Old 06-28-2012, 08:48 PM   #1
themoneypit
Drives: 2012 45th convertible ss ls3
gotta love these chevy dealers!!!
my sister has an 07 tahoe. she calls me the other day and said all the inside gauges stopped working, and she was headed to the dealer to see what the problem was. i was out of town or she wouldve called me first. anyhow, they tell her she needs a new instrument cluster, and cost would be $550.
i told her to run, and i would look at it when i got home. key on, pulled fuse for the cluster, re-installed, and everything is good as golden again.
these dealerships are crooks!! i know its not a camaro, but i had to share this story because our camaros have the same type of guages, and im sure that would fix these as well if they were to stop working on someones car.
themoneypit is offline   Reply With Quote
Old 06-28-2012, 08:52 PM   #2
DFWZ28
DFWZ28's Avatar
Drives: 2010 SS
Jeez, thanks moneypit....good info to have.
DFWZ28 is offline   Reply With Quote
Old 06-28-2012, 08:55 PM   #3
Supercamaro64
Right, right.
Supercamaro64's Avatar
Drives: 79 Z28, 86 Camaro, 94 Burb 4x4
Every dealer is a ripoff, for any type of service except warranty-covered (because its not paid for by you lol)).
"You wanna lay the fate of the world on the kids camaro? Thats cool."
"When reporters asked what it was, one official stated, 'It's a small, vicious animal that eats Mustangs.'"
The Creampuff Fleet-
Supercamaro64 is offline   Reply With Quote
Old 06-28-2012, 09:02 PM   #4
tomlink
tomlink's Avatar
Drives: 2011 Camaro 2LT RS
Send a message via Skype™ to tomlink
Actually I am surprised by the low level of expertise at the dealers. They can use Google too, no? And they have car-specific info from the car company that we don't.
Would they have replaced a good instrument panel without a fuse-pull? I'd bet yes.
tomlink is offline   Reply With Quote
Old 06-28-2012, 09:14 PM   #5
themoneypit
google is how i found out how to fix it. quick search, clicked on a chevy forum, and found it. i even told her while she was at the dealer to have them do it. she said they checked the fuse and it was good, so it needs a cluster... i just started laughing and told her to run...
when i did it for the gauges, the stabilitrak light came on and stayed on. i shut it off, turned key to on again, and did the same for that fuse, then all was good with it. its been about a week now and no more issues.
Old 06-28-2012, 09:25 PM   #6
ec1990
Drives: 2012 AGM SS
I once had the dealership replace the entire steering shaft to fix a clicking sound while braking for over $600. Turns out it was a rotor retainer left on at the factory so they don't fall off. Fixed by the dealership for less than $30.
Good thing is I got a refund check from GM for the full amount after a quick complaint to corporate. Dealerships - Suck, GM - Awesome
ec1990 is offline   Reply With Quote
Old 06-29-2012, 08:12 AM   #7
themoneypit
its just crazy... i would bet that they would have done the fuse pull, and charged her the $550 saying they installed a new cluster. she called and complained after i fixed it in 30 seconds, and they tried to sell her a new tahoe discounted 10grand.. she told them, she would never buy anything from that dealership again, and hung up on him.
Old 06-29-2012, 08:29 AM   #8
Ir0nM4n
Love me some Tacos
Ir0nM4n's Avatar
Drives: 14 1LE
This isnt GM, though it is about a Dealership. My wife owns a Hyundai Tucson and while I was loading bricks in it. I broke the middle safety belt buckle. Took to Hyundai, quote was $200 to replace. Well it was $160 for labor and $40 for the buckle. I explained to her to bring the buckle home and I would install it. Didnt have to remove the seat. I had it installed in less than 1/2 an hour. Reason it was that long is the new bolt for the buckle didnt work. Used the old bolt and whalah installed. I wonder if they just quote book price then do what I did.
