Old 08-25-2012, 09:25 AM   #1
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
Perpetual Motion
If you had a Volt and installed an inverter to produce 120 volts, could you then plug it into your Volt to charge your Volt while driving?
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein
PAUL SS is offline   Reply With Quote
Old 08-25-2012, 10:06 AM   #2
awfarley
awfarley's Avatar
Drives: 2011 5.7L Tundra Double-Cab X-SP
That's a fun thought. How/where would you hook it up though? Using the wheels as a sort of turbine?
Then hook it up to a dyno in your backyard and plug your house into it (that's a joke btw)
awfarley is offline   Reply With Quote
Old 08-25-2012, 11:28 AM   #3
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Thats the most creative way to waste electricity (or gas) that I've ever heard of
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 08-25-2012, 11:30 AM   #4
dmginc
dmginc's Avatar
Drives: In Circles
hes talking about a 12v to 120v inverter that would plug into an accessory power in the car and then plug that into the Volts plug in...not sure it would actually work but it is an interesting thought
CAI Cold Air Intake, BMR Strut Tower Brace, BMR 1.2" Lowering Springs
Gen5DIY Fog Lights, Big Worm Third Brake Light/Side Marker Tint (Charcoal)
GTS Tail Light Covers, Purple Under Hood Lighting
Magnaflow Resonated X-Pipe w/ Muffler Delete
Black Plasti Dipped Wheels, Z/28 Spoiler
dmginc is offline   Reply With Quote
Old 08-25-2012, 11:31 AM   #5
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
I think it would shorten the life of your batteries, constantly topping off, no deep cycling...
2010SLVRBULIT is offline   Reply With Quote
Old 08-25-2012, 12:14 PM   #6
matt55
matt55's Avatar
Drives: CTS-V
Nothing is free.
10.8@130.8 610 whp, CAI, 2.5, E85, id850 on street tires.
matt55 is offline   Reply With Quote
Old 08-25-2012, 01:10 PM   #7
DGthe3
Moderator.ca
DGthe3's Avatar
It wouldn't top them off though, just slowly drain them.
Old 08-25-2012, 09:47 PM   #8
KXRM
Drives: 2011 Mustang GT
That won't work, Energy can neither be created nor destroyed and you are consuming energy to move the car, whatever would be left in the ACC lighter would be stored energy. So this would actually waste more energy because no system is perfect and heat from the charger would waste battery while the rest would go back where it came from.
You can kind of think about it like this. Imagine a regular combustion engine vehicle. Now imagine you splice a line into the fuel line that returns gasoline to the tank while you drive. That's all you would be doing here, just with electricity.
KXRM is offline   Reply With Quote
Old 08-26-2012, 01:14 AM   #9
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
Not sure if serious....
JamesNoBrakes is offline   Reply With Quote
Old 08-26-2012, 01:23 AM   #10
DGthe3
Moderator.ca
DGthe3's Avatar
Almost ... to be even more accurate, you should include something about a leak (to approximate the losses from the 12V DC to 120V AC conversion)
Old 08-26-2012, 07:22 AM   #11
pgustavson
Stop writing "vert", ffs!
pgustavson's Avatar
Drives: 2011 2LT Convertible
^This
Vararam | Vmax Ported TB | Ported IM | Vmax Black ICE-olator
pgustavson is offline   Reply With Quote
Old 08-26-2012, 07:55 AM   #12
derklug
derklug's Avatar
Drives: 12 Boss 302
Perpetual motion is only found in 4 year olds at bedtime.
The biggest mistakes in life come when you know exactly what you are doing.
derklug is offline   Reply With Quote
Old 08-26-2012, 10:27 AM   #13
PAUL SS
PAUL SS's Avatar
No, not serious, just putting it out there for thought and discussion.
What we need here on Camaro5 is a think tank.
Old 08-26-2012, 07:06 PM   #14
KXRM
Good point, then imagine that the splice is cobbled together using a botched epoxy job
