01-30-2013, 12:47 PM | #1 |
Drives: Black 2SS/RS M6 Join Date: Mar 2010
Brake Lines
Are there any replacement lines for the SS that are longer that would work for a cts-v front brake conversion?
2010 LS3 2SS/RS M6
AirAid Cold Air Intake, AAC LED sidemarkers, AAC P13w plasmas drl, Kook's Custom 1-7/8" Headers, Corsa Hybrid Exhaust JRE 445 Cam Package, JRE SCT Tune, RX Catch Can and Breather Tech AFX Heater Hose Relocation Kit, Black Chrome Wheels Pfadt trailing and toe arms, Pfadt solid subframe mounts, Pfadt diff bushings, Street Slayer Twin Carbon Technostalgia Camaro LED taillights, CTS-V Front Brakes, Powder Coated Calipers By ME MGW Short Throw Shifter Complete ZL1 Rearend Swap |
01-30-2013, 03:12 PM | #2 |
Drives: 2010 2SS/RS Join Date: Mar 2010
JDP Motorsports sells a Goodridge braided line specifically for their CTS-V conversion. Get in touch with them and they'll get you squared away
2010 CGM 2SS/RS:
Pfadt'ed Out Level 4, Pfadt Featherlight Coilovers, Pfadt ZL1 Sways, Pedders Radius Rod Inserts, CTS-V Brakes, Borla S-Type, Quad Tips, Forgestar 22" F14's (Show), CAI Intake w/ scoop, Rx Catch-Can, AAC Lighting, Showstopper Sidemarkers "Information is the oxygen of the modern age" Build Thread |
01-30-2013, 04:58 PM | #3 | |
Drives: Chevys at the limit Join Date: Nov 2010
We have lines specially made for this conversion. Feel free to Call, PM or email me anytime with questions! Best regards, Tyler 888-308-6007 |
01-30-2013, 05:24 PM | #4 |
Drives: cars Join Date: May 2011
I didn't take comparison pics of stock vs goodridge. I could swear I took 1 but its MIA. The JDP goodridge and pedders are the 2 I know of.
Goodridges ones were nice although i would like a slightly wider copper washer and contact patch on the ends. They're sealing ok though. |
01-30-2013, 06:07 PM | #5 |
I was going to just run with the stock lines but don't want to stretch the line so I think jdp is going to get more of my money.
2010 LS3 2SS/RS M6
01-30-2013, 10:11 PM | #6 |
Drives: '69 SS Convertible Join Date: May 2009
Doesn't make sense to upgrade to CTS-V brakes and not upgrade to stainless lines anyway. You should convert over to DOT4 fluid while you at it as well.
-2010 Camaro 2SS | M6 | VR w/White Stripes | 1 3/4" KOOKS - 3" Magnaflow | LPE 3.91 gears | ADM tuned | Halltech w/ADM Scoop | Spohn/BMR Trailing Arm/Toe Rod | BC Coilovers| Pedders FE4 ZL1 swaybars | Cradle/Diff/Radius Rod bushings | VMax TB | Morimoto Projectors | MGW shifter | Red Calipers
Build Journal |
01-30-2013, 10:52 PM | #7 |
Stainless lines will be on the way tomorrow and already got ate super blue. Done and done. Thanks for the info and help guys.
2010 LS3 2SS/RS M6
01-30-2013, 10:58 PM | #8 |
650HP soon to come
Drives: 2017 Chevy Camaro ZL1 Join Date: Jul 2011
I've seen a bunch of different stainless brake lines. I've got some work soon to be done to my car coming up so the brake lines aren't on my immediate to do list, however I will be sending my calipers off to mike the powder coater guy so when I do that, would be the perfect time to do the brake lines.
I've seen the Granatelli Motorsports Stainless Steel Brake Lines and also the Goodridge and some others. Is there one that really stands up better than the other?
2017 Camaro ZL1
Hyper Blue Metallic A10, PDR, NAV, Premium floor mats |
01-30-2013, 11:08 PM | #9 |
Negative Camber Junkie
Drives: 2010 1SS LS3/6MN ABM 1 of 23 Join Date: May 2009
Well, it does help if they are DOT approved which the Goodrich are IIRC.
for the great folks at JDP. It's where I got mine. T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same. Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different. I can't wait for my next Track fix. DA HAWKS OWN DA CUP!!!!! |
01-31-2013, 10:14 AM | #10 | ||
01-31-2013, 06:47 PM | #11 |
Thanks for the help this morning Tyler.
2010 LS3 2SS/RS M6