Ir0nM4n is offline   Reply With Quote
Old 06-29-2012, 08:52 AM   #9
Bruiser
Drives: 2010 SS/RS IOM w/Cyber Gray Stripes
OT--Tahoe Cluster
Don't be surprised if they stop working again. There is a known problem that the stepper motors go out on these--well at least on the previous body style. '07 is when the new style came out. Anyway, you can get them to "reset" by pulling the fuse a few times but eventually, they just won't reset. Of course maybe the '07s didn't inherit the problems of the '06.
There are places that will rebuild the cluster or you can do it yourself if you can solder.
This is just my experience,
-Bob George
Bruiser is offline   Reply With Quote
Old 06-29-2012, 09:02 AM   #10
Bodih
I Got My Orange Crush
Bodih's Avatar
Drives: it like I stoles it...
Had a similar situation with the anti-lock brakes in my Impala SS. The ABS would stop working, and the DIC would indicate a system malfunction. after I dropped off the car at the dealership, they called me back about 20 minutes later to say it needed the master control module and the control valve changed for a total of $2,500. The kicker was they said they had to change both components because they couldn't tell which one was bad! I told them to button it up and I would come back to get it. They tried to charge me $125 for diagnostics. I asked them why I should pay if their diagnostics can't tell me what's broken; they wrote it off.
They must have reset the codes. The DIC and warning light were out when I left the dealer, but then came on 10 minutes later. I stopped to see a friend that works at a Firestone Service Center. He popped the hood to check the control module, and immediately said he saw the problem. The ground wire had backed halfway out of the connector on the module, so there wasn't a continuous ground. He disconnected the plug, snapped the ground lead back in the connector, and sent me down the road without a charge. I sent him a $100 gift card to a nice restaurant the next day.
How many folks blindly believe the first thing they're told by a mechanic. Unless I already know what the problem is, I get a second opinion, AND a second quote, before the work is done.
My love is in league with the freeway. Its passion will ride, as the cities fly by, and the tail-lights dissolve in the coming of night. And the questions in thousands take flight ~Robert Plant - Big Log~
Bodih is offline   Reply With Quote
Old 06-29-2012, 09:17 AM   #11
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
I'm not. Most have one licensed mechanic and a bunch of apprentices (certified technicians) A.K.A. flunkies. And they all work on flat rate. Get the job done as quickly as possible or you don't make money.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 06-29-2012, 09:27 AM   #12
DRKS1D3
DRKS1D3's Avatar
Drives: '17 Corvette Grand Sport M7
+100 Every dealership is a bunch of clowns. Once they have your money from a sale, they don't care about you anymore. It has to be the slimiest business there is!
MY RIDE: 2017 CORVETTE GRAND SPORT--TRIPLE BLACK, 7 SPEED MANUAL, VARARAM TCR-7 INTAKE, BORLA CATLESS X-PIPE, CARBON FIBER STAGE 2 AERO, MGW SHORT-THROW SHIFTER
**SOLD**2011 TRIPLE BLACK SS CONVERTIBLE--6 SPEED MANUAL, MANY MODS, 455 RWHP/435 RWTQ
DAD'S RIDE: 2012 ZL1 #1866--BLACK, 6 SPEED MANUAL, EXPOSED CF HOOD, POLISHED WHEELS, SUNROOF, ROTO-FAB INTAKE
"Silly Americans, taking from the rich and giving to the poor only works in fairy tales. Success is earned here!".
DRKS1D3 is offline   Reply With Quote
Old 06-29-2012, 11:39 AM   #13
Brett64D
Brett64D's Avatar
Drives: 2010 2SS/RS A6 LS3
If it happens again, go on ebay and look up getting the motors rebuilt. I had several go out in my Avalanche and the guy on ebay replaced all motors, lights and tuned up the entire cluster for $70 including return shipping. They work great now.
Brett64D is offline   Reply With Quote
Old 06-29-2012, 11:46 AM   #14
myold88
myold88's Avatar
Drives: SUMMIT WHITE 2SS/RS CAMARO
How about telling us who this dealer is. Also, I hope you call the dealer and let them know
how you fixed this $550.00 problem yourself.
myold88 is offline   Reply With Quote
