#1 |
Raised by Wolves
Why would snow...
make my Mazda b2600i pickup start missing? Took me a while to figure it out, but when it is snowing and I'm driving my mazda pickup, after about 15 miles the engine starts to sputter under load. I have a 25 mile commute.
It just seems weird, not all snow causes this but a wetter, heavier snow for sure will make this happen. Light snow, no worries. After I shut it off for a while, it starts and runs fine. This pickup usually runs like a clock. It's my winter beater, and delivers me safely in "most" inclement weather. It's fuel injected, a 90 model 4x4. I thought meybe snow was building up in the air intake, but last time it happened I stopped and checked out the air intake, not a trace of snow. Any ideas? I'm stumped.
#2 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Callaway Rogue Join Date: Jul 2009
Now that is just plain strange.... No idea here.
#3 |
Raised by Wolves
I know! It's just weird. Runs fine and then starts sputtering, missing, choking out. Park awhile, runs just fine, and it only does it when it snows. It can be raining in sheets and water spraying up off the road, no problem. Get just the right kind of snow and it runs like crap! This is why I'm asking - I know there's a lotta real smart guys here willing to offer advice to a damsel in distress.
#4 |
I'm not totally useless..
I would check to see that the connections for the intake piping all along the route from the airbox to the MAF to the TB are tight. If the cold causes a split to open or the like, you could have un-metered air entering the system causing a lean condition....
There are some "known" issues as well with those trucks that haunt me from my days as a tech: 1. MAP - pretty obvious it could be affected by the temp/pressure change with that type of weather affecting fueling/timing 2. MAF -- can be affected by the cold and improperly computing air flow 3. ECT sensor -- if not functioning properly can send improper data to ECM messing everything up.
#5 | |
Raised by Wolves
Ok, that makes sense, i'll check for leaks. Thanks for the input.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2005 STi corn fed Join Date: Jul 2008
Are you sure it's not happening when it's cold enough for snow, not just when it's snowing? Try resetting the ECU by disconnecting the battery for a good 20 minutes or so. Try cleaning the MAF sensor. Is the air filter element dirty?
| Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow | KILLER74Z28 | General Automotive + Other Cars Discussion | 25 | 07-22-2011 10:51 AM |
| This is a hoot! SNOW!!! | rmpackers | Off-topic Discussions | 7 | 01-06-2010 06:29 PM |
| 2 FT OF SNOW A WEEK AGO - ALL GONE & 55 DEGREES TODAY!!! | "prima"Donna | Off-topic Discussions | 17 | 12-27-2009 05:07 PM |
| LM-60 vs X-Ice Xi2 vs Scorpion Ice & Snow | Mayhem | Wheels and Tires Talk Sponsored by The Tire Rack | 8 | 12-09-2009 11:28 PM |
| Flipping weather | Iroczlover | Off-topic Discussions | 10 | 02-11-2009 08:46 PM |
