#1 |
Dodge ram cummins
Anyone own a new cummins preferably a 2010+ did you do the dpf and egr deletes and if so how did you pass inspection? Also is the dpf and egr just the two part under the hood, did you have to do anything to the exhaust?
ordered dec 15 2008 picked up on june 8 2009.
upgrades kooks 1 7/8" LTH w/ deleted cats, corsa exhaust, hurst short throw shifter stage 3 comp cam, 3.91 gears ecs kit blower, meth injection, upgraded axles, drive shaft, McLeod rxt clutch, fully forged 416ci stroker all installed and dyno tuned by slowhawk performance in bridgewater ma. |
#2 |
![]() Drives: car Join Date: Nov 2009
The egr is located high on the engine with a crossover pipe near the valve cover. Blocking the egr is super easy and to cheap but you need a tuner to take care of check engine light.
The dpf is a large container located after the cat with 2 fuel lines running to it. Easy to delete as well. You wont pass inspection if you have emissions. |
#3 |
I don't think I'd do the deletes. I been doin more research now and see alot of people saying that the problems are pretty much cleared with the 2010+ models and even now the 07-09 because of program and software updates. There saying there more driver friendly you can let them sit and idle better mpg and performance so we will see time will tell
#4 |
anyone else have info have the newer ones got better or do they still have problems?
#5 |
![]() ![]() ![]() ![]() Drives: 12 Boss 302 Join Date: Sep 2009
If you are not going to change the exhaust, deleting the EGR and the DEF will result in the particulate filter clogging constantly. The new systems are working much better and are not failing at the old rates.
The biggest mistakes in life come when you know exactly what you are doing.
#6 |
Wow that's good news
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro SS1LE 2000 Trans Am WS6 Join Date: Jul 2008
Lots of complaints on the cummins forum about fuel economy. That's what has kept me from getting one.
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans 2002 Trans Am 2015 Ram Crew Cab Cummins |
#8 |
Ya that's what I've read to the mpg I can deal with. I just don't wanna by one and deal with the dpf problems that's why I'm lookin to see if the bugs have been worked out of the 2010+ I haven't really heard of anything or seen anyone really say anything about it.
#9 |
Retired Navy
Drives: 2010 2SS/RS Join Date: Mar 2011
If you don't have to worry about inspection, then doing the deletes and adding a tuner for the CEL is the way to go. Mileage increases of 3-5 mpg are not uncommon at all.
#10 |
Ya I've heard the mpg get much better with the deletes and tune. But I wouldn't bother doing it here In mass just cuz inspection. I don't want to have to deal with changing everything back every year that's why I'm trying to find more info on issues with dpf but haven't found much on the 2010+
| Why RAM Air is a myth!!! Long Read (Wall of text) | live2well | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 80 | 11-02-2009 03:34 PM |
| It's Official: Ram Truck Brand Split Off From Dodge Brand; Good Idea? | meanmike | General Automotive + Other Cars Discussion | 4 | 10-09-2009 09:23 PM |
| Dodge Challenger R/T Classic Edition | nester7929 | General Automotive + Other Cars Discussion | 25 | 03-12-2009 10:08 PM |
| Challenger Priced | Design1stCode2nd | General Automotive + Other Cars Discussion | 176 | 09-08-2008 07:33 PM |
| 2009 Dodge Challenger Press Release (introducing model lineup) | Tran | General Automotive + Other Cars Discussion | 8 | 03-20-2008 12:47 AM |
