Maybe on the AWD model?
I wish I had a small block alarm clock...
Old 02-07-2013, 05:11 PM   #5
fielderLS3
fielderLS3's Avatar
Opinions?
It would be less likely to start on fire that way, and probably not much less efficient.
Solution: Stop doing large FWD Cadillacs.
Is there a V8 powered ATS in the works (perhaps an ATS-V)?
. 2022 1SS 1LE (Coming Soon)
Old 02-07-2013, 06:15 PM   #6
mikeyg36
The ATS-V is supposed to be running the TT 3.6 V6, but the LS3 and the LT1 will fit. I also heard that the Alpha will need some re-working to support the power and torque of a V8.
Old 02-07-2013, 06:37 PM   #7
ATS-V will probably be LF3 powered, not LT1.
Old 02-07-2013, 07:28 PM   #8
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
And I've heard that its been designed from the beginning to accommodate 4 bangers through high-output V8s, since it will be underpinning the CTS & 6th Gen Camaro as well as the ATS.
Weren't you saying the reverse not that long ago, that it would probably be getting a gen V and not a turbo6?
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 02-07-2013, 07:32 PM   #9
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
I can't see it not having a v8 if the Camaro will have one for the 6th gen - unless the LF3 is really something special - which I hope for but I am not so sure...
Kyle2k is offline   Reply With Quote
Old 02-07-2013, 09:14 PM   #10
mikeyg36
I believe it was C&D that said that the smaller, weight saving parts of the Alpha platform had to be revised and strengthend for V8 applications. I really do hope it gets a V8 and not the turbo 6. I've never been a fan of turbo engines.
Old 02-07-2013, 09:31 PM   #11
I said the LT1 would fit, but back then engineers were still deciding on LT1 vs LF3. Seems like LF3's the predominant rumor now.
All rumors. Technically there isn't a such thing as an ATS-V.
Old 02-07-2013, 09:49 PM   #12
mikeyg36
Whatever engine it has, it better destroy the M3. I hate that car with a passion
Old 02-08-2013, 05:11 PM   #13
Kyle2k
Kyle2k's Avatar
Drives: 2010 Camaro
I just hope that it is a tuned up version of the LF3 with something special as opposed to the same thing you can get in a next gen CTS or XTS
Old 02-09-2013, 12:39 AM   #14
DGthe3
Moderator.ca
DGthe3's Avatar
I guess that depends on what the LF3 is rated at off the shelf. If its a 400 hp engine out of the box, I don't have issue with it being in an ATS-V as is. More would be better, but 400 hp @ 3600lbs is a pretty good combo. If its 350 ... not so much
