Old 05-10-2009, 10:41 AM   #1
Dentyneice
Drives: 2010 Camaro 2ss
Pure Acetone to help Gas Mileage?
The last tip in the video talks about putting 2 ounces of PURE acetone into a 10 gallon gas tank which increased gas mileage by about 9 MPG! Anyone know if this trick actually works?
http://www.wonderhowto.com/how-to/vi...ve-gas-121052/
2010 CGM/Black 2SS M6
20% Tint -:- Hurst 44% Short Throw Shifter -:- Viper 5901 Alarm/Remote start -:- High Gloss Black Painted Calipers + White Brembo Decal
Dentyneice is offline   Reply With Quote
Old 05-10-2009, 11:03 AM   #2
patriotpa
Drives: 02 Silverado, 09 Vue, 10 1SS
Location: Tired of apologizing when we should be kickin' butt!
I'd skip it. Acetone EATS most seals. It's one hell of a solvent. Wanna risk a $35,000.00 car over a few MPG? I wouldn't.
patriotpa is offline   Reply With Quote
Old 05-10-2009, 12:16 PM   #3
Dentyneice
Here's another link about Acetone in cars
http://www.pureenergysystems.com/new...00069_Acetone/
Old 05-10-2009, 12:36 PM   #4
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
Busted by the Mythbusters in both Carb and EFI engines 3 years ago. Made mileage WORSE by their numbers.
Old 05-10-2009, 12:46 PM   #5
patriotpa
I especially enjoyed this part of the page you linked to:
"Acetone and Your Engine
Acetone is known to deteriorate cheap plastics and other substances. While the components in a car's fuel system should be of high quality, and thus immune to any deleterious effects from exposure to acetone, be aware that "ideal" is not always the case in practice. Be advised that not all systems have been tested against acetone. Until such thorough testing has been accomplished and certified by a accredited authority, you assume your own liability for experimentally testing acetone in your particular system. "
'Nother link:
http://peswiki.com/index.php/Directo..._Fuel_Additive
Cautions
Keep acetone away from painted surfaces. It is the key ingredient in paint remover.
Acetone is a poisonous substance with dangerous vapors, similar to gasoline.
Vietnam officially bans acetone as additive in gasoline [dead link] - Acetone is a solvent that can be used as an additive for boosting octane levels in gasoline. However, a high amount of acetone in gasoline can affect the rubber seals of vehicle engines, and is being blamed for the large-scale breakdown of motorcycles in Ho Chi Minh. (Platts; Sept. 8, 2006)
Glencore Singapore to recall acetone-tainted gasoline from Vietnam (International Herald Tribune; September 12, 2006)
Go for it Champ; just make sure you have the money to fix it in case you break something!
Old 05-11-2009, 12:39 PM   #6
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
I can't understand how it would help mileage ... I think it has a lower energy density than gasoline.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 05-11-2009, 12:45 PM   #7
theholycow
theholycow's Avatar
Drives: '02 GMC Sierra, '80 Lesabre
For its energy density to matter, it would have to help by being a fuel. The theories supporting acetone use as a fuel additive tend to be about chemical reactions, catalyzation, cleaning, or changing the combustion process...not about it as a fuel.
I don't believe it helps. I like to find ways that I can save gas, and I like to understand how to do stuff that I wouldn't even want to do, so I give it quite a bit of thought and effort.
Here's a good link busting the acetone as a fuel economy improver idea:
http://www.fuelsaving.info/acetone.htm
Removing weight has surprisingly little effect on fuel economy
Engine break-in procedure | Gear ratios
2002 GMC Sierra 4x4 5.3 (190,000 miles and going strong)
1980 Buick Lesabre family heirloom with 36,000 miles
2008 Volkswagen Rabbit 2 door I5-2.5 5spd DD lease
she really underestimates the damage i would do to her reproductive organs
http://allOffTopic.com is the place for all the naughty stuff you can't get away with on this forum...
theholycow is offline   Reply With Quote
Old 05-11-2009, 05:55 PM   #8
Oracle
Drives: Ford Focus
I would NEVER put acetone in my fuel, several reasons really. the stuff is volatile. like rediculously volatile. it would evaporate out faster than you could use 1/4 of the tank, thus only giving you the advantage for a short time. Acetone is also a hell of a solvent, so the bladder in the gas tank, the fuel lines, the injectors, seals, everything derived from a petrochemical would be corroding away. third the stuff is very hydrophillic. nothing like absorbing water from the air and pumping that into your engine. there is more but really acetone just sounds like a bad idea to me.
Oracle is offline   Reply With Quote
Old 05-11-2009, 06:32 PM   #9
theholycow
theholycow's Avatar
I don't use acetone (as I mentioned above) and am a skeptic, but I think there's a few things to address here...
Are you suggesting that gasoline is not ridiculously volatile?
Does anyone know if there's a measure of volatility?
Do you have a car that doesn't have a sealed fuel system with evaporative emissions control? Fuel vapors go into the charcoal canister and end up getting burned in the engine.
Worse than ethanol? Ethanol is 10% of your gas.
Worse than methanol, too? If you somehow manage to have water in your gas, you put Drygas or HEET in, which is (usually) methanol, whose purpose is specifically to absorb as much water as possible.
Any water in the air in your gas tank is going into your engine, whether it goes through the ethanol that comes in your gas, any additive you put in, or if it just condenses and gets sucked into the fuel pump without binding to something flammable. You want it bound to something flammable (like ethanol, methanol, or acetone if you're one of those silly people who would try acetone).
Old 05-11-2009, 07:50 PM   #10
Captain Awesome
Drives: 2010 Camaro 2SS/RS
^^^ What HE said ^^^
I was gonna mention Mythbusters! You got the jump on me!
Captain Awesome is offline   Reply With Quote
Old 05-11-2009, 08:57 PM   #11
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
Just run leaded gas.
I piss excellence
and fart awesomeness
Old 05-11-2009, 10:09 PM   #12
lovecheese
Drives: 2007 turboed Civic SI
NEVER NEVER do this.
lovecheese is offline   Reply With Quote
Old 05-11-2009, 10:46 PM   #13
semdycadlac
Drives: 02, 03, 05 GMC 2500HD Duramax
buy a moped of u want good mpg
semdycadlac is offline   Reply With Quote
Old 05-12-2009, 12:27 AM   #14
TFord
Camaro Fanatic
TFord's Avatar
Drives: 2000 Z28
Send a message via Yahoo to TFord
lol
TFord is offline   Reply With Quote
CANADIAN GAS MILEAGE! V6 AUTO turab16 Canada 29 05-04-2009 01:06 PM
V-6 mustang EPA Gas Mileage comiskeybum General Automotive + Other Cars Discussion 33 03-18-2009 06:05 PM
Massachusetts may consider mileage chip bigralph General Automotive + Other Cars Discussion 12 02-20-2009 08:58 PM
GM: Natural Gas is an enticing alternative Mr. Wyndham General Automotive + Other Cars Discussion 12 08-02-2008 08:02 PM
Punks puncture gas tanks Scotsman General Automotive + Other Cars Discussion 22 05-30-2008 02:19 AM
