Old 03-10-2012, 10:08 PM   #1
Vette TPI
Vette TPI's Avatar
Drives: 1987 Corvette TPI
Unhappy Sony Radio help..
I recently got this radio.
And my Corvette already had an aftermarket xplod 52x4 radio in it but was cheaper and didn't sound good. So me and my brother installed the new one. Every thing was wired correctly and the radio would work until we tried plugging in the antenna cord to the radio. The yellow power wire we forgot to cover touched the back metal part of the radio and it shut off. We went through and checked the radio fuses and every other fuse in the car. And the radio will not work at all, even with the engine running and a door open none of the interior lights will come on either. I think I royally F'd up! :( Please help me figure this out, last resort is to take it to CarToys and I would rather spend that money on other stuff.
Vette TPI is offline   Reply With Quote
Old 03-11-2012, 12:24 AM   #2
OffseT
Maroboy2001 AKA Offset
OffseT's Avatar
Drives: Boosted Trans Am
You sure you checked ALL of the fuses? You could have grounded the power wire.. hope you didn't mess up anything from the fuse box..
OffseT is offline   Reply With Quote
Old 03-11-2012, 04:00 AM   #3
Vette TPI
Vette TPI's Avatar
Everything in the fuse box looks good. Car ran fine when I took her to friends house and back home. Everything but inside lights and radio work.
Old 03-11-2012, 07:10 AM   #4
Bo Tie 1
Bo Tie 1's Avatar
Drives: 11 Camaro SS,05 Vette Z51,76 Camaro
Sure sounds like you popped a fuse. Do you have the manual for the car?
If so check the specific fuses again. Good luck.
Bo Tie 1 is offline   Reply With Quote
Old 03-11-2012, 12:18 PM   #5
ROBOSSRS
ROBOSSRS's Avatar
Check the continuity of the fuses with an ohm meter. Maybe they look good, but could be bad.
Old 03-11-2012, 04:34 PM   #6
Decibel JJ
Car nut
Decibel JJ's Avatar
Drives: Tahoe Z71, Race cars
On some corvettes (and others) the radio constant (yellow) wire is on the same circuit as the cigarette lighter and/or the courtesy lights .. Check that fuse
If I remember right, it's on the passenger side of the dash
Quote: Don't you just hate it when Satan steals your ride and does all these weird ass mods to it?
R.I.P. Evan .. A true Friend
Decibel JJ is offline   Reply With Quote
Old 03-11-2012, 08:23 PM   #7
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
GM never believed in keeping all the fuses in one easy place
Old 03-11-2012, 11:00 PM   #8
v6sonoma
v6sonoma's Avatar
Drives: 2010 SS RS
Make sure to check the fuses in the driver compartment as well as under the hood.
9/26/09 Took delivery!
Old 03-12-2012, 03:20 PM   #9
Vette TPI
Vette TPI's Avatar
I'll run through and just check every fuse while I'm at it.
Can I get one at NAPA?
Ill do that.
I don't know of any place but on the passenger side under the hood and inside the dash on passenger side.
Old 03-12-2012, 03:39 PM   #10
Vette TPI
Vette TPI's Avatar
Thank you Camaro5!!!!!!
I found it was the 15 amp fuse in the courtesy spot on the fuse box on the side! Thank all you for your help it is much appreciated!! Everything is set to go just need to get a new fuse and I'm ready to
Old 03-13-2012, 12:28 AM   #11
Vette TPI
Vette TPI's Avatar
another question, will this fuse be sufficient for use in my Corvette, found it in the garage. It is a 15 amp but very small and wondering if I can still use it.
Old 03-13-2012, 03:16 AM   #12
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
^ drives a Vette but cheaps out on the right 25cent fuse
even cheaper solution is use a 1/4 wide strip of aluminum foil wrapped over each end to complete the circuit. That will be around 15amps, full wrap of fuse is 30-40+
[no I don't have a little ball of foil in ever car just incase I have to rig one to get home ]
Old 03-13-2012, 09:10 AM   #13
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
no it won't
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 03-13-2012, 09:15 AM   #14
Decibel JJ
Car nut
Decibel JJ's Avatar
I fugured thats what it was...
A mini ATC fuse is ok to use in the place as long as your contacts are tight enough to keep the fuse tight in place.
