Old 07-19-2012, 04:49 PM   #1
Cliffjumper
Cliffjumper's Avatar
Drives: 2013 2LT RS Black
The tree I park under is drooling on me
How do I remove the tree sap off my car it has globbed up and ran down my driver side window. I have tride everything including goof off and it's just making it worse. And it's kinda embarrassing
Cliffjumper is offline   Reply With Quote
Old 07-19-2012, 04:49 PM   #2
LIM3
it's mind bottling..
LIM3's Avatar
Drives: SGM
clay bar possibly?
LIM3 is offline   Reply With Quote
Old 07-19-2012, 04:50 PM   #3
ohsotender1
Drives: 2012 45th Anniversary 2SS
try dryer sheets
ohsotender1 is offline   Reply With Quote
Old 07-19-2012, 04:51 PM   #4
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Originally Posted by ohsotender1 View Post
try dryer sheets
Dryer sheets? Just out of curiosity...why?
6. You can't drift in an auto
jeffny09 is offline   Reply With Quote
Old 07-19-2012, 04:51 PM   #5
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Uhhhh sap...it ruined my maximas paint bro...watch out it sont get on ur car bro
Old 07-19-2012, 04:55 PM   #6
IrocJack
IrocJack's Avatar
Drives: 2010 2LT/RS RJT
razor blade (on window) and some WD40
IrocJack is offline   Reply With Quote
Old 07-19-2012, 04:57 PM   #7
Cliffjumper
Ok and then there are three globs on my roof I haven't even touched yet how about those lol. It looks like my car got attacked by aunt jemima
Old 07-19-2012, 05:10 PM   #8
Cliffjumper
Anyone need fire wood I'm about to chop this tree down there is sap running all down my door it's every where. I did get it off the window tho. Thanks irocjack
Old 07-19-2012, 05:11 PM   #9
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Found this on a BMW website.
Parking under large trees can result in unwanted deposits of a sticky substance on the car. Most people assume this is tree sap, but the real culprit is far more likely to be insect honeydew, excreted by aphids or scale insects that infest the leaves and branches.
Composed of sugars and other waste products that pass undigested through the insects' bodies, honeydew becomes harder to remove the longer it's left on the car.
If you remove the honeydew and park under the tree again, you'll just end up with more sticky stuff dripping down on your vehicle. You may be able to dislodge and reduce the numbers of offending aphids in the tree by blasting overhanging branches with a forceful stream of water from a hose. Unfortunately, a hard stream of water does not help much if the source of honeydew is scale insects.
Spraying with insecticides is rarely needed to protect the health of the tree.
Above courtesy of the University of Minnesota Horticulture department.
How to Remove Tree Sap
To remove the tree sap from your vehicle's surface, you can use finger nail polish remover on a cotton ball. After the sap is removed, make a paste of water and baking soda to wash the affected area, then apply wax.
Another method to remove the sap is to use mineral sprits (it will also remove tar). Use a soft, terry towel, or wash cloth dampened with mineral sprits. After removal, wash the car and apply wax to the affected area.
Tree sap can also be removed by using a water-soluble paint brush cleaner. A common household solution is bacon grease or lard. Just rub it on, and off comes the sap. To get tree sap off of your hands, simply rub mayonnaise on them and wash it off. To remove tree sap and other substances, you can use common solvents like lighter fluid, rubbing alcohol, WD-40 or even Skin-So-Soft bath oil.
The way to use those materials is to let them do their work of dissolving (in the case of alcohol) or softening (in the case of oils), enough to rub off the remaining sap. If you use the oil, wash the car afterwards to remove it.
You can also use commercial wax and grease-removing products available at auto supply stores. Be sure to wash and dry the car before applying the wax and grease remover. Then dampen a clean cloth with the solvent and rub the affected area. It may require several attempts if the sap is very thick or extremely hard. The surface may appear hazy after the solvent evaporates, but a good wax application will eliminate the haze and complete the job.
Removing tree sap from a car's finish is a bit more difficult than tar, as hardened sap can scratch your paint. I've found that by hand-rubbing the sap spots with mineral spirits or denatured alcohol, I'm able to easily remove the sap without damaging the finish. Mineral spirits and denatured alcohol acts as a solvent to break up and dissolve the sap.
If there is a large amount of sap on the car, or if the sap has been left on the finish for an extended period of time, it can be a lot of work to remove. For these cases, you can try hitting the affected areas with a light-duty buffing compound to remove the hardened surface on the sap spots. Then you can use mineral spirits or a similar solvent to remove it. The light duty buffing compound softens the sap so the solvent can do its job. The goal is to use the least pressure possible to reduce the risk of scratching the paint. After removing heavy sap, always buff the treated areas with a good polish to clean up any marks created during hand-rubbing with solvent. The treated area must also be re-waxed.
Another technique is to use orange based solvents and children's molding clay. Apply a bit of the solvent and rub with the clay. It is abrasive enough to scrub off the sap which has been broken down by the solvent.
The chemicals used to remove road stains can also remove your wax or sealants. After removing tar, sap or bugs, plan to spot wax or re-wax your vehicle. If you don't have time to wax right away, use a quick detailing spray that contains wax. A quick spray wax is great for this kind of spot waxing, too.
Old tar, tree sap, and paint over-spray can be easily removed with a miraculous new product called automotive clay. As you rub it across any type of surface (paint, glass, plastic, metal, rubber, vinyl) it instantly sticks-to and pulls-off all contamination that is stuck to the surface. Here's how to use an automotive clay bar:
To use the automotive clay, spray a water-based lubricant on a small area of your car and rub the bar back and forth with light to medium pressure. If the lubricant begins to dry, you'll need to spray more. Clay bars are fairly sticky, and they cannot be used dry.
After a few passes with the clay bar, rub your hand over the area to feel if the surface contamination was removed. Keep rubbing until all contamination bumps are gone. Finally, wipe the clay residue off with a soft terry cloth towel, and buff to a nice luster. Just like waxing, work in small areas.
Check the clay bar frequently for hard particles. When found, pick them off. Make it a habit to occasionally knead and reform the bar so that a fresh portion of the bar contacts your car's paint.
When you're finished claying your car, you should go over it with a pre-wax cleaner to finish cleaning the paint and restore essential oils. Then, protect your newly cleaned finish with one or more coats of rich Carnauba wax.
The Bird is the word!
Old 07-19-2012, 05:26 PM   #10
Cliffjumper
So it's not enough that I have to deal with the dead bugs splattering themselves on my car I have to worry about them sh!tting on it to? I quit. Thanks for the helpful tips angrybird
