Old 10-16-2012, 01:24 AM   #1
Jas29
Jas29's Avatar
Drives: 2017 Camaro SS
68 charger what should i offer
Hey guys i'm looking at a 68 charger
The person selling the car wont tell me what he wants for it and wants me to make an offer
The engine was rebuilt 8 years ago
-starts no problem but wont idle owner said it has a few vacuum leaks and should be an easy fix
-the rear quarter panels changed around the same time
-new gas tank and gas line(needs to be installed)
-interior needs to be replaced (seats ripped and panels don't look to be in good shape)
-says he has all the missing pieces didn't go through them to check
-its a console automatic original silver w/ blue interior
-he said its a numbers matching engine and transmission
its a Canadian car if that changes the price
Don't want to offer to much for a car that needs a lot of work
Jas29 is offline   Reply With Quote
Old 10-16-2012, 07:44 AM   #2
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
Send a message via AIM to nUcLeArEnVoY
Know the original options? Even poorly optioned (i.e. lower trim levels, engines, etc.) Mopars demand high coin. They're the creme da'la creme of classic muscle when it comes to market value.
A numbers-matching 383 non-R/T is around $13,000.00 for low retail value on NADA, but that constitutes better condition than what you see here.
Low retail value description:
"This vehicle would be in mechanically functional condition, needing only minor reconditioning. The exterior paint, trim, and interior would show normal wear, needing only minor reconditioning. May also be a deteriorated restoration or a very poor amateur restoration. Most usable "as-is".
Some of the vehicles in this publication could be considered "Daily Drivers" and are not valued as a classic vehicle. When determining a value for a daily driver, it is recommended that the subscriber use the low retail value."
This is a project car, so you can expect to at least halve that. A respectable offer for the car would be $6,000.00. See if he bites.
nUcLeArEnVoY is offline   Reply With Quote
Old 10-16-2012, 08:25 AM   #3
CamaroSkooter
Retarded One-Legged Owl
CamaroSkooter's Avatar
Drives: 2010 Black Camaro 2SS
I would start at $3k, and see what his reaction is.
There's a LOT of work to be done on that vehicle...
My VIN = 2G1FK1EJ9A9105017
Old 10-16-2012, 08:48 AM   #4
Russell James
Russell James's Avatar
Drives: '15 SS 1LE, '69 Z28 drag car
I'm seeing maybe 2, if you have your heart set on a 68 Charger that needs everything.
Purchase price on something like that will really be meaningless. Whether it's 1 or 5 k..... it still needs 20 + to complete right, and a year or two of every free minute you have.
I think, more than purchase price... would be the question of do you really want that? If you really have to have it, I'd start at 2. If he is any where over 5 - 6 he's dreaming. I see that car in the 2 - 4 range, 4 being pushing it to someone that really has to have that car for some reason.
Russell James is offline   Reply With Quote
Old 10-16-2012, 08:48 AM   #5
midnighter
Drives: nothing
That looks to be a Charger SE trim with a 383. Offer them no more than $5k. My friend just bought a 1969 Coronet 440 trim (comparable to a Chagrer SE trim) w/383 all original, 80k original one owner miles, for $5k
Old 10-16-2012, 09:58 AM   #6
toesuf94
toesuf94's Avatar
Drives: THR #11 E-force supercharged
Send a message via MSN to toesuf94
$4500.00
Cars and women are both going to give you problems...but you can pay somebody else to fix your car!
toesuf94 is offline   Reply With Quote
Old 10-16-2012, 11:34 AM   #7
Berean
Drives: Truck
$1500 and he orders you a pizza.
Berean is offline   Reply With Quote
Old 10-16-2012, 11:39 AM   #8
Definitely no higher than $5,000, start off at $3,000.
Old 10-16-2012, 11:40 AM   #9
BNB
Rollin' The Lunchbox
Drives: 2012 Camaro Ashen Grey
This.
BNB is offline   Reply With Quote
Old 10-16-2012, 11:43 AM   #10
Ringo64
Forever Pontiac
Drives: 2012 Black 2SS/RS
WIN
Ringo64 is offline   Reply With Quote
Old 10-16-2012, 03:42 PM   #11
nester7929
Rice Harvester
nester7929's Avatar
Drives: 2014 Bright Yellow 2SS/RS
I'd try 2500-3000 here. The trouble is you'll occasionally run into people who think that just because it's a muscle car it's automatically worth a ton. There's a LOT of work to be done here, and when you're haggling make sure you mention that you plan on doing a lot of work, so you need it for a low price.
nester7929 is offline   Reply With Quote
Old 10-16-2012, 03:48 PM   #12
Vikas2k
Drives: '12 Camaro LS V6 6MT, '09 CX9 GT
If its a Canadian tire, is rust an issue on this car? Did you see underneath the car to check for corrosion? Also I see a 2" disconnected hose/harness of some sort.
Vikas2k is offline   Reply With Quote
Old 10-16-2012, 04:34 PM   #13
Jas29
Jas29's Avatar
I met the person he has 7 other cars for sale all mopars and i have no idea why the 2" hose was disconnected but he said fixing that should stop the car from dying. I did look underneath and it didn't look bad the K member was perfectly fine
Here is the Fender tag maybe someone will have better luck decoding it then i did
this is what i got
CAR: Dodge Charger 2 Door Sports Hardtop
ENGINE: 383cid 4-bbl HP V8
TRANSMISSION: 3-Speed Automatic
TIRES: Unknown tire code
MODEL YEAR: 1968
BUILD DATE: September 06.
AXLE: Unknown Axle Code
INTERIOR:
PAINT: Silver Metallic (Dodge) Buffed Silver Metallic (Plymouth), Silver Haze Metallic (Chrysler, Imperial).
OTHER: Unknown Color Upper Door Frame Color.
MOLDINGS:
78: Wheel Lip Mouldings
ABC OPTIONS:
H1: Power Brakes
R1: AM Radio
X1: Tinted Glass (all)
abc OPTIONS:
a6: Console
b4: Bucket Seats
h7: Fender or Hood Mounted Turn Signal Indicators
m6: Driver's Outside Remote Operated Mirror
w6: Build to Spec's for Canada
Old 10-16-2012, 06:28 PM   #14
Mr Twisty
Mr Twisty's Avatar
Pay someone that knows old muscle to look at it. How long has it been outside without the glass in place?
-- Benjamin Franklin
lib·er·ty
/ˈlibərdē/
noun
1.
