Old 08-16-2012, 03:14 PM   #1
Hellfighter
Hellfighter's Avatar
Drives: 2013 Black ZL1
1988 Ford Bronco II XLT
Has anyone owned this car or owns it currently, i just got mine as a DD with 66k miles on it with emaculant interior for 1500$, but the outside paint is good but has few small rust spots, and windows dont go up, i have to push them up if they are down some, and the wheel is loose a little, like if im parked i can turn the wheel left and right freely. Is there anyway to fix this and to remove rust spots in the paint also?
Hellfighter is offline   Reply With Quote
Old 08-16-2012, 03:53 PM   #2
Mishimoto
Drives: Mostly Stock
A low mileage Bronco II, nice buy! Do the windows go up really slow or won't budge at all? The steering will feel loose compared to a newer vehicle, but you should check your steering components. Have someone move the wheel left to right quickly (in park or in neutral with e-brake on) and so you can look for excessive play in the tie rods. For the paint, is there just no paint in those areas and it caused surface rust? Or do you have rust/rot in some spots?
Mishimoto is offline   Reply With Quote
Old 08-16-2012, 04:21 PM   #3
TheReaper
TheReaper's Avatar
Drives: 2018 Mustang GT
Keep an eye on the front brake calipers. The pistons in the stock ones will stick and lock up.
TheReaper is offline   Reply With Quote
Old 08-16-2012, 04:31 PM   #4
ChrisBlair
Buick 455 Fan
Is it the 6 or the 4?
Old 08-17-2012, 12:43 PM   #5
Hellfighter
Windows go down fine, when they try to go up, they just sit there and wont move, so i have to use both hands on both sides to raise them up, and cant let em go all the way down or it will be PITA getting them up. I can take pictures of the rust spots, i think there used to be paint, the vehicle sat for 20 years, then another guy bought it 2 months ago, then i came along and got it as a DD. Was wanting to raise it 2 inches, and get 16 or 17 inch tires, it rattles past 59 MPH like shakes, so i think it has issues with tires, they have not been changed since 04. And im thinking about getting new coils / shocks / springs.
Old 08-17-2012, 12:43 PM   #6
Hellfighter
Its the 2.9 Litre , v6 2WD i think. Its a 5 Speed. I can take pics.
Old 08-17-2012, 12:44 PM   #7
Hellfighter
What do you mean? It has 2 Disk brakes in front and 2 drums in back? Is this normal? should i worry about changing all 4 to disk breaks and renewing the pads and disks? any good after market systems for a decent price?
Old 08-17-2012, 01:06 PM   #8
TheReaper
TheReaper's Avatar
Check the front calipers and if they are stock change them out. Odds are that the previous owner has already changed them. The Ford Ranger and the Bronco II's had serious issues with the calipers in that year. The drum brakes in the back should be fine.
Old 08-17-2012, 10:38 PM   #9
Hellfighter
Why are there 2 drums and 2 disks? why not 4 disks like todays cars.
Also there is a light that says Rear Antilock or something and its lit up orange, what does that possibly mean? i checked all fluids, everything is topped off and this has nothing to do with it but i even drained raidiator fluid and added new.
Old 08-18-2012, 09:28 AM   #10
Rapid Runner
Drives: 2012 Audi TT-RS
Cause the truck was built in 88
As for rear disc brake conversion... the ford ranger and the ford explorer shared many parts.. if their weren't the same their were still highly compatible .. ie: the rear end of an explorer on a ranger
So maybe it may be the same case with the bronco
Sent from my MB855 using Tapatalk 2
Rapid Runner is offline   Reply With Quote
Old 08-18-2012, 12:45 PM   #11
TheReaper
TheReaper's Avatar
Buy a Haynes or Chilton manual for the Bronco and you will get a better picture of what you have.
Old 08-18-2012, 03:08 PM   #12
ChrisBlair
Buick 455 Fan
My 1970 Buick could have been ordered with front discs, but instead it has four drums which was standard for V8 models at the time. How come it didn't have ABS and electronic stability control from the factory?
Old 08-18-2012, 09:10 PM   #13
Hellfighter
I went ahead and did get the manual from o'rileys, when exchanging to motorcraft sparkplugs , and placing screws back into some trim pieces inside lol. Need new shocks and new wheels now and i think it is set for a DD, i got 2 disks and new calipers coming in on tuesday to replace stock ones, Overall the car has been quite bouncy, also wanted to ask does anyone know how well the stock front springs are? for 20 years of sitting , undercarrage has small rust look but inside i see no major rust on floor boards at all. do you think the current suspension is quite good for a good ol while time. Or some things had been recalled and or need replaced? Like i said shocks i am ordering soon cause it is super bouncy, i am sure its fun on the beach at night with a lady and all , but on road boing boing boing. You get the idea.
Old 08-18-2012, 10:49 PM   #14
TheReaper
TheReaper's Avatar
Sounds like you have a plan. The springs should be fine and adding new shocks will tighten things up.
