Old 07-12-2012, 02:08 PM   #1
shank0668
shank0668's Avatar
What to pay for LS1
There is an LS1 long block for sale...
Heads, block, valve covers, and everything to create a long block its only 400 dollars.
241 cast heads, good block, good crank, good clean and marked pistons and rods
Is it worth the 400?
Old 07-12-2012, 03:05 PM   #2
MikeSVX
The magic smoke genie....
MikeSVX's Avatar
Drives: Jewels (2010 RJT 1SS)
Not bad, but if you don't already have a LS1 I would look for something else. You'll need a lot more to do a swap. I would check a salvage yard and see what you can get a complete unit or front clip for. You'll need all the wiring and the ECU.
MikeSVX is offline   Reply With Quote
Old 07-12-2012, 03:53 PM   #3
shank0668
shank0668's Avatar
I know what you're saying, and that was an area of concern for me. What will I have in it as opposed to what I could get a complete one for.
This will be a project over an extended period of time, so I need to consider whether to save and buy everything at once, or start piece by piece.
Old 07-12-2012, 07:17 PM   #4
DaBears
Drives: 2014 Subaru Forester, 2010 Equinox
a dollar
DaBears is offline   Reply With Quote
Old 07-18-2012, 09:04 AM   #5
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Any idea how many miles are on it? Remember that you can't bore them out very far, most people only take them out to 3.905 (comming aftermarket piston size), although I've heard of a few taking them out to 3.910, but not sure of those are off the shelf pistons or something customg and expensive.
Do you know what year it is? The later blocks, 00+ have oil passage design, and improved oil flow. 01+ have bulkhead vent windows, and better windage.
That said, if the bore liners look like they're in good shape, I'd probably pay $400 for it, just know what you're getting before you buy.
Jason@JacFab is offline   Reply With Quote
Old 07-18-2012, 12:03 PM   #6
shank0668
shank0668's Avatar
Didn't have the correct equipment for the bores, but they seemed to be stock from what I had. They are in good shape, you can even see the cross hatch marks from honing a little. I bought it for $350. IT was supposed to be a 99. I am not looking for killer performance, so it will be good.
