Old 03-15-2012, 11:45 AM   #1
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
and we still have no brakes
and we still have no brakes, only thing that happens, when in my stone drive way, the rears will lock up n drag and thats it.
Everything is new under the hood and up front, but the front brakes don't work right. BUT EVERYTHING IS NEW AAAAAAHHHHHHHHHHHHHH im gonig nuts here.
did I say everything is new???
Old 03-15-2012, 12:48 PM   #2
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
sounds like you've got brakes if its locking up...lol
what car is this for?
I piss excellence
and fart awesomeness
Old 03-15-2012, 12:59 PM   #3
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
86 Firebird
Old 03-15-2012, 01:04 PM   #4
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Ive gone through gallons of fluid, flushing and bleeding.
rears will lock and release as normal, the front just don't do much of anything unless you lean on it hard.
but everything is new, I only have new parts to replace with new parts.
it all happened about 5 years ago, brakes started to go to crap. changed rotor n pads, no change, change calipers n master cylinder, no change, changed booster and prop valve no change, all new rubber and hard lines, no change.
Every summer I mess with it some then give up, being a stick I can just downshift to stop decent. But I won't let the GF or her kids ride in it that way.
Old 03-15-2012, 01:09 PM   #5
Camaro21
Drives: SOLD - 2013 M6 ZL1
It sounds like you have a bad Proportioning Valve or you didn't bleed them in the right sequence.
Camaro21 is offline   Reply With Quote
Old 03-15-2012, 01:43 PM   #6
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
I do have a uni disc/drum brass hotrod prop valve I could put on for a test, SInce its only 2 in and 2 out[stock is 2 in 3 out], id say the large port on the end is for the front brakes???
smaller bottom one rears?
Would I assume the top two input holes would be the same, left top in pic is rear, right top is front?
Old 03-15-2012, 02:01 PM   #7
Fightinfire921
Fightinfire921's Avatar
Drives: GMC Acadia, 2024 Chevrolet Camaro
Send a message via Yahoo to Fightinfire921
Did you bleed the master cylinder?
2024 Camaro 2SS
Fightinfire921 is offline   Reply With Quote
Old 03-15-2012, 02:49 PM   #8
CamaroSpike23
Truth Enforcer
sounds like the prop valve/manifold
with a 2 in, 3 out... IIRC, the larger one should be for the rear brakes (as it should "T" and split across to each of the rear brakes) and each of the smaller ones should be for the fronts individually.
see if this pic helps. you may have the lines run incorrectly
I piss excellence
Old 03-15-2012, 08:34 PM   #9
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
no lines are right, that brass one isn't like stock so i wasn't sure. No way to mix up the lines going from a stock prop to stock prop.
Got it all done, working till I couldn't see then cracked my rear line trying to break the bleeder lose.
had to reflare several lines for standard ends, to avoid needing 999 adapter for the metric ends they had. So fingers crossed there too.
Old 03-15-2012, 09:00 PM   #10
alini
alini's Avatar
Drives: 2016 Camaro Hyper Blue 2SS
How solid is the pedal? Does it feel strong and just not grabbing? You have a locked up caliper or bad brake line causing fluid not to move the caliper piston
Is it soft and not grabbing til the back?? Air in the system still, bleed the brakes again. Start first with the fittings at the master cylinder, then do rear passenger, rear driver, front passenger, front driver.
** The above post is by someone who is not an expert **
2005 Pt Cruiser panel Conversion
2016 2SS Camaro Hyper Blue white interior
1937 Chevy truck. Full custom. Build in work
https://www.teamalini.com
alini is offline   Reply With Quote
Old 03-16-2012, 11:55 PM   #11
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Well I have no choice but to start over with the earliest parts I replaced, which was calipers n rotors.
I can see rotors are fine, reman calipers are $10 each so ill do it anyways.
2013 5th Gen Firebird on order.
86 Pontiac Firebird [a work in progress]
[68 Firebird hoodscoops, custom notchback[1-3 built]rear mounted tach, inverted wing]
http://www.thirdgen.org/techboard/v6...-all-over.html
"In certain extreme situations, the law is inadequate.
In order to shame its inadequacy, it is necessary to act outside the law.
To pursue... natural justice.
This is not vengeance.
Revenge is not a valid motive, it's an emotional response.
No, not vengeance.
Punishment."
Old 03-17-2012, 12:48 AM   #12
MAC
Iroc-Z <3'r
MAC's Avatar
Drives: '87 5.7L Iroc-Z
Heres a thread on Thirdgen.Org related to brake issues. It may be of some use.
http://www.thirdgen.org/techboard/br...al-no-air.html
"Camaro Z/28 is back. Gentlemen, Don't even bother to start your engines."
MAC is offline   Reply With Quote
