Old 05-09-2012, 12:19 PM   #1
2ndCamaro79
Drives: 2014 V-Sport/ 2015 Escalade
Yikes New M5 Power!!
We spend so much time talking about the new Shelby, but maybe we (and Shelby) should watch out for this monster! Who says a heavy rear wheel drive car can't be fast!! Everyone who thinks the American Muscle cars need to lose weight, prepare to eat your words. Yes I know it cost a lot more than the ZL1 and Shelby, but geez its fast and has all kinds of luxury. I wonder is this the new fastest 4 door production sedan. I would like to see this go head to head with the CTS-V.
Stats:
Weight: 4348 lbs
0 to 60: 3.7 seconds
1/4 mile: 11.9 seconds
2ndCamaro79 is offline   Reply With Quote
Old 05-09-2012, 12:34 PM   #2
ffrcobra_65
Drives: SuperCharged 2SS/RS IOM MN6
That is a fast tank for sure.
ffrcobra_65 is offline   Reply With Quote
Old 05-09-2012, 12:40 PM   #3
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
That thing is a beast, just wish they kept the E60's V10. Can't deny that it's really fast but it doesn't do it for me. I'm holding out for now.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 05-09-2012, 12:59 PM   #4
G8GT4now
G8GT4now's Avatar
Drives: 14 SS Sedan
Looks like Cadillac needs to make a change to the V. It has been the same since 2009. The new M5 will easily beat the V.
G8GT4now is offline   Reply With Quote
Old 05-09-2012, 01:44 PM   #5
rez333
Drives: 2013 ZL1
I understand that launch control can compensate for a lot of things, but I don't understand how it can compensate for 4340lbs of weight. The CTS-V has launch control, is lighter and has more torque. Can someone explain the physics of how this M5 achieves what seems impossible?
rez333 is offline   Reply With Quote
Old 05-09-2012, 02:19 PM   #6
G8GT4now
G8GT4now's Avatar
Drives: 14 SS Sedan
I am not aware of launch control on the V, but I have an automatic.
Old 05-09-2012, 02:23 PM   #7
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
My first guess would be short gearing, followed closely by stickier tires, then under rating the engine.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 05-09-2012, 02:23 PM   #8
2ndCamaro79
No idea .......... Top Gear said it may be the greatest car ever Tell you what the Germans were not happy about losing the crown to the CTS-V.
Old 05-09-2012, 02:33 PM   #9
Stew
I thought per this forum no cars can be underrated anymore.......
Old 05-09-2012, 03:01 PM   #10
The IOM Ninja
Drives: 10' IOM 2SS/RS, 13' GB Shelby GT500
It's actually more than likely the Dual Clutch Transmission and Launch Control. The DCT is the same reason an M3 will do 0-60 in 3.9 Seconds with Rollout...
The IOM Ninja is offline   Reply With Quote
Old 05-09-2012, 03:16 PM   #11
2ndCamaro79
Can we get a dual clutch and HP bump in the 2014 ZL1
Old 05-09-2012, 03:23 PM   #12
DGthe3
Moderator.ca
DGthe3's Avatar
I don't know what you're reffering to. But its pretty easy to under rate an engine if you don't follow the SAE testing procedure.
Also, there is quite a difference between saying that an enigne must be underrated based on a single dyno run & speculating that another one could be underrated to as a possible explanation as to how the car performs better than it should.
Old 05-09-2012, 03:39 PM   #13
BigHemiSrt
Drives: 07 Dodge Charger SRT8
This...more technology basically. Same reason why a almost 4k lb GTR is so damn fast.
BigHemiSrt is offline   Reply With Quote
Old 05-09-2012, 03:52 PM   #14
G8GT4now
G8GT4now's Avatar
Drives: 14 SS Sedan
GTR also had the advantage of all wheel drive, where the M5 is only rear wheel drive.
